Xj600 sprocket bearing removal
R1stu
Shrek!
PostPosted: 23:50 - 09 Aug 2015    Post subject: Xj600 sprocket bearing removal Reply with quote
Any ideas on the best way to remove the old sprocket carrier bearing at all.
Think will need to replace, due to the amount of rust I cleaned out of it today!
Carbon closet tart! https://www.bikepics.com/members/r6stuk/02r6/
Stolen bike. 2000 R1: https://www.bikepics.com/members/r6stuk/00r1/
Current bike 1991 Honda ST1100 Pan European, 1986 Honda cb350sg (Finished)
R1stu
Shrek!
PostPosted: 11:46 - 10 Aug 2015    Post subject: Reply with quote
All around, but when you rotate the hub you can hear it grind, I've used some bearing oil in there to smooth it for the moment, but there is plenty of play in there!
Fizzer Thou
PostPosted: 12:31 - 10 Aug 2015    Post subject: Reply with quote
When I needed to remove the same bearing in the one on the FZR I placed it in the oven on a low heat.The ally carrier expanded more than the bearing and it tapped out reasonably easily.
When installing the new bearing,store it in the freezer the night before,then heat the carrier.It will push into place more easily using a large socket than using a drift Wink
Always have a 'Plan B'
R1stu
Shrek!
PostPosted: 12:58 - 10 Aug 2015    Post subject: Reply with quote
Good thinking! may try that as well
PostPosted: 18:42 - 10 Aug 2015    Post subject: Reply with quote
Keep the kitchen windows open!
Aff
PostPosted: 19:58 - 10 Aug 2015    Post subject: Reply with quote
Concrete rawl bolt and a drift or slide hammer.
Electric Bike Project
The last post was made 11 years, 31 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 59.73 Kb
