885 Speed Triple p*ssing coolant
Diggs
PostPosted: 09:32 - 10 Aug 2015    Post subject: 885 Speed Triple p*ssing coolant Reply with quote
I came back from a ride on my Mk1 speedy recently, left it on the sidestand to find that after a couple of minutes it began leaking coolant from the coolant cap. I know the level was fine before I set off. Any thoughts?
Now - Speed Triple, old ratty GS550, GSXR750M
Gone (in order of ownership) - Raleigh Runabout, AP50, KH125, GP125, KH250, CBX550, Z400, CB750FII, 250LC, GS550, ZXR750H1, Guzzi Targa, GSX750F, KH250 x2, Bimota SB6R and counting...
davebike
PostPosted: 11:42 - 10 Aug 2015    Post subject: Reply with quote
Fan not cutting in
Blocked rad either water side or more lightly outside (air) side
Dave
NC750Xdct + others at work !
[email protected]
PostPosted: 11:56 - 10 Aug 2015    Post subject: Reply with quote
Overfilled? Rad cap seal/safety valve failing?
Was the temp OK on the ride?
Triumph Trophy Launch Edition
PostPosted: 12:03 - 10 Aug 2015    Post subject: Reply with quote
The cap on my Speed Four went, bodge it by replacing the rubber seal with something thicker or get a new cap from Triumph. I think mine was less than £10.
Diggs
PostPosted: 15:27 - 10 Aug 2015    Post subject: Reply with quote
Long ride on a hot day. The fan did kick in which is a bit worrying otherwise I'd just change the thermostat thingie. I'm going to drain it all down, flush it and refill and see if that cures it...
PostPosted: 15:35 - 10 Aug 2015    Post subject: Reply with quote
Replace the cap...
Diggs
PostPosted: 16:52 - 10 Aug 2015    Post subject: Reply with quote
It was the cap to the expansion tank...
I'm going to bleed the system and put in fresh coolant to see if that helps - the stuff that came out looked like leaky bum-water...
Diggs
PostPosted: 22:10 - 10 Aug 2015    Post subject: Reply with quote
Sorted. I undid the radiator cap and a drain bolt, stuck a hosepipe in and flushed the lot. It took 10 minutes before the water ran clear. I don't know if my method of bleeding is the correct one, but I took the expansion tank cap off and ran the engine until air stopped bubbling out. Just need to get some antifreeze now and top it up...
The last post was made 11 years, 30 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 54.69 Kb
