| RAY WATSON |
 RAY WATSON L Plate Warrior
 Posted: 14:02 - 12 Aug 2015 Post subject: nsr125cdi c1589b can I swap it with a c1626a |
Hi,I have the standard issue with a 1990 JC20 which fires when it wants. I fitted a standard cdi from a 125 Honda and it sparks regulary but wont run The bike as if it has altered the ignition timing. So I purchased a C1626A unit off Ebay as it appeared identical to the orginal C1589B apart from one extra green and white wire wire . The cdi now sparks once and thats all?? Any help please with cross reference /interchange .
| stirlinggaz |
| stirlinggaz |
 Posted: 15:28 - 12 Aug 2015 Post subject: |
hi,
heres an excerpt from Alains nsr tips document. (i hope you dont mind Alain?)
REMEMBER: if you change your CDI unit by a different country specs check carefully if it’s compatible or you will have to modify the wiring . Example fitting a UK specs CDI (CI626) on a FRENCH IMPORT bike require to cross the green and the black/yellow on the connector (the one with 4 wires) . Report to page 7
& heres the text part of page 7 (if you want a copy of the complete page which lists what colour of wires on CDI do what, you will need to download the full doc:
ELECTRONIC DE-RESTRICTIONS
You can note that the black/yellow & green wires are reversed, it is necessary thus, if you fit a UK CDI unit on a French bike to make the following manipulation: On the 4 wires connector 4 leaving the loom, use tweezers with sharp ends. Side opposed to the entry of wire you can see the end of the 4 terminals, introduce a end between the plastic and the terminal (that frees the stop) and pull out gently the wire .You do that with black/yellow and the green, then cross them and refit in the connector. In addition, whilst the two terminals are out, grip them a little to optimize the contacts (a small pliers with fine nozzles is perfect). In more pay attention to push well the terminal inside the bottom of the connector. This CDI unit is negotiated on EBAY around £45 (it becomes rare) but is worth £87 new including all taxes, in the same way for the R/C valves unit (less rare) and which is worth £130
cheers,
GAZ |
| alains |
 alains World Chat Champion
| stirlinggaz |
| alains |
| stirlinggaz |
| alains |
 Posted: 12:58 - 15 Aug 2015 Post subject: |
fitting a CI626A on a JC20 is ridiculous because it's restricted and the ignition advance curve is different
the CI589B does not exist and the CI572 isnt rare on eBay, as
https://www.ebay.co.uk/itm/Honda-nsr-125-jc20-cdi-igniter-/281748308519?hash=item4199820227
i saw 2 or 3 others , some sellers are greedy and price shouldnt go over 40 quids ____________________ the worst day fishing is better than the best day working |
| stirlinggaz |
 Posted: 14:29 - 16 Aug 2015 Post subject: |
hi,
I guess that answers the op's original question as to why it was only sparking once.
I had suspected that the A on the CI627A meant it was restricted but was unsure if it was useable on jc20.
C1589B is what op SAYS he has/had originally.
so he should just buy a C1572, if he ever actually reads this
cheers,
GAZ |
| alains |
| stirlinggaz |
The last post was made 10 years, 323 days ago. Instead of replying here, would creating a new thread be more useful? |
