nsr125cdi c1589b can I swap it with a c1626a
RAY WATSON
PostPosted: 14:02 - 12 Aug 2015    Post subject: nsr125cdi c1589b can I swap it with a c1626a Reply with quote
Hi,I have the standard issue with a 1990 JC20 which fires when it wants. I fitted a standard cdi from a 125 Honda and it sparks regulary but wont run The bike as if it has altered the ignition timing. So I purchased a C1626A unit off Ebay as it appeared identical to the orginal C1589B apart from one extra green and white wire wire . The cdi now sparks once and thats all?? Any help please with cross reference /interchange .
Embarassed Embarassed
stirlinggaz
PostPosted: 15:04 - 12 Aug 2015    Post subject: Reply with quote
Hi,
have a look for Alains(resident nsr guru) nsr tips doc,
Im pretty sure this is referenced in there.
if you cant find the nsr tips doc or Alain hinself doesnt reply, pm me & I will e-mail you a copy.
cheers,
GAZ
stirlinggaz
PostPosted: 15:28 - 12 Aug 2015    Post subject: Reply with quote
hi,
heres an excerpt from Alains nsr tips document. (i hope you dont mind Alain?)
REMEMBER: if you change your CDI unit by a different country specs check carefully if it’s compatible or you will have to modify the wiring . Example fitting a UK specs CDI (CI626) on a FRENCH IMPORT bike require to cross the green and the black/yellow on the connector (the one with 4 wires) . Report to page 7
& heres the text part of page 7 (if you want a copy of the complete page which lists what colour of wires on CDI do what, you will need to download the full doc:
ELECTRONIC DE-RESTRICTIONS
You can note that the black/yellow & green wires are reversed, it is necessary thus, if you fit a UK CDI unit on a French bike to make the following manipulation: On the 4 wires connector 4 leaving the loom, use tweezers with sharp ends. Side opposed to the entry of wire you can see the end of the 4 terminals, introduce a end between the plastic and the terminal (that frees the stop) and pull out gently the wire .You do that with black/yellow and the green, then cross them and refit in the connector. In addition, whilst the two terminals are out, grip them a little to optimize the contacts (a small pliers with fine nozzles is perfect). In more pay attention to push well the terminal inside the bottom of the connector. This CDI unit is negotiated on EBAY around £45 (it becomes rare) but is worth £87 new including all taxes, in the same way for the R/C valves unit (less rare) and which is worth £130
cheers,
GAZ
alains
PostPosted: 12:19 - 14 Aug 2015    Post subject: Reply with quote
it's right for foxeye (JC22) , but for older models (JC20) it's only 2 kinds of CDI : CI572 which is unrestricted and CI589C restricted
both are swapable direct
note : CI589C were sold in France,scandinavia,switzerland & germany
the CI572 were sold in UK & IRL,spain,italia
remenber: JC22 units have an added (white/green) wire which pilot the security stand , this is not the case on the JC20 which has a central stand
stirlinggaz
PostPosted: 15:08 - 14 Aug 2015    Post subject: Reply with quote
hi,
so can the ci626 from a jc22 be fitted to jc20?
providing the wires on the multi-connector matched up (except for the extra wire for side stand) or can be matched up.
would the extra side stand cut out switch wire be left unconnected or would a circuit have to be made?
cheers,
GAZ
alains
PostPosted: 15:33 - 14 Aug 2015    Post subject: Reply with quote
of course yes , the green/white wire is unused
it's possible to build a secret green line through a switch and plug to the ground
but i will find ridiculous to fit a CI626 to a JC20 when the CI572 is the best
stirlinggaz
PostPosted: 02:40 - 15 Aug 2015    Post subject: Reply with quote
hi,
yes but, if i understand the op correctly, he doesnt have a CI572, he had a C1579B & he wants to use a CI626A
but when the CI626A is fitted, its not firing correctly & I thought it might have been something to do with the extra side stand cut out switch wire......just a thought.....I'll bow out lol
cheers,
GAZ
alains
PostPosted: 12:58 - 15 Aug 2015    Post subject: Reply with quote
fitting a CI626A on a JC20 is ridiculous because it's restricted and the ignition advance curve is different
the CI589B does not exist and the CI572 isnt rare on eBay, as
https://www.ebay.co.uk/itm/Honda-nsr-125-jc20-cdi-igniter-/281748308519?hash=item4199820227
i saw 2 or 3 others , some sellers are greedy and price shouldnt go over 40 quids
stirlinggaz
PostPosted: 14:29 - 16 Aug 2015    Post subject: Reply with quote
hi,
I guess that answers the op's original question as to why it was only sparking once.
I had suspected that the A on the CI627A meant it was restricted but was unsure if it was useable on jc20.
C1589B is what op SAYS he has/had originally.
so he should just buy a C1572, if he ever actually reads this Smile
cheers,
GAZ
alains
PostPosted: 18:41 - 16 Aug 2015    Post subject: Reply with quote
of course and for information CI627A (or CI627) and CI589B do not exist
stirlinggaz
PostPosted: 00:12 - 19 Aug 2015    Post subject: Reply with quote
hi,
sorry Alain, that was a typo, it should have been CI626A but CI589B is definitely what the op claimed to have originally.
cheers,
GAZ
The last post was made 10 years, 323 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 2.11 - MySQL Queries: 13 - Page Size: 72.23 Kb
