zx6r loud noise
chappy
PostPosted: 13:23 - 12 Aug 2015    Post subject: zx6r loud noise Reply with quote
Hi there when I started my zx6r g2 yesterday in the wet there was a slight ticking noise on tickover when started. I commuted 60 miles no problems just slight splutter on low revs .
On way home the noise got worse then realy loud to point of bike sounding like a chopper and affecting power. .
So I think exhaust blowing got home checked noise is coming from the right side exhaust headers but can't see no cracks or holes .
Would this be a gasket gon .
Just order 4 new ones and will try have exhaust off later to check . Do I need to remove radiator or not . Any other ideas if not the gasket or cracks in pipe.
Thanks
Matt B
PostPosted: 13:34 - 12 Aug 2015    Post subject: Re: zx6r loud noise Reply with quote
chappy wrote:
So I think exhaust blowing got home checked noise is coming from the right side exhaust headers but can't see no cracks or holes . Would this be a gasket gon .
Yes, most likely. Get it apart and have a look.
chappy
PostPosted: 16:39 - 12 Aug 2015    Post subject: Reply with quote
Hi thanks reply matt. Do I need to remove and take out the rad or can I just move it out way to remove headers
so don't need to rebleed system and refill .
Thanks
chappy
PostPosted: 20:06 - 12 Aug 2015    Post subject: Reply with quote
Hi there so stiped it down rad left in just moved slighly got the headers off and found the nearest one to the right has its bottle neck snaped off ..
not sure if can be welded or not its not rotten or rusty just clean break but plate got to sit flat after . Will look on ebay . Do i need g2 wot is 99 headers only or will 2000 fit also
Thanks
chappy
PostPosted: 20:33 - 12 Aug 2015    Post subject: Reply with quote
Na not the stud sorry if got wrong name . All the nuts came off ok when i lifted the headers out one end bit was broke . Its the bit that looks like a bottle neck sleave the bit the copper gasket sits on and the other side the clamp that bolts up to manifold its the plate thats broke.
So copper gasket / plate / clamp bolt .
Thanks for time the plate they both sit against .
The last post was made 11 years, 20 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.26 - MySQL Queries: 13 - Page Size: 61.76 Kb
