Making exhausts louder and motorcycle lifts.
Irezumi aka Reuben
Carrot Top
PostPosted: 14:37 - 14 Aug 2015    Post subject: Making exhausts louder and motorcycle lifts. Reply with quote
I have a spare set of standard exhausts for my bike that I wish to make louder (not obnoxiously so) but not shorter. There any good guides that people have or just a case of standard take off end, shorten slightly, repack, put end back on etc...?
With regards to motorcycle lifts does anyone have one or can recommend one? Fed up of working on bikes and having to kneel/crouch down all the time!
Thanks for any help.
Pictorgraphicalfantastical
delsol
PostPosted: 14:49 - 14 Aug 2015    Post subject: Reply with quote
If you have the space you won't regret it:
https://www.machinemart.co.uk/shop/product/details/cml3-hydraulic-motorcylce-lift?da=1&TC=SRC-motorcycle%20lift
More compact, (have not personally used one):
https://www.machinemart.co.uk/shop/product/details/clarke-cml5-hydraulic-motorcycle-and-atv-lift?da=1&TC=SRC-motorcycle%20lift
Register online with Machinemart and wait for the regular offers for VAT Free on Clarke products. Or google around and you will probably beat even the Vat free prices.
PostPosted: 14:53 - 14 Aug 2015    Post subject: Reply with quote
Never done it myself but a guy on the TDM forum made his cans louder by drilling extra holes next to the outlet.
https://www.listingfactoryhost.com/users/alanburd/eBayAuctions/skylift2/images/16626740b0de4202a2e6245c0_large.jpg
Abba Skylift is pretty cool
MCN
PostPosted: 15:36 - 14 Aug 2015    Post subject: Reply with quote
Second link is not so good for a fairing-ed bike more suited to dirt-bikes unless you can remove them then somehow avoid hitting the zost which usually run under the engine. Sad
The table one is superb though. I have had one for a couple of years.
I modificated mine by drilling the bed and fitting small 1/4t shackles to accept load straps to help prevent the hoowur from falling off when being worked on it. Jacking up to remove wheels for instance.
delsol
PostPosted: 17:44 - 14 Aug 2015    Post subject: Reply with quote
Similar mods mate Thumbs Up , Exhaust clamp 'U' bolts fitted to take tie downs.
Slide out storage boxes under the floor bed (biccy tins or similar) stops small bits getting dropped and lost, and you know where the parts are for when you come to rebuild.
Doesn't take up too much space really because that's where I park the bike Smile
Drive up the ramp, front wheel in between wheel clamp, side stand down, sorted.
Busa1340R
PostPosted: 17:54 - 14 Aug 2015    Post subject: Reply with quote
I was gonna do this, but after a lot of searching around found a Draper lift with a pneumatic pump and manual foot pump cheaper than Machine Marts equivalent offerings even with the VAT knocked off.
It's currently a little unsteady because of uneven garage floor - I really should adjust the feet properly. Raises the Bus up nicely to around chest height and just about wide enough for ABBA stand or paddock stands....ideal. I park the bike on it all the time to retain garage space.
Current: 2010 Suzuki GSX1340R Hayabusa, 2013 Yamaha YP250R X-Max Sport - Previous: Triumph Sprint ST1050ABS, Honda XL600V Transalp, Honda NT650V Dullsville (don't ask!), Kawasaki ZX9R E1, Honda NX650 Dominator, Suzuki GSX1300RKZ Hayabusa, Honda CBR1000FM, Kawasaki GPZ500S, etc etc
MCN
PostPosted: 00:03 - 15 Aug 2015    Post subject: Reply with quote
I clapse mine flat then lean it against the wall. (They're only about 10" when flatted.) Rock-bolt in the wall with another strap-it-on-to-me hooked onto ramp as security measure. In case the useless bastirt falls onto my tootsies some day. Embarassed
Fizzer Thou
PostPosted: 09:24 - 15 Aug 2015    Post subject: Reply with quote
I would not be without either ramp.I bought one new and the other came along for £100 when a friend had to give up work.Luckily my shed is big enough to not have to worry about moving them around Wink
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Workshop/Picture396.jpg
Always have a 'Plan B'
MCN
PostPosted: 21:08 - 15 Aug 2015    Post subject: Reply with quote
Those strip lights have melted your number plates. Shocked
316lad
PostPosted: 22:24 - 15 Aug 2015    Post subject: Re: Making exhausts louder and motorcycle lifts. Reply with quote
Well, the lift question has been answered above.
To make your exhausts louder simply take a very large screwdriver, insert the sharp end of it into the end can of your exhausts and hit it hard a few times with a lump hammer until it punctures the baffles and makes it a boy racer 'straight thru' exhaust.
OR, (better plan)
Do a bit of research into how to make your bike actually perform better, faster and more exciting and challenging and have a better ride as a result instead of just being an annoyance late at night to your unfortunate neighbours.
spannermonkey...
PostPosted: 20:14 - 20 Aug 2015    Post subject: Reply with quote
Louder isn't always more power. Listen to a boy racer car and it makes more noise but the engine spins up slower. It's all about back pressure and not in a two stroke way. If you make your can noisy, your bike may run leaner and hotter, great if your trying to save on fuel but it will kill the power. Many slip on cans kill top end and have flat spots. You have to change the fuel map/carb jets to suit. Not only does increasing fuel make it run better but it also keeps the engine cool looking after piston rings. Not only changing the exhaust but start looking at how the air enters. KN aren't worth the money, then think about timing.
Go ahead make it loud and empty sounding but the few of us with ears can hear you lot miles off and with no mechanical sympathy and just wonder how long it will be before you wreck the internals.
Current machines - Aprilia RS250. Kawasaki H1A 500. Past machines - Kawasaki ZX7r P6, Yamaha RD250E (the one that got away), BSA Racing bantam (revs over 10'000 sweet as), Yamaha RXS100, Suzuki GP100, Suzuki GS500K2 - best all year machine ever - come rain, sleet and snow just epic.
Val
PostPosted: 01:12 - 21 Aug 2015    Post subject: Reply with quote
That is nice lift:
https://abbastands.co.uk/product-detail.asp?item=superbike-stand
The last post was made 10 years, 315 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.28 - MySQL Queries: 13 - Page Size: 79.71 Kb
