petrol
richfar
PostPosted: 17:48 - 18 Aug 2015    Post subject: petrol Reply with quote
Does plastic float in petrol, being a twat I dropped a plastic nozzle into my fuel tank. Have I got to drain tank and remove to get it out or if I fill the tank will it float to the top .
Thanks
PostPosted: 17:56 - 18 Aug 2015    Post subject: Reply with quote
Depenmds on the plastic.
Do you need it back? Just leave it in there, might interfere with the fuel gauge, if fitted,
Any reason you can't snare it and fish it out with a loop of string down a piece of pipe?
MCN
PostPosted: 18:12 - 18 Aug 2015    Post subject: Reply with quote
As said, depends on density of prastic.
If it's an air-filled capsule type thing then it will probably 'float'. But fishing out may be difficult depending on fuel level and shape tank position of filler neck etc..
It isn't a massive job to whip the tank off and roll about on the ground with it in the hope it falls out. Smile
You can then help your odds by making a half pipe out of something, shove it in the neck of the tank and roll the tank around until the float lands on your half pipe then slide it out like a chute.
BrownTrousers
PostPosted: 18:29 - 18 Aug 2015    Post subject: Reply with quote
It may or may not float. But for the cost of a tank of petrol Id be filling it up and finding out, before faffing with removing the tank (or even before posting the question on here tbh).
Bikers make great organ donors - add your name to the register
Ducati Multistrada 950 | Triumph Tiger 800 XR | Honda CBR500R | Yamaha YBR 125 Custom
MCN
PostPosted: 18:32 - 18 Aug 2015    Post subject: Reply with quote
Agree. but if the filler neck has a doofer to stop fuel sloshing out then filling it up will/may trap the bastirt under the top of the tank.
monkeybiker
PostPosted: 19:02 - 18 Aug 2015    Post subject: Reply with quote
How big is the thing you need to pick up?
Could try one of these.
https://www.ebay.co.uk/itm/Draper-600mm-Flexible-Pick-Up-Tool-Claw-Grab-Action-Retrieving-Arm-Tool/190804450521?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20140122125356%26meid%3D441cdd668c234a9b8021f318070bc4ad%26pid%3D100005%26rk%3D1%26rkt%3D6%26sd%3D400288027815
kipzilla
PostPosted: 21:20 - 18 Aug 2015    Post subject: Reply with quote
Do you have another identical nozzle? If so see if it floats in water, if it doesn't then it definitely won't float in petrol.
skatefreak
PostPosted: 09:56 - 19 Aug 2015    Post subject: Reply with quote
Hah!
I'd leave it!
Had an allen key I thought I had lost years prior fall out a tank once hahaaa...
richfar
PostPosted: 13:32 - 19 Aug 2015    Post subject: Reply with quote
Cheers it does not float, wont come out through filler. Had to remove tank and take out EFI fuel pump off bottom of tank then got it out.
The last post was made 10 years, 321 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.41 - MySQL Queries: 13 - Page Size: 59.6 Kb
