| hollisharri |
 hollisharri L Plate Warrior
 Posted: 13:04 - 19 Aug 2015 Post subject: CG125 E - Snapped chain has smashed part of the casing |
Just posting for a bit of advice.
I bought a CG125 E from gumtree and planned to ride it back home (about 200 miles).
I got about 30 miles when the chain snapped. It was just half of one link but it kicked off the sprocket. I had no tools so had RAC come out. The mechanic shortened the chain and moved the rear wheel in. Everything seemed fine.
About 40 miles later, it happened again, only this time it snapped in half and jammed up against the front sprocket. I also, to my horror, discovered the swing arm pivot bolt had lost its nut and vibrated halfway out the frame. (but that's not the issue).
After getting home via recovery vehicle, I took the flywheel cover off to free the chain and discovered that some of the casing had cracked off inside. Pics below. It looks like the flywheel chamber is still sealed so I'm hoping it's something I can ignore, but I thought I'd ask. Pics below:
https://i.imgur.com/kOG2wc2.jpg
https://i.imgur.com/bXcrGAC.jpg
https://i.imgur.com/sYZFNfR.jpg
https://i.imgur.com/JVhhEcN.jpg
There also appears to be some play on the front sprocket but I'm waiting on some tools to arrive before I can check that out properly. |
| stinkwheel |
 Posted: 13:26 - 19 Aug 2015 Post subject: |
That damage wont bother the bike. That piece of casting is there to stop oil being flung off the front of the chain.
So clean in there, I'd suggest the chain hasn't been oiled for years/since new.
If it were me, I'd glue a bit of bent metal plate to the remains of that casting to keep the lube where it's supposed to be and leave it at that.
Needless to say, check everything else.
Someone's been at the flywheel... ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| hollisharri |
| Vincent |
 Vincent Banned
| hollisharri |
| base |
 base Trackday Trickster
| DrSnoosnoo |
 DrSnoosnoo World Chat Champion
| Pete. |
 Pete. Super Spammer
 Posted: 16:03 - 19 Aug 2015 Post subject: |
| base wrote: | Rac should never of shortened the chain IMO, my biggest concern will be if the shaft has been bent due to the chain stuffing itself into the casing, happened to me years ago on a fz600 had to have a new shaft put in. |
Looks like the casing took all the shock. I don't think the CG has enough mass to bend that shaft, the FZ would have a fair bit more.
hollisharri - the sprocket is supposed to move about, don't worry about that. It should be greased on the shaft though. You do need a new chain though and buy a good one. As stinky said the casing is not broken anywhere important, you can just live with that or glue a patch over, you got lucky there.
Anyway, looking at that bike it seems that someone has stripped it, cleaned it, painted all the rusty bits and put it back together - carelessly. You can see where the swingarm pivot bolt has had the rust wire brushed off the head but not the sides. Do yourself a favour and go over every part of the bike, check all the fasteners and make sure that stuff is greased and oiled where it's supposed to be. ____________________ a.k.a 'Geri'
| mudcow007 |
 mudcow007 World Chat Champion
 Posted: 16:10 - 19 Aug 2015 Post subject: |
why the damage on the flywheel??
has bodyguard ever owned a CG  |
| hollisharri |
The last post was made 10 years, 319 days ago. Instead of replying here, would creating a new thread be more useful? |
