| kon rad |
 kon rad L Plate Warrior
| unitynotsocri... |
 unitynotsocri... Banned
 Posted: 18:09 - 21 Aug 2015 Post subject: |
If the valve length and valve size are the same then it should work if the valve guides are bored out to match,valve stem seals should not be a problem......,
You must check the valve in its seat to see if it needs recutting or grinding. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| kon rad |
| unitynotsocri... |
 Posted: 15:42 - 22 Aug 2015 Post subject: |
They are not exactly the same....they are ten times cheaper . grinding off a few mm will make them behave even cheaper ! They may be wideer cos of crappier steel.
I d check the valve guides and see if its possible to swap them forchinkojap ones.
You may get back pressure in the oil supply and a leaky head if you restrict the oil feed.,.but....! Just kid on its an old Brit bike.no one will know.
If the barrel ally can be chopped so the oil hole is clear then do it. Beware......many big bore kits sometimes need the crankcase mouth to be rebored and some have mismatching lower barrel liners . You can't really go up more in cc terms for the effort\ money involved .
Check the valve guide sizes ,if you can't fit chinklyjap matching guides you could get an engineer to bore out new Honda ones...
Please be careful when mixing chinklyjap and jap parts. There's a few differences between the Honda cg . Generally just use the chinklyjap cases\ covers. The internals are not exactly the same.
You may be able to refit knew guides using the oven to heat the cylinder head , ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| kon rad |
| unitynotsocri... |
 Posted: 17:09 - 22 Aug 2015 Post subject: |
The steel piston liner.....in the barrel can be too long and touch the crank or not fit the crankcase mouth.
When it comes to jap vetrsus chincrap I think of Russia and Germany slogging it out on the eastern front. The Germans with quality network and great optics ,bombs,training etc wheras the ruskies had to stick with bolt action rifles,planes made from fabric but.........win by producing ten times the numbers.
One should compare a Honda seventies\ eighties cg engine with a chinklyjap one.
One of the first things you notice is 8 mm engine\ casing bolts rather than 10 mm head . times that metal saving by the million ....like the ruskies in ww2 and it adds up. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| kon rad |
The last post was made 10 years, 318 days ago. Instead of replying here, would creating a new thread be more useful? |
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.65 - MySQL Queries: 13 - Page Size: 55.68 Kb
