Peugeot Ludix Carb/fuel issue
Paul smifff
PostPosted: 17:57 - 16 Aug 2015    Post subject: Peugeot Ludix Carb/fuel issue Reply with quote
I'm fixing a 2006 ludix up for my nephew. The problem I'm having is if I start it with easy start it starts but obviously only runs for a second. The float area is getting fuel but it won't fire, I feel there's a vacuum issue or I've plumbed the pipes wrong. Does anyone have a ludix or a pic of the carb on the bike for me to compare?
Kind regards
Paul smifff
PostPosted: 20:11 - 19 Aug 2015    Post subject: Reply with quote
So fitted another carb, if I unplug the auto choke it idles nicely and will rev. Though it will only rev up to half throttle then it bogs down. Any ideas .....
There is no mixture adjustment either
Paul smifff
PostPosted: 16:02 - 22 Aug 2015    Post subject: Reply with quote
Got it to rev all the way yesterday. Then nothing, took the carb off and fuel poured out the fuel line. So I am confident the diaphragm has stuck. I will replace and try again
Paul smifff
PostPosted: 20:22 - 23 Aug 2015    Post subject: Reply with quote
Ok so will now idle for 2 to 3 mins then die. Guess it's not getting a healthy fuel supply to the spark.
I've ordered a new carb
New jets
And a new reed.
If this all fails I'm really running out of ideas.
Any other suggestions welcome
Paul smifff
PostPosted: 16:38 - 25 Aug 2015    Post subject: Reply with quote
Reed turned up today and jets. Will update shortly with progression if any
Paul smifff
PostPosted: 19:56 - 25 Aug 2015    Post subject: Reply with quote
Worse than ever. New reed won't start. I could see the standard jet was restricted so replaced it with a new 56 and now it doesn't start at all
Paul smifff
PostPosted: 20:33 - 26 Aug 2015    Post subject: Reply with quote
Ok so more tinkering. Fitted the new jet which has improved the situation. If I blow consistently into the breather on the carb whilst turning over it fires up. I can hold it with the revs but then it cuts out and won't idle. On the plus side the bike will fully rev although it's very smokey and still hesitant on the revving up
Paul smifff
PostPosted: 21:40 - 28 Aug 2015    Post subject: Reply with quote
Ok so I got it reving had to hold it on the throttle. Got it nice and warm and gently revved it until it was going some. I breathed constant firm breaths into the carb breather. Since then it has started and idled well or certainly a huge improvement.
I have also disconnected the rear corroded lights which oddly could be connected?
Paul smifff
PostPosted: 16:59 - 31 Aug 2015    Post subject: Reply with quote
A new carb and fine tinker seems to have resolved both starting and revving issues
Nexus Icon
PostPosted: 17:06 - 31 Aug 2015    Post subject: Reply with quote
Nice to see someone persevere and sort issues out themselves.
Well done.
Have some Karma.
Greetings from Shitsville!
Paul smifff
PostPosted: 17:35 - 31 Aug 2015    Post subject: Reply with quote
Thank you
I was a bit concerned as I've read so many pages on forums of people giving up and not resolving the issues I was very frustrating lol.
Happy it's running nicely now Smile
Paul smifff
PostPosted: 19:25 - 04 Sep 2015    Post subject: Reply with quote
Just an update. Bike is going well and passed it's mot today.
I have noticed when the battery drops by a quarter it starts having running issues. Just worth checking if anyone had these issues 😊
Nexus Icon
PostPosted: 10:32 - 05 Sep 2015    Post subject: Reply with quote
Why is the battery dropping at all? If it's because the bike is standing for days at a time, unused, then I reckon it might be fuel related rather than electricity related. For example, the carb could be flooding or gumming up with shit from the tank while it's sitting.
I haven't had a carbureted bike for years but I don't recall battery power, or lack thereof, affecting the running as long as the thing started in the first place.
Paul smifff
PostPosted: 20:14 - 06 Sep 2015    Post subject: Reply with quote
To be honest I think it's more down to me starting and stopping it so frequently it has had chance to charge. Then when you do start it, due to all the lights running constantly it does keep running as it's not charging enough.
When I charge the battery it's all good. It seems to be an issue when the battery is low.
The last post was made 11 years, 55 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 78.43 Kb
