which tyre sealent
Boris the spider
PostPosted: 18:34 - 25 Aug 2015    Post subject: Reply with quote
This. Don't get caught out and use the cycle stuff.
It is not heavy / thick enough.
I have this in rear of 125. after glass punctured it. No issues at all.
I also have put it in several of her punctured tyres on car.
Again. No issues.
https://www.ebay.co.uk/itm/SLIME-TIRE-TYRE-REPAIR-SEALANT-16oz-FOR-CARS-VANS-/151406871532?hash=item23408d83ec
Yes I'm a pig....And yes... The working public do pay my wages. Tho I contribute to your benefits you lazy c##t. You do not pay my wages. So go fcuk yourself.
joncwl
PostPosted: 18:41 - 25 Aug 2015    Post subject: Reply with quote
i used some tyreweld like thing they use for tractor wheels in one of my 125's tyre after i ran over a hedgehog and no issues since.
currently being a cager cause winter......the bike will be back out during the summer now
last bike, 1990 yamaha tzr125 (2rk model) - still after a fairing kit for it !!!!!
Islander
PostPosted: 19:57 - 25 Aug 2015    Post subject: Reply with quote
Before you chuck sealant in there, try changing the valve core. Thumbs Up
andys675
PostPosted: 21:07 - 25 Aug 2015    Post subject: Reply with quote
if it's that slow you may need bead sealant
PostPosted: 21:20 - 25 Aug 2015    Post subject: Reply with quote
Cheapest on ebay.
Done me fine so far.
kramdra
PostPosted: 00:15 - 26 Aug 2015    Post subject: Reply with quote
None. Sealant is shit, often does not work. Do job properly and find the leak.
Pump to 45psi, apply soap water around tire, bead and valve. This will show where.
Remove tire, check internal damage, plug puncture, give rim a quick clean then either bead sealer or paint**, replace rubber valves every time, they perish and only cost 20p
** paint should be given time to fully dry, solvents are not great for tire life.
Ariel Badger
PostPosted: 23:15 - 27 Aug 2015    Post subject: Reply with quote
I have used Slime for the last eight years, I changed a rear on a road bike and found evidence of four punctures it had stopped. The Badger has it only in the front tyre to add a little weight to keep it on the floor Mr. Green
Major Doss
PostPosted: 04:13 - 28 Aug 2015    Post subject: Reply with quote
Soo Kramdra... Thumbs Up
Do the soap/valve/etc test, when it/if it returns 'nothing', that may be wheel corrosion affecting sealing against the bead. TBH, I have not heard of this ailment afflicting the FZS, yet.
The valve may be new, but that don't mean it was fitted correctly.
Have you whacked a speed hump? I have bent 2 Ducati fronts this way. One rear on a kerb, 'gentle' crash...
If the above tests do not verify, slime/gloop/greenshit will not help, and will very likely piss off whoever removes/replaces your tyre.
I feel your pane, bro.. I is filling air every fortnight.
kramdra
PostPosted: 13:56 - 29 Aug 2015    Post subject: Reply with quote
It will almost always show, even very small leaks. If not, that is why you get the tire off, clean up the bead and give it a decent coat of paint, wait a week for it to harden before fitting tyre. If you cant wait, use bead sealer each time, its not expensive.
Papa Lazarou
PostPosted: 19:51 - 29 Aug 2015    Post subject: Reply with quote
If the puncture is in the centre of the tyre, get it fixed properly. The other stuff is only for getting you home.
If it's in the side wall, new tyre.
Ariel Badger
PostPosted: 23:53 - 29 Aug 2015    Post subject: Reply with quote
Get the right grade of Slime, it differs for tubed and untubed tyres.
PostPosted: 01:55 - 30 Aug 2015    Post subject: Reply with quote
They have it for tubed tyres? That's a new one on me Shocked
twistybiscuit
PostPosted: 14:07 - 03 Sep 2015    Post subject: Reply with quote
Any joy? I have the same issue on my 125 where the rim wasn't sealed properly during the last tyre change. Taking the tyre off seems a faff for what is a very small loss of pressure (~10PSI per week)...
Papa Lazarou
PostPosted: 15:37 - 03 Sep 2015    Post subject: Reply with quote
Just fix the leak. No biggie and a lot safer.
DrSnoosnoo
PostPosted: 12:24 - 08 Sep 2015    Post subject: Reply with quote
I now too have a slow puncture somewhere in my rear tyre. It's getting to the end of its life so will be replaced soon.
How do tyre places appreciate having the rim full of this gunky stuff? Do they complain or is it common enough for it to be encountered often?
I only ask because for some reason, my head has a (possibly invented) memory of tyre people complaining about all the goo coating the wheel rims of cars.
PostPosted: 12:46 - 08 Sep 2015    Post subject: Reply with quote
How to tyre places appreciate having the rim full of this gunky stuff? Do they complain or is it common enough for it to be encountered often?
From my Goldwing days when I had sealant in my tyres some places would not touch it. Others charged you a surcharge to change your tyre.
That was many years ago mind. I wouldn't use the stuff now. AA card and transport to a bike/tyre shop if the get you home repair kit doesn't work.
https://www.ebay.co.uk/itm/STOP-N-GO-POCKET-TYRE-PLUGGER-MOTORCYCLE-PUNCTURE-REPAIR-KIT-SMALL-/221564143110?hash=item3396408606
DrSnoosnoo
PostPosted: 12:49 - 08 Sep 2015    Post subject: Reply with quote
As I feared. I'll just keep topping up til I can get to a tyre shop for a new one.
kramdra
PostPosted: 12:50 - 08 Sep 2015    Post subject: Reply with quote
Theres a good chance they will just fit it as is, with most of the dried stuff in there. Or charge extra to clean it... Some might not care but its not exactly a well paid profession.
PostPosted: 13:47 - 08 Sep 2015    Post subject: Reply with quote
I don't think I'd want to ride on a tyre that had been punctured four separate times unless it was professionally repaired each time...
The last post was made 11 years, 29 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 0.32 - MySQL Queries: 13 - Page Size: 131.51 Kb
