| winsoar |
 winsoar L Plate Warrior
 - Super Spammer
| winsoar |
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 13:29 - 25 Aug 2015 Post subject: |
| winsoar wrote: | | mpd72 wrote: | If they cant recognise a YBR125 carbed engine without a part number, try another breaker.
Is this the normal process when a bike's running rough, replace the entire engine and gearbox? How much is an engine, which could be almost as knackered as the one you currently have? |
They could either fix the existing engine for around £700, or I could get a replacement on eBay for about £300 and they can fit it for £150. |
Never go to that place ever again. Also if you are keen on changing the whole engine, do it yourself. Get the YBR manual, or watch a youtube video.
I'd investigate the engine you've got now before you bin it though. It could be a silly thing, easy to fix. Also, the manual states what to check regularly. According to, let's swap the engine thing, I can see you don't really like the maintenance stuff.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
'95 Mercedes-Benz w202 C200 CGI, '98 Mercedes-Benz w210 E200 Kompressor |
| Ste |
 Ste Not Work Safe
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 15:23 - 25 Aug 2015 Post subject: |
I take it the 'they' are a non franchise mechanics.... 'They' are probably right.....
I can swap a tiddler engine in about an hour... most are attached to the frame with just five bolts, and air-cooled ones in un-faired bikes have bugger all else to undo first before fishing them out; so a half competant mechanics ought to be able to do one, comfortably in a couple of hours; which is perhaps £100 worth of labour.
If you want an engine fixing, rather than replacing; well, same labour is needed to take engine out, and put it back, but in between, you have to take it to bits, find out whats wrong, get parts to fix what's wrong, then put it all back together again. A 'Practiced' mechanic working on an air-cooled engine they know, can possibly do that, in maybe a day, day and a half, lets say, 10hours 'labour'.. so before they bought any bits, like seals, gaskets or oil. at the same notional £50 p/h that's around £500 JUST to pull the motor and have a look at it.. then if the crank is kerbuggered then its however much that would cost to replace or get reconditioned; if the heads kerfuckkered chewed by cam, however much to replace....
BUT, before you start, you have that £600 odd of basic labour to get motor out, look at and put back in, that PROBABLY makes the whole bike, pretty much beyond ecconomical repair..... (qualification)... by a 'paid' mechanic.
£300 for a 'take out' engine to replace the unknown quantity you have? + £150 to swap it? £450... even that's a repair cost, that's aprox half the bikes second hand value; possibly more depending on what shape the rest of the bike is in... if this was accident damage being assessed by an insurance company, that would be on or in the 'write-off' threshold, where the 'risks' associated with repair would mean it's as cheap and easy to just get another bike; remember, replacement engine is NOT a 'guaranteed fix' its a take-out from a second hand bike; what would it have been taken out of? chances are something that was either crashed, and or stolen. If crashed; thing could be not a lot better than what you already have; could have holed the primary cases in a crash and been run out of oil, or left running on its side with the oil all run away from the pump... could be a good'n.. b-u-t its still a 'risk'. So STILL, marginal whether the thing is Beyond Economical Repair (by paid mechanic)
MY ADVICE:- you are talking of chucking big money at a low value bike; and most of it paying some-one else to twiddle spanners. DONT.
Get the bike back; buy a Haynes Manual for it, and if you don't have any tools; get some! Whether you get this bike fixed, or get another, you will need them, unless you want to be paying same fella's rather over-the-odds to do basic routine USER maintenance, like adjusting your drive chain, or changing your oil, ever thousand miles or so.
I would THEN suggest that before you start spending any big money on replacement engines or a new bike; you take a chance, and get a little bit intimate with the engine in this one. It COULD be that the engine is simply so neglected, that teh cam-chain is making a right royal racket from lack of adjustment, and the valves aren't opening 'cos teh tappet clearances are gaping wide, and doing some basic maintenence procedures, as set out in the Haynes Manual, could put it all to rights, for little more than a day, reading the book and following the instructions.... might not.. but what have you got to loose?
After that? Well, you can start taking the engine to bits.. you don't have to take it out the bike to take the top off and have a look... and again, instructions are all in the book.... its just 'time' your time, not a £50 per hour mechanics.
Likely, that there is some major maledy in there.... BUT as you say that the thing is running, and at least capable of 40mph, suggests to ME that it isn't completely extinct, and your crank is seized or main bearings colapsed, and the engine might be 'salvageable' with some slightly less onerouse engineering...
Likely that its no more than the bore is worn beyond, and maybe a piston ring has snapped, and all you need is a rebore and new piston & rings... maybe £50 for a machine shop / engine reconditioners to rebore the cylinder, and £40 for a new piston and rings to suit the bigger hole they cut. Add a top end gasket set, and maybe even a new cam-chain, and you could probably do a DIY 'top end rebuild' on that engine for well under £200 'all in' not taking the engine out of the frame.... As said, what have you got to loose, having a go?
IF NOT... if you really cant face that idea, THEN.. I would suggest that you think long and hard about doing ANYTHING with THIS bike.
IF you can find an engine, you are looking at thick end of £500 to get a paid mechanic to fix it.. and that's before they find any 'niggles' to ramp the labour charges, like the new engine not running right on your carburetor, or the exhaust crumbling when they take it off, or the exhaust studs in the take out engine being sheared and needing machining out and helicoiling....
2007 YBR? Worth what? £750 ish... what would you get for it sold on e-bay 'spares or repairs' "MOT'd, runs, but engine needs attention"... My bet would be there's plenty of optimists that would break thier kneck, hoping top get an "Easy-fix" for £4-500.... add that to what you DONT give paid mechanic, and you have the price of another, better, working bike.
End of the day; that's the choices. Motorcycles are high maintenance machines, they aren't sealed for life consumer goods like a washing machine or car; and a lot of the basic routine maintenance, especially on an 'simple' economy commuter is 'USER' maintenance, that its expected that you, the owner/rider will do; as otherwise you wouldn't have bought such a machine... 'cos paying a paid mechanic £50 an hour to do it for you, rather defeats the 'cheapness' they are bought for!
Unfortunately, too many, don't understand this; and do expect to just add petrol and go places; more so with bikes like the YBR125 sold on high mpg figures to 'learners' too nieve to know chains need adjusting; so older 2nd hand examples are often well into 'maintenance overdraft' before newer nieve newbies get thier hands on them and they brake down!
But that's the choices; if you have the money to pay a paid mechanic to do your dirty work for you, then use a bit of it to buy a better bike that'll likely need less of it to start with; if not, then be prepared to get down and dirty twiddling spanners on your own account.
And from where you are at now; same choice applies.. either get shot of this bike 'as is', recovering as much as value from it as you can, selling 'spares or repairs' to some-one prepared to put in the spanners to make something better of it, and buy something 'better' that doesn';t need so much immediate spannering... OR get spannering... route you are going is likely to turn this thing into a money-pit, paying hand over fist to a paid mechanic for their time and tools, to find and only part solve problems you REALLY don't need.
Re-think the plan from the top... AND don't be afraid to get your own hands dirty.. it's not as daunting as you first imagine, and many of us actually find twiddling spanners and investing a bit of ourselves on making our bikes as 'good' as we can make them quite a lot of fun. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| WD Forte |
 WD Forte World Chat Champion
| andys675 |
 andys675 World Chat Champion
| P.addy |
 P.addy Red Rocket
| RhynoCZ |
 Posted: 15:53 - 25 Aug 2015 Post subject: |
There you go: https://ybrclub.com/_files/books/yamaha/YBR125ED-3D9-E0.pdf Engine removal on page 178, 5th chapter.
As WD Forte suggests, the engine is probably cataloged by its VIN. The first few letters and numbers specify the engine, the rest is just a serial number.
EDIT: Also, if you decide to go for a new engine, do the valve clearances and check the timing chain and it's tensioner before you run it. I'd also check the spark plug. You'd be surprised how many people buy a new engine, put it in their bike and then say it's still crap.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| Ste |
 Ste Not Work Safe
 Posted: 15:56 - 25 Aug 2015 Post subject: |
The old engine will still have value as spares or repair on eBay.  |
| winsoar |
 Posted: 17:18 - 26 Aug 2015 Post subject: |
Just to explain I looked for many months for a bike that was within my price range, and found this one for £700 and was told it was a working bike that passed it's MOT.
I paid cash for the bike and then around 2 months later I had passed my CBT - it took two months for the DVLA to send my replacement driving licence hence the delay.
So then I started riding it, not knowing what the bike should sound like. I started off slow, and as I got better at riding it, I noticed that it got very loud when I tried to get faster than 40 mph, and that's when I decided to get it checked out.
First of all, I got a friend who has the same bike to change the oil for me, and change the spark plug. But when he started the bike up, he immediately recognised that it sounded totally different to his bike.
I then took the bike to a recommended local bike mechanic who confirmed that there is something wrong with the engine - possibly the pistons/bearings I think he said - bottom end trouble I think he called it.
So since then I have been searching on eBay for a replacement engine, but the only ones being listed are the injection models, not the carb models.
The bike has done 12,774 miles and the previous owner was an overweight young guy so he might not have been checking the oil regularly perhaps. I can only guess what could have caused the damage to the engine.
If I pay £500 for the repair, plus the £700 I paid for the bike, that is still within the price range for this bike at this age. So I don't mind paying for the repair if it is going to fix the problem.
I found it extremely hard to find a bike within my price range, so a repair is going to be the best option for me.
But the question still remains - where can I find a replacement engine?
I'm not technical when it comes to bike mechanics. |
| Ste |
 Ste Not Work Safe
 Posted: 17:26 - 26 Aug 2015 Post subject: |
I assume the bike sounded the same before and after your mate did stuff to it?
For trying to track down a suitable engine, try using some of the breakers part finder websites and see what anywhere has to offer.
https://www.google.co.uk/#q=motorcycle+breakers+part+finder |
| winsoar |
 Posted: 17:30 - 26 Aug 2015 Post subject: |
Yes it sounded the same. When I took it to the mechanic he adjusted the idle speed and that has improved it when idle, but still the same issue of not getting past 40 mph.
I will see if I can find it on any websites, it would be easier if I knew the part number though. Most of the sites I've found where they list one don't say if it is carb or injection. When I contact them they say injection! |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 21:11 - 26 Aug 2015 Post subject: |
| winsoar wrote: | I found it extremely hard to find a bike within my price range....
And there in lies your problem.
If you cant fix your own bike, then you either need to be able to afford to pay some-one else who can, or afford one that doesn't need fixing, or a bit of both...
And I stand by previous advice... £700 for a 7 year old YBR, wasn't a bargain, especially for one that has proved to be buggered.
£700 buy price, + £500 repair cost; £1200 isn't within the price range for that bike. £700-£900 is a fair private sale price for it, IF its in good sound condition.. which your's wasn't.. and whatever neglect or abuse it's been subject to that's buggered the engine, would suggest that the rest of the bike has been similarly neglected and or abused, and that even if you fix the engine, it wont make it a top-book price bike, and that when put back into use, that use will see the next weak link in the chain of abused and neglected components.. fork seals, shock absorbers, head-race bearings, brakes, etc start to 'fail' landing you with more big bills each time to be put to rights by an expensive paid for mechanic, making the bike a 'money pit' you have to keep chucking money at to maintain a notional 'residual value' it probably doesn't have, and STILL not have a nice, reliable, joy to ride machine for it all.
I still say; either get brave and try and get some hands on mechanic skills, so that you can fix your own problems and afford to run an 'end of life' old bike, OR cut your losses; sell 'Spares or Repairs', and go find a newer, better condition machine that will do the job you want it to.
As to answering the question of the 'part number' or where to find another 'compatible' engine ... sorry, but I choose NOT to offer suggestion. I don't think that that is in any way 'helping' you.. just assisting you to perpetuate your current frustration & misery.
You might not like the answer; but if you cant see the 'sense' in it, and wish to disguard it as 'irrelevant', then that's your call. end of the day, its your bike, and your money, and you will do what you think is best, regardless, and either you'll sort it, and convince yourself it was a great thing to do, or you'll learn the hard way, maybe it wasn't.. that's your perogative, but I still stand by my advice.
Get a Haynes and some spanners and try and remedy your lack of mechanic skills, OR cut your losses, get rid, and find the money to be able to afford a bike that wont need them. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Val |
 Val World Chat Champion
 Posted: 01:29 - 27 Aug 2015 Post subject: |
| winsoar wrote: | Just to explain I looked for many months for a bike that was within my price range, and found this one for £700 and was told it was a working bike that passed it's MOT.
| Teflon-Mike wrote: | Get a Haynes and some spanners and try and remedy your lack of mechanic skills, OR cut your losses, get rid, and find the money to be able to afford a bike that wont need them. |
^^^ This.
Cut your losses mate. Forget about new engine.
Sell the bike on ebay with no reserve stating that you sell as seen or spares and repairs.
I am pretty sure you will get at least £500. Add £500 for new engine plus £150 for the labour.
For £1150 you will get perfect YBR from ebay.
This is the best way to handle that given the fact you cannot do any repair yourself. ____________________ Adrian Monk: Unless I'm wrong, which, you know, I'm not...
Yamaha Fazer FZS 600, MT09, XSR 900 |
| winsoar |
| Vincent |
 Vincent Banned
 Posted: 17:38 - 01 Sep 2015 Post subject: |
.......and don't let this experience put you off bikes
When looking for another, try and get someone who knows about bikes to go have a look at it with you. Buying any second hand vehicle with little or no mechanical knowledge can be a risky venture. ____________________ Space Is Deep |
The last post was made 10 years, 353 days ago. Instead of replying here, would creating a new thread be more useful? |
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 116.95 Kb
