GT550 G7 tickover problems
Bugsy64
PostPosted: 16:29 - 28 Aug 2015    Post subject: GT550 G7 tickover problems Reply with quote
Hi, I recently rescued this bike from a breakers. I stripped it and have rebuilt her. When fired up she runs at about 5k and is very reluctant to settle down, when it does tickover it starts to climb again. I did not strip the carbs except for removing the tops and bowls and gave them a clean out with carb cleaner. The cables are not snagging, it returns to the stop freely. I have heard rumours that gt's are known for this. Neutral
Bugsy64
PostPosted: 16:49 - 28 Aug 2015    Post subject: Reply with quote
Sounds like an air leak.
check the airbox/manifolds
bypass2
PostPosted: 19:34 - 28 Aug 2015    Post subject: Reply with quote
if it has not been started regular known for it the one i have got does it. start it up when the revs go up turn it off do it 4/5 times then it should settle then.
sickpup
Old Timer
PostPosted: 05:16 - 29 Aug 2015    Post subject: Reply with quote
High mileage with worn spindles creating an air leak?
davebike
PostPosted: 10:06 - 01 Sep 2015    Post subject: Reply with quote
Classic older GT550
check compression
Then if good It is dirty /worn out carbs
Could be a holed diafhram GT well know for this
The throttle spindle wears out the carb bodies causing and air leak this is why I broke several GT550 carb in good nick almost un available
Dave
NC750Xdct + others at work !
[email protected]
The last post was made 10 years, 355 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 42.64 Kb
