Need one fork?
skatefreak
PostPosted: 18:24 - 01 Sep 2015    Post subject: Need one fork? Reply with quote
Well,
after all the thrills of a fork seal that just would not budge I'm after another fork (second hand preferably).
Problem is, ebay only has pairs Neutral
could anyone give me any leads on how\where to source a single fork?
I would take this opportunity to convert the cbr600 f3 to USD forks but as its not a straight swap and I need the bike as backup transport more than I have time to diddle the conversion at the moment its going to have to be just swap out the fork Neutral
Any thoughts would be much appreciated.
Best regards
-Jvr
MCN
PostPosted: 18:26 - 01 Sep 2015    Post subject: Reply with quote
Probably only pairs as it is normal to replace a pair as a matched set. You could wait for someone like you selling one. Smile
Chuffin Nora
PostPosted: 18:49 - 01 Sep 2015    Post subject: Reply with quote
skatefreak wrote:
Well,
after all the thrills of a fork seal that just would not budge...
Been there. Done it. Don't want to do it again.
Your turn!
But before the possibility of me going over old ground, can you explain what you've tried so far?
Obviously the standard slide hammer/WD/boiling water procedures.
Anything else?
Standing by...
There's a fine line between integrity
skatefreak
PostPosted: 19:00 - 01 Sep 2015    Post subject: Reply with quote
Chuffin Nora wrote:
skatefreak wrote:
Well,
Your turn!
Anything else?
Standing by...
Its worse than that...
After many fruitless hours I lost my rag and screw driver'd it out.
Hands up, my bad and indeed I found a nick in the stanchion.
Worked it back with some 2,000 wet-dry/scotch bright, changed the seals, threw it back together and left it in a huff.
Took the bike up and down the road, on/off the breaks to depress the forks but after just a few gos it was pooling around the dust seal.
Wiped it off and repeated the cycle a few times and it shows little to no signs of slowing...
Literally would have to wipe it at the door of the MOT place but would probably still weep just pushing the forks by hand.
Either which way I need this bike to be working and safe and a pissing fork is no good Neutral
Have fired off an email to a breakers with a few f3's but it may have to be a pair at this rate and then oh, how ironically I'll be selling a single fork haha...
Will also have a look at re-chroming as the other fork is just fine...
Wish I had the time for a USD conversion but I can't afford to have this bike off the road to much longer Sad
Best regards
-Jvr
PostPosted: 19:12 - 01 Sep 2015    Post subject: Reply with quote
Offer it at 75% of the price of the pair. Wink
andym
PostPosted: 20:25 - 01 Sep 2015    Post subject: Reply with quote
Had a similar issue with a friends VN800, the seals hadn't been replaced for about 14-15 years and were leaking badly. I'd said how easy it was to replace them without stripping the forks down and proceeded to get tore in to 1 with the screwdriver.... almost 2 hours later the stubborn little bastard released its grip (and that was tapping Rolling Eyes the screwdriver with a hammer)..... OK so after about an hour I started thinking the seals were a different design, but it turns out they were just stuck solidly in place
kramdra
PostPosted: 20:28 - 01 Sep 2015    Post subject: Reply with quote
Photo of the damaged chrome? a light sand with 1500 to take off any burr it will probably be ok.
New fork seals almost always weep, and I only use genuine ones. I recommend a small amount of grease on the seal lips before fitting and a pea sized amount spread around the stanchion under the dust seal. This has always, 10+ times, worked for me, as a singe time, very long term fix.. try it, wont cost anything.
skatefreak
PostPosted: 08:56 - 02 Sep 2015    Post subject: Reply with quote
Its not showing any sign of slowing but I only changed the one so will get the fork off again and try with the other, throwing some grease in there as well.
Will get back with new when there's news!
Best regards
Papa Lazarou
PostPosted: 09:25 - 03 Sep 2015    Post subject: Reply with quote
You could contact your local breakers. The forks will be standard on several models-you need the diameter and length.
Alternatively, you can get the fork rechromed and ground down professionally.
skatefreak
PostPosted: 15:25 - 09 Oct 2015    Post subject: Reply with quote
Gone done found a CBR 600 f3 left hand fork.
Eventually pitched up on ebay for only £60?!
Called round a few breakers a while back and they were a bit silly though.
Wanted £100 for a second hand stanchion (brand new after market part £112 @ weemoto) and > £250 for each full fork...
Maybe understandable as they would be left with a second fork that's harder to shift but kind of pricing themselves out of the market there.
Anywho.
Don't give up, just takes time Very Happy
600 back on the road soon. Much excite!
The last post was made 11 years, 41 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.99 - MySQL Queries: 13 - Page Size: 76.33 Kb
