Honda CBF125 fuelling or electrical?
sgtcalle
PostPosted: 12:18 - 02 Sep 2015    Post subject: Honda CBF125 fuelling or electrical? Reply with quote
Hi All.
I foolishly tried to ride my girlfriends 2010 CBF125 the 45 miles to work the other day. Got 35 miles in when the bike started surging and dieing, before eventually spluttering to a halt. The symptoms were more or less as shown here:
https://www.youtube.com/watch?v=Yz6ljcPzY7E
I have read online that this year of CBF were recalled for faulty fuel pumps, and the symptoms would seem to support this. However, upon trying to restart the bike I found the battery was flat. I bumped it, managed to get a mile or two further before the same thing happened. I had noticed a bit of battery performance degradation in the days prior (I.e not turning over as vigorously). Would a reg/rec or similar fault cause the fuelling issues described? Loath the replace a £200 fuel pump unless I have to.
Any help much appreciated as usual.
CBR600F '02
Manchester
MCN
PostPosted: 12:34 - 02 Sep 2015    Post subject: Reply with quote
If you suspect the battery then test that first.
If not enough juice in the battery then there won't be enough to convert into big happy sparks for the engine.
AVO meters are easily obtainable (without a licence) from your friendly
Maplins.
The battery should have a minimum of 12volts at rest. But 13v is normal.
Under 12v indicates a bad battery.
But these tests are not dead accurate and should not be relied on.
If you have someone to help.
Put the tester to the 20 Volts DC range.
Connect the red to the battery Positive +
Connect the Black to the Frame or Battery Negative -
Turn the bike over on the starter and observe the meter.
It should read 12v or a little under.
If it reads under and rapidly drops to the low numbers then the battery is goosed.
This is a Load Test and is 'almost' the heaviest test for a battery.
Due to bad battery (5 years is nearly old).
Bad charging system.
Bad connections.
And some other less likely stuff.
nowhere.elysium
The Pork Lord
PostPosted: 12:38 - 02 Sep 2015    Post subject: Reply with quote
Kangaroo hopping? They have a known issue with the fuel pump. Check that.
zark
PostPosted: 12:49 - 02 Sep 2015    Post subject: Reply with quote
if they were recalled for fuel pumps - would a quick call to honda establish if you have had a recall or need one?
otherwise - on my FI YBR, every running, starting or lumpy issue was caused by a stator fault not charging the battery. a multi-meter will save you untold guesswork
CBT - Oct 13. Theory - July 14. Mod 1 & 2 - June 15.
Rides a Fazer like an idiot... Edit: Now ride a Fazer Thou...
PostPosted: 13:29 - 02 Sep 2015    Post subject: Reply with quote
How has a hooky fuel pump discharged the battery?
Multimeter.
Charge battery.
Diagnose from there.
sgtcalle
PostPosted: 15:36 - 02 Sep 2015    Post subject: Reply with quote
thanks for the replies.
I will of course be investigating both avenues - but as rogerborg suggests, how would a faulty fuel pump lead to a dead battery.
If my bike has missed a recall, are Honda liable to fix the problem for free on a 2010 bike? Surely they would just say we made every effort to contact the owner but with no success?
CBR600F '02
Manchester
MCN
PostPosted: 16:46 - 02 Sep 2015    Post subject: Reply with quote
I think a safety related recall has no time limit. You can check with VOSA if the bike is listed for recalls.
Recalls
Sudden Loss of Engine Power is something to do with safety. Wink
There is a gap of 217 days between these two posts...
vijay jaganathan
PostPosted: 19:49 - 06 Apr 2016    Post subject: Reply with quote
i would like to share my experience.i also had the same problem two months after searching web i thought it was due to fuel pump.I am from india, new fuel pump costs around 75 pounds which is a big money here.But , i found odd similarity with the problem.It occurs either after servicing or during rainy season.So,i checked the spark plug and found water in the noise suppressor.The old noise suppressor cover is a three piece unit.So, water can enter easily and changed with a single piece unit which costs less less than 1 pound and now it is running fine
The last post was made 10 years, 197 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.06 - MySQL Queries: 13 - Page Size: 63.62 Kb
