| sgtcalle |
 sgtcalle Spanner Monkey
 Posted: 12:18 - 02 Sep 2015 Post subject: Honda CBF125 fuelling or electrical? |
Hi All.
I foolishly tried to ride my girlfriends 2010 CBF125 the 45 miles to work the other day. Got 35 miles in when the bike started surging and dieing, before eventually spluttering to a halt. The symptoms were more or less as shown here:
https://www.youtube.com/watch?v=Yz6ljcPzY7E
I have read online that this year of CBF were recalled for faulty fuel pumps, and the symptoms would seem to support this. However, upon trying to restart the bike I found the battery was flat. I bumped it, managed to get a mile or two further before the same thing happened. I had noticed a bit of battery performance degradation in the days prior (I.e not turning over as vigorously). Would a reg/rec or similar fault cause the fuelling issues described? Loath the replace a £200 fuel pump unless I have to.
Any help much appreciated as usual. ____________________ CBR600F '02
Manchester
| MCN |
 MCN Super Spammer
 Posted: 12:34 - 02 Sep 2015 Post subject: |
If you suspect the battery then test that first.
If not enough juice in the battery then there won't be enough to convert into big happy sparks for the engine.
AVO meters are easily obtainable (without a licence) from your friendly
Maplins.
The battery should have a minimum of 12volts at rest. But 13v is normal.
Under 12v indicates a bad battery.
But these tests are not dead accurate and should not be relied on.
If you have someone to help.
Put the tester to the 20 Volts DC range.
Connect the red to the battery Positive +
Connect the Black to the Frame or Battery Negative -
Turn the bike over on the starter and observe the meter.
It should read 12v or a little under.
If it reads under and rapidly drops to the low numbers then the battery is goosed.
This is a Load Test and is 'almost' the heaviest test for a battery.
Due to bad battery (5 years is nearly old).
Bad charging system.
Bad connections.
And some other less likely stuff. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN.
| nowhere.elysium |
 nowhere.elysium The Pork Lord
| zark |
 zark Trackday Trickster
| Pol Anorl |
 Pol Anorl Banned
 Posted: 12:58 - 02 Sep 2015 Post subject: |
fuel pump.
known issue
recall for many
call honda. ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
20:30:37 Pyro.: I don't sort of like men, I take every advantage to choke on dick.
Jewlio Iglesias: You live in Liverpool - Chances are, the front door has already been kicked off the hinges |
| Rogerborg |
 Rogerborg nimbA
 Posted: 13:29 - 02 Sep 2015 Post subject: |
How has a hooky fuel pump discharged the battery?
Multimeter.
Charge battery.
Diagnose from there. ____________________ Biking is 1/20th as dangerous as horse riding.
| sgtcalle |
| MCN |
 MCN Super Spammer
There is a gap of 217 days between these two posts... |
| vijay jaganathan |
 vijay jaganathan L Plate Warrior
The last post was made 10 years, 196 days ago. Instead of replying here, would creating a new thread be more useful? |
