Yamaha ybr125 2012 Side Stand
Ruffone1958
PostPosted: 16:17 - 02 Sep 2015    Post subject: Yamaha ybr125 2012 Side Stand Reply with quote
Hi, Having problems engaging side stand. I can see problem it is the small pin that stops engine if stand is still down. The pin is bent upwards so I cannot engage stand to full lock. Can I bend it back down ? Or get new part? Are these expensive and easy to fit? My bike DIY is pretty basic !!!
PostPosted: 16:25 - 02 Sep 2015    Post subject: Re: Yamaha ybr125 2012 Side Stand Reply with quote
They are easy to fit, a new one isn't as cheap as it should be £50 from AJ Sutton, you may be able to get a cheap one second hand.
Best bet is to take it off clean it up and see if you can get it working again. Failing that you can just bridge the wires to bypass it.
The last post was made 10 years, 351 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 31.53 Kb
