Cheap Airbrush
PostPosted: 18:39 - 03 Sep 2015    Post subject: Reply with quote
No reservoir so not great, although the pump is fine for minor stuff. I have a similar pump but with a reservoir for painting models.
There are loads of cheap air brushes around on Ebay and the like, or get an Iwata Neo for about £45 (half decent basic airbrush - it is better than me so I am pretty happy with it).
K
MCN
PostPosted: 22:23 - 03 Sep 2015    Post subject: Reply with quote
As Kickers says, No reservoir so not much cop.
The compressor has a very small output so you will not get much air flow to drive an air brush.
You can probably find a pressure vessel for it quite easily.
Make sure you get a relief valve for it too. Shocked
A compressed air tank is potentially a bomb when there is no reliable safety valve fitted.
You could go mental and ensure it's hydro-statically tested for good measure. Very Happy
MCN
PostPosted: 23:22 - 03 Sep 2015    Post subject: Reply with quote
Vincent wrote:
Will it blow my tyres up? Very Happy
Not sure if you needed a reply.
Probably will. Very Happy
MCN
PostPosted: 01:23 - 04 Sep 2015    Post subject: Reply with quote
Vincent wrote:
It must be good for something...and my trailer tyre is flat and the 12v compressor won't reach. It's got a female screw connecter that presumedly screws onto an airbrush, can you get tyre adapters for them? Does that female end have a title/name? Looks about 1/4" ID.
Probably 1/8" NPT or BSP.
1/8" relates to the inside diameter of the fitting/hose.
For low pressure BSP and NPT can be bastarded into each other with some thread tape. Smile
You'd need to look for the alternative metric size.
https://www.google.co.uk/aclk?sa=l&ai=CGKiOkeToVcWdOIeabrmykbgD9cbVjQel1-u-uQGtp9u7_wMICRACIN7Nzx4oD2C7hoCA3AqgAfu0kvYDyAEHqQIuDfoVHZe5PqoEJk_QxLrZRLiw-bp4oWvztEltTaXAOksAD5C4k7uQ9t1DS-F6DL2ZwAUFoAYmgAftyu0JkAcBqAemvhvYBwHgErP38LDZ8O3COA&sig=AOD64_0DS05eCiVe6krXea-J9cRwtxrnZA&adurl=https://clickserve.dartsearch.net/link/click%3Flid%3D92700007390061335%26ds_s_kwgid%3D58700000537106533%26ds_e_adid%3D49754061285%26ds_e_product_group_id%3D137295745965%26ds_e_product_id%3D000310218%26ds_e_product_merchant_id%3D4992679%26ds_e_product_country%3DGB%26ds_e_product_language%3Den%26ds_e_product_channel%3Donline%26ds_e_product_store_id%3D%26ds_e_ad_type%3Dpla%26ds_s_inventory_feed_id%3D97700000001443537%26ds_url_v%3D2%26ds_dest_url%3Dhttps://www.machinemart.co.uk/shop/product/details/clarke-30d-airline-tyre-inflator-with-pressure%253Fda%253D1%2526TC%253DGS-000310218&ctype=5&clui=9&rct=j&q=&ved=0CB4QpytqFQoTCNf4y82O3McCFUi2Ggod630IOA&ei=keToVZfsNcjsauv7ocAD
You need to look for a 'Tyre Inflater'.
Chingchong from some cnut on Ebay would be my guess
PostPosted: 22:23 - 04 Sep 2015    Post subject: Reply with quote
While pressure wise it might, suspect the flow is tiny compared to a normal garage compressor. That one is 23L/min which works out at 0.8cfm. For comparison my little garage compressor is 7cfm.
K
Just_James
PostPosted: 22:59 - 04 Sep 2015    Post subject: Reply with quote
It's worth picking up a cheap brush for £10 or so and having a play Thumbs Up
I've rather minimum experience with one myself, mostly from doing interior repairs on cars but it's a handy tool to have for little touch up jobs and such, you'll be surprised how much control you have over where you want paint to go.
I'm sure that little comp' will be fine for most of the stuff you might want to use it for (assuming you're not looking to start doing custom airbrush jobs Laughing )
Current Bikes / Projects: 1999 Rieju RS1 50
Previous bikes - 1986 DT125R (field bike), 1989 KX250, 1980 KX420 (with 500cc big bore), 1992 YZ250, 1988 KX500, 1989 XR250R, 1988 VFR400R NC24, 1999 Cagiva Mito 125, 2008 Rieju RS2 50 , 1993 Honda NSR 125
The last post was made 10 years, 348 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 76.21 Kb
