Sinnis vista no spark
Jem1969
PostPosted: 12:16 - 05 Sep 2015    Post subject: Sinnis vista no spark Reply with quote
Hi all- have a sinnis vista - great bike until it cut out, now I can't get a spark
Changed coil - CID and regulator, tested plug but still nothing?
Hi sinnis vista owner
PostPosted: 13:19 - 05 Sep 2015    Post subject: Re: Sinnis vista no spark Reply with quote
Before anything else, what position is your killswitch in?
Why?
Do you have a multimeter? You can get one for £5 and it's a lot, lot cheaper than replacing parts and hoping for the best.
Things to check with it:
Fuse(s).
Main earth point.
Side stand cut-out switch.
Kill switch.
Jem1969
PostPosted: 16:55 - 05 Sep 2015    Post subject: Re: Sinnis vista no spark Reply with quote
Why?
Fuse(s).
Main earth point.
Kill switch.
Thanks, what voltage should be coming from stator?
PostPosted: 20:13 - 05 Sep 2015    Post subject: Reply with quote
Anywhere between 15 and a billion.
This is a decent guide if you want to go delving.
https://www.bikechatforums.com/viewtopic.php?t=295684
However, I'd urge you to rule out the basics. If you have a charged battery that's spinning the engine strongly, you should get a spark regardless of what the stator is producing.
The last post was made 10 years, 345 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 40.6 Kb
