| steve09 |
 steve09 Scooby Slapper
 Posted: 20:32 - 07 Feb 2005 Post subject: Help af1 (kickstart :-) ) |
ok well i just couldnt reisit temptaion,, i live out in country on a almost private road and i just had to ride bike up and down hehe.everyone elses had a go but me,
it bumped and run nicely, i noticed in first from about 4k-6 it dosent seem to pull at all and almost splutter but i surpose it was kinda cold,
2nd gear rules
any way after my ride i stop bike and the side stand broke lol one of the bolts snapped then i try to start it on button and nothing really happened so i tryed to bump it and it sounds like its just running in gear its not reving, faster u push it more it revs thats about it lol,
soo ive taken carb off sorta, all but the choke cable as the screw is really in there, i was gonna clean carb but i dont really know what i got to do so i thought id ask,, also battery is near enuff flat could this be why its not starting when i try to bump it?,
also,,, i cant for the life of me get the fuel gauge to work,, the 3 wires on back of tanks what order do they go in lol i can get it too go right up and right down but not indicate how much fuel is in there,
cheers
steve
| Scotsman37 |
 Scotsman37 World Chat Champion
 Posted: 21:03 - 07 Feb 2005 Post subject: |
You need to improve your grammar & spelling  |
| steve09 |
 Posted: 21:14 - 07 Feb 2005 Post subject: |
sorry ill edit it,
the spelling is down to my dislexia if i type to fast and not think about what im writeing i make mistakes, no excuse for gramma though,
cheers
steve |
| M1ke |
 M1ke Ped Boi
| steve09 |
| M1ke |
 M1ke Ped Boi
| Kickstart |
 Kickstart The Oracle
 Posted: 23:22 - 07 Feb 2005 Post subject: |
There is no side stand cut out switch on these normally.
The ignition system is seperate from the charging system and battery and it should not care as long as the battery has enough power to turn it over quickly enough, and certainly not when bumping it.
For the carb take the float bowl off the bottom (14mm spanner required) and clean it out. Use carb cleaner to clean all the jets out. If it has been sat for ages then there is a rubber O ring around one jet that might be perished (on the choke circuit I think) so that might need replacing. There is a filter under the banjo shaped piece where the fuel pipe connects.
However it is a pig to get fuel into the fuel pipe . From the fuel tap the pipe goes up and over the carb, and gets air bubbles in there (obvious if you replace the fuel hose with clear stuff). Takes a fair amount of wiggling to sort this out (disconnect the fuel tap from the frame so that you can hold it higher than the carb). Otherwise you land up with a tiny bit of fuel in the carb (this might well be your problem).
the fuel gauge just uses a float to lift a contact along a variable resistor. It will only work with the tank the right way up. From memory it is the orange wire to the front, grey to the back and the blue in the middle (this is what it is on the early AF1, cannot remember for certain with the Sintesi).
| steve09 |
| Scotsman37 |
| Kickstart |
 Posted: 22:30 - 08 Feb 2005 Post subject: |
The orange wire from the coil connects to a red and white wire in the loom. This is for the kill switch, so ensure this is not earthing out anywhere (the kill switch / ignition switch works by earthing this wire).
Also check that the kill switch is not flicked off. Very easy to do on this switchgear.
There are no fuses on the ignition system. Indeed there are only a few wires (the already mentioned one, plus a red, a green and a black wire) from the stator to the coil. The only other wires from the stator are the yellow (or blue) wires to the regulator / rectifier and these have nothing to do with the ignition system.
If it is not cranking over then check the relay. It is a small alloy box on the front n/s frame rail, just near the horn. Has 2 large wires and 2 small wires, all connecting with spade connectors.
If does sound like your HT lead is dodgy. Either get a new piece (it is cheap and most bike mechanics should have some) or trim 5mm off each end (the bits at the end break up so it no longer makes decent contact). The lead screws into the cap and the coil.
The thick hose is just the gearbox breather. Think it is meant to go into a small hole just over the rear sprocket.
| steve09 |
| Scotsman37 |
 Posted: 22:43 - 08 Feb 2005 Post subject: |
There is such a thing as a fuse for the ignition and so have another look at Haynes' electrical diagram if you don't beleive me!  |
| Kickstart |
| Scotsman37 |
| Kickstart |
 Posted: 10:43 - 09 Feb 2005 Post subject: |
That looks like the wiring diagram for the 50, while Steve has a 1988 model AF1 125 Sintesi (the one with the pneumatic power valve). The giveaway is the single wire from the alternator to the regulator / rectifier unit.
Only those with the later ignition system (and thus the Rotax 122 engine) will have a fuse in the ignition system, while the early RS125 and all the alloy frames AF1 125s used the Rotax 123 engine with SEM ignition, on which the stator connects directly to the coil (no seperate CDI unit). The original 1987 model AF1 (steel framed) used the Rotax 127 engine which also used a version of the SEM ignition system (but with fixed ignition timing, where the later ones had some advance / retard dependent on revs). There seems to be no definate switch over from the 123 engine to the 122 engine on the RS, almost as though they phased the new engine in over a few years from about 1996 to about 1999.
| steve09 |
 Posted: 18:45 - 09 Feb 2005 Post subject: |
lol ok ne 2stroke experts live in or near ashford kent n wana come down my house and fix this sodding bike for me
i got spark but i dont think the carb is set up probaly after i rebuilt it i followed manul and wht not but when i open one screw its ethier open and pissing out petrol or closed u know not sure if thts right screw hehe,,
best i got all night was it to fire up for 5secs then died,
sometimes it sounds like im not gettin a spark but now i dont kniw and me arms kill from running it up and down road all night lol.
i was gonna charge battery today but got soo angry just walked away,
any one got any more ideas or can type me a simple plain of things to check,,
cheers
steve |
| Kickstart |
 Posted: 00:01 - 10 Feb 2005 Post subject: |
Afraid I am miles away, getting on for 200 of them!
There are only 2 real adjustments on the outside of the carb. The idle speed (just get it running and set that to your preference) and the air screw which should be one turn out.
The large bolt on the bottom hold the main jet, and should be tightened up fully.
The bolt holding the banjo on for the fuel pipe should also be tightened up fully.
Get a spare car battery and use some jump leads which should save you bump starting it. Just be careful with the jump leads.
| steve09 |
| Kickstart |
 Posted: 00:02 - 13 Feb 2005 Post subject: |
If you have a dodgy spark plug then this will cause major problems. Sometimes you can check a plug and see a spark, but due to an internal short it is sparking between the outer electrode / body of the plug to the engine. Of course once bolted into the head this means that there is no gap for it to spark over.
I really hope the coil is fine. Check the numbers on it. Should be 101.815.xx (cannot remember the xx bit) and the wires from the stator to the regulator / rectifier should be light blue. If there is that number on the coil but yellow wires to the regulator / rectifier then it will have problems (have tried this by mistake though, and they just seem to not rev beyond 6000rpm).
The HT lead and cap can be cheaply replaced. If you are unsure about them then just replace them.
The tube up from the gearbox filler should not go to the carb as it is a breather hose. On most it just goes to above the front sprocket (so at least when you overfill the gearbox with oil the excess goes onto the chain). I would not worry about these pipes much, as they are not really essential for the engine to run properly.
This might help you:-
https://www.bikechatforums.com/viewtopic.php?t=17124
Third picture down you can see the idle air screw (to the far left of the left hand carb, looks to be brass). This is for adjusting the mixture at very small throttle openings, and is the one that is specified in the owners handbook to be 1 turn out. The more turns this is open the leaner the mixture will be (some carbs have mixture screws which work the opposite way). It is possible that someone has fitted a carb off another bike though, as the PHBH carb is used on loads of 125s (including the NSR and the Mito).
The idle speed adjuster you just have to adjust while the engine is running really. No real setting of "one turn out" or anything like that.
| steve09 |
| Kickstart |
 Posted: 23:55 - 17 Feb 2005 Post subject: |
Probably worth checking the oil pump settings. Also check that you are not using gearbox oil. If you have got the carb about right it tends to suggest that the problem may not just be jetting, so oil (either excess 2 stroke, or gearbox oil from a leaking main bearing seal) is possible. Given that you left the engine for a bit them it is also possible that the float needle is sticking and allowing petrol to drain into the engine when parked.
2 stroke plugs do not normally last that long, and leaving them idling does tend to kill them, but I would expect them to survive being idled long enough to set it up.
Also it might be worth draining the crankcase just in case there is loads of fuel floating around in there. There is a bolt under the engine just in front of the starter motor. This is used for setting the ignition timing, but also does a good job of doubling as a drain for the crankcase.
| steve09 |
 Posted: 15:56 - 19 Feb 2005 Post subject: |
hiya,
brougth new plug put it in and it started,, bike shop told me not to let it idle so i drove it round and round the block till it got up to temptrue then itinkered about with carb, it will run with the choke leaver pushed up even though it says choke is down u pull it down and it dies, then all of a suddern it stoped dead, not ceased just sparkplug gone again ,bike shop said the reason it plug coulda been covered in oil was cos i kept cranking it over,, this time it was black so its been runnin rich?,cant see while it just keeps killing plugs, theres not a special way of putting them in or anything you have to do to prepare them is there?
cheers
steve |
| mchaggis |
 mchaggis World Chat Champion
 Posted: 23:49 - 19 Feb 2005 Post subject: |
If it's running too rich, I'd check your air filter and give it a good clean/ replace it, before starting to fiddle with the carburettor. ____________________ I must not be a troll...
Mmmm, Guinness
Discovering the delights of Hammerite and a 3/4" brush.  |
| Kickstart |
 Posted: 00:39 - 20 Feb 2005 Post subject: |
Choke lever is by the clutch lever. Pull it towards you for the choke to be on. It has a small sprung ball bearing to hold it open (think it has 2 open positions). However the way you describe the choke (up / down) tends suggest that you do not have the standard choke lever. It should be parallel to the clutch lever, sharing the same pivot, while what you describle sounds more like the NSR / RS / Mito choke lever which rotates around the handlebar.
This operates a cable that goes down to the carb and lifts a pluger in the carb.
Make sure you are operating it the right way, and also that the plunger is operating smoothly.
The plug should be a B10EG. Such cold plugs are prone to fouling if used round town alot, but not as bad as you are experiencing.
Make sure the mixture screw is one turn out.
Clean the plug up with a blow torch!
| steve09 |
The last post was made 21 years, 271 days ago. Instead of replying here, would creating a new thread be more useful? |
