Motorbike 'dolly'.
Ed Case
PostPosted: 23:47 - 09 Sep 2015    Post subject: Motorbike 'dolly'. Reply with quote
For moving a bike around in a restricted space when the only stand on the machine is a sidestand, I'm thinking of getting a 'dolly' off ebay (371348409590) for fifty-odd quid. Anyone got one/thoughts/criticisms, are they shite or worth having ?.
MCN
PostPosted: 01:06 - 10 Sep 2015    Post subject: Reply with quote
Cheap and Cheerless. Smile
I have two devices for moving my bikes.
One from Hein Gerike that's like a flat plate with four lockable castors. It fits under the centre stand and let me effortlessly 'glide' a BMW K1300 around in my garage. Or swish it close to the wall.
The other device is my Abba Stand. But that pins into the swing arm pivot and then you lift the bike up using an 'over-centre' principle.
Both are good.
The limitations of both is where my floor is not completely smooth Embarassed (I poured the floor myself)
On the smooth parts they work fine but on rough surfaces they make me curse like a priest.
The device you're looking at seems reasonable for the £££
Chuffin Nora
PostPosted: 05:51 - 10 Sep 2015    Post subject: Reply with quote
MCN wrote:
and lets me effortlessly 'glide' a BMW K1300 around in my garage.
Shocked Mate! --- 'a' BMW K1300!
As though an unattended baby in a pushchair outside a shop, that reads like you one day 'found' a BMW K1300 just sitting around somewhere and decided that it would be far happier making a rather nice addition to your garage! Shifty
Oh, my!
There's a fine line between integrity
MCN
PostPosted: 10:25 - 10 Sep 2015    Post subject: Reply with quote
Oh, my!
WTF R U on about M8? Confused
UncleFester
PostPosted: 10:50 - 10 Sep 2015    Post subject: Reply with quote
https://www.machinemart.co.uk/shop/product/details/clarke-mcd1-motorcycle-dolly
I have one of these, you need a level floor .... but it's simplicity to use and lets me fit the bike flush up against the back wall of a single garage so i can still get a car in.
I wouldn't want to try that by hand with 200kg of bike.
2017 Z1000SX
PostPosted: 10:54 - 10 Sep 2015    Post subject: Reply with quote
I used a Motorbike Dolly once.
https://scontent-lhr3-1.xx.fbcdn.net/hphotos-xpf1/v/t1.0-9/1923954_23938123475_5538_n.jpg?oh=c29f314db4e4404db0abcea5a83c958a&oe=56A103A7
MCN
PostPosted: 11:43 - 10 Sep 2015    Post subject: Reply with quote
chris-red wrote:
You let her on the back nekid?
Where is her PPE you fool? Mad
Very Happy
supZ
PostPosted: 12:10 - 10 Sep 2015    Post subject: Reply with quote
I've been looking for something like this too.
Moving house and I'm not sure my garage is wide enough to turn the bike round easily so want a dolly or something I can ride onto to swing the back end round.
Been looking at some cheap discs, low friction, caster driven etc.. nothing has really jumped out at me.
The ABBA sky lift looks fantastic but a bit pricey, especially as I already have an ABBA stand.
A cheap dolly/mover will probably do me fine
CBR954RR - Daily toy
CBR600RR - Trackbike
t121anf
PostPosted: 12:44 - 10 Sep 2015    Post subject: Reply with quote
Anyone got any tips for getting a smooth garage floor?
Mines ok, however it seems to be part old path and part concrete laid when the extension was build, the join isn't great and the path part is bumpy like you'd expect from a path.
MCN
PostPosted: 13:49 - 10 Sep 2015    Post subject: Reply with quote
Shall I PM U?
I researched and plotted my own floor until I found a very practical remedy.
But it ain't cheap no matter how you cut or dice it.
You have to 'tank' the floor. Very simple and effective.
Then you pour a 'self levelling' cementitious compound over the 'tanked' surface.
You will need a few tools to do it.
A heavy duty mixer. (SSD drilling machine from B&Q £65). I blew the arse out of my Black & Decker mixing the compound. Mixing these materials requires a slow speed to prevent adding in too many air bubbles. The compound will set before all the air gets out and leave the floor porous. Running an electric motor at slow speed and high torque is a problem as the motor can't cool. It relies on the motor speed to drive the cooling fan. So the motor can overheat. I needed six batches (20kg bags) for my floor and my machine failed on batch 5.5 Embarassed
And a spiked roller for the compound makes it dead easier.
I would recommend a pair of spiked shoes too. (Not your wife's golf brogues, she'd murder you if she found out)
You need a 24" roller to spread the tanking compound. You could struggle with a 12" though.
It will take you about a day to do it at a very efficient push. But if you are doing it for the first time then budget for two days. (plus the time to empty the garage.)
I painted the floor after and it look Mega.
I have just finished putting up Insulated Drywall last week. Cnut of a job but the garage now looks like a proper Bike Shed.
This task is not cheap.
You may even consider a 2" pour of fresh concrete But you would still have to tank the old floor.
I think it cost me about £350 for tools and materials.
But the finish is superb. Where the 0.5 batch was poured it went 'off' before completely level and there were a few high spots. I thought I could grind them down with my angle grinder. Shocked Hard as a Hoowur's heart that stuff. It took ages.
Ed Case
PostPosted: 15:23 - 10 Sep 2015    Post subject: Reply with quote
Yes supZ, I've got an ER6F and my garage is 'uphill' from the road and trying to 'walk' it down backwards has got a bit scary at times and mauling the bike the bike around to face downhill is a pain in the arse and everywhere else as well. I've dropped the bugger once and just about got away with it, doubt I'd be so lucky next time. One of these things is a damn sight cheaper than fairing panels.
kramdra This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
PostPosted: 19:54 - 10 Sep 2015    Post subject: Reply with quote
I've got one of these:
https://zonneveldproducts.mamutweb.com/Resource/File/0/mm_rerawheel.jpg
Brilliant Thumbs Up Thumbs Up
Ed Case
PostPosted: 22:07 - 10 Sep 2015    Post subject: Reply with quote
Pete. wrote:
Any idea how that would work with an ER6F with the zorst under the motor and obviously a full fairing ?.
PostPosted: 05:58 - 11 Sep 2015    Post subject: Reply with quote
Perfectly...
supZ
PostPosted: 12:52 - 11 Sep 2015    Post subject: Reply with quote
Pete. wrote:
where did you get it from?
can't seem to find any information about it, no website no nothing Confused
Ed Case
PostPosted: 15:33 - 11 Sep 2015    Post subject: Reply with quote
Pete. wrote:
Perfectly...
Just how zit work, where'd j'get it, and how much ?.
PostPosted: 17:29 - 11 Sep 2015    Post subject: Reply with quote
Good question. I got mine gifted to me so never bothered to check. Looks like they are 240 euros here:
https://zonneveldproducts.mamutweb.com/Shop/List/Motor-Movers/218/1
But there's a UK website touting them for £100, though it does look like an old web page here:
https://www.richandcath.co.uk/bikes/garage.htm
MCN This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
supZ
PostPosted: 21:11 - 11 Sep 2015    Post subject: Reply with quote
Yeh looks like that guy got his from MandP (found that site myself whilst furiously googling Smile) but they don't do it any more.
Shame, looks like a nice bit of kit.
The key with this is something simple that you can just roll over/clip into and off you go. No point fiddling around with stands, etc..
Expensive for 'a bit of plastic' but even this thing looks like it would suffice for me
https://www.mandp.co.uk/index.php/default/360-degree-bike-glide-buddy.html
Ed Case
PostPosted: 22:42 - 11 Sep 2015    Post subject: Reply with quote
Looks a good bit of kit but b'jasus a bit pricey by comparison 200+euros.
PostPosted: 22:57 - 11 Sep 2015    Post subject: Reply with quote
Make one. Take something like this and weld on two side-plates and a dish for the wheel to sit in:
https://r.ebay.com/vqE7V7
The last post was made 10 years, 363 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.31 - MySQL Queries: 13 - Page Size: 124.02 Kb
