No fuel to plug :(
mattfender666
PostPosted: 19:09 - 13 Sep 2015    Post subject: No fuel to plug :( Reply with quote
Evening all,
Was wondering if I could pick your brains, my friends Pulse Lightspeed 125 has no fuel getting to cylinder, carb fills up as I can empty float bowl from screw underneath, havent tried a bit of fuel down plug hole yet as its typical cornish weather again!!
Ive removed the carb and cleaned jets and passages out but noticed when assembled and ful,l no fuel squirts out of intake hole when throttle opened? Anyone got any advice??
Cheers, Matt
KH100>CG125>SR125>GPZ500S>XV535>XJ600N>GSX600F
RhynoCZ
PostPosted: 19:18 - 13 Sep 2015    Post subject: Reply with quote
Valves? Thinking
mentalboy
PostPosted: 19:39 - 13 Sep 2015    Post subject: Re: No fuel to plug :( Reply with quote
How the heck do you manage see into the intake when the throttle is opened to determine fuel movement???
New fuel in the tank or skanky old stuff?
mattfender666
PostPosted: 19:44 - 13 Sep 2015    Post subject: Reply with quote
RhynoCZ wrote:
Valves? Thinking
Both 0.08mm
mattfender666
PostPosted: 19:46 - 13 Sep 2015    Post subject: Re: No fuel to plug :( Reply with quote
I meant on the bench, no fuel coming out of carb when throttle opened.
Fresh fuel yesterday, entire fuel system flushed
mattfender666
PostPosted: 19:47 - 13 Sep 2015    Post subject: Reply with quote
Just whacked some fuel down the plug hole, still no fire, tried 3 times still no luck, guessing weak spark then??
mentalboy
PostPosted: 19:57 - 13 Sep 2015    Post subject: Reply with quote
Unlikely, you've probably just flooded it.
Just opening the throttle whilst the carb body is on the bench is not going to result in fuel flow unless you've got a very swanky vacuum set-up on the bench which creates a venturi effect? If you have I'd love to see the pics!!
Have you checked the spark? (undo plug, reconnect it to HT lead, ground plug to engine - keep body parts clear - then crank engine, observe spark colour, report back Smile
mattfender666
PostPosted: 01:01 - 15 Sep 2015    Post subject: Reply with quote
Success to a degree, ignition coil defective ordered a new one as spark faint blue
The last post was made 10 years, 358 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 57.35 Kb
