| andym |
 andym World Chat Champion
| MCN. |
 MCN. Banned
| Rogerborg |
 Rogerborg nimbA
 Posted: 08:32 - 15 Sep 2015 Post subject: |
The active chemical removed from Nitromors is dichloromethane.
https://www.youtube.com/watch?v=B58GSXZg-d4
eBay can provide. You'll die, every kitten within 10 miles will explode, etc. ____________________ Biking is 1/20th as dangerous as horse riding.
| stinkwheel |
 Posted: 17:56 - 15 Sep 2015 Post subject: |
Paramose.
Basically old-school nitromorse. Slap it on, make a cup of tea, hose it and the paint off.
Only supplied for commercial use... in 5litre cans on ebay. You need to send a letter confirming it's for commercial use before they'll dispatch.
We have a can at work for "ahem" cleaning grafitti off the the building. Absolutely not for stripping the paint off my motorcycle parts. No sir. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| MCN |
 MCN Super Spammer
 Posted: 18:09 - 15 Sep 2015 Post subject: |
Be careful with the contact time not an issue on steel but the caustic solution will etch aluminmiminmum (not sure if Mag Alloy will also suffer).
Any marks 'you add' would need to be rubbed out that's all.
Gloves and Glasses and long sleeves and wash hands thoroughly BEFORE going to the toilet.
It will loosen one layer at a time normally. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| cyberglass |
 cyberglass World Chat Champion
| MCN |
 MCN Super Spammer
 Posted: 19:04 - 15 Sep 2015 Post subject: |
| cyberglass |
 Posted: 19:12 - 15 Sep 2015 Post subject: |
hahaha ok i wont be ordering and doing this then  ____________________ DL650 Vstrom 2004
DRZ400S 2003
Yamaha R1 2005 |
| stinkwheel |
 Posted: 21:36 - 15 Sep 2015 Post subject: |
Remember the correct gloves.
I wear nitrile for the duration of the job then put on a pair of those big blue PU dipped ones when I'm actually handling the stuff.
Latex does nothing. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| andym |
| stinkwheel |
| MarJay |
 MarJay But it's British!
 Posted: 10:46 - 16 Sep 2015 Post subject: |
my GF is an industrial chemist, and she blames the EU. The EU removes all of the interesting chemicals from everything.  ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
Remember kids, bikes aren't like lego. You can't easily take a part from one bike and then fit it to another. |
| wr6133 |
 wr6133 World Chat Champion
| weasley |
 weasley World Chat Champion
| MCN |
 MCN Super Spammer
 Posted: 11:44 - 16 Sep 2015 Post subject: |
| deeds |
 deeds Nova Slayer
| Jewlio Iglesias |
 Jewlio Iglesias Banned
 Posted: 19:15 - 16 Sep 2015 Post subject: |
Is that just by using it, or does it work better if you put it in some food for them? ____________________ 21:41:40 petalbriefs: look phil, I dont preach to you about bowling pins or whatever, so you stick to that and I'll stick to cars
21:38:18 Northern Monkey: chav lives in the garage with an almax on it
21:34:54 rhys99: My train got stuck in heavy traffic |
| MCN |
 MCN Super Spammer
| Rogerborg |
 Rogerborg nimbA
 Posted: 21:42 - 16 Sep 2015 Post subject: |
| Suntan Sid |
 Suntan Sid World Chat Champion
 Posted: 21:46 - 04 Nov 2015 Post subject: |
I wanted to remove some paint from some engine covers today.
Not wanting to spend hours with wet 'n dry, slowly removing the ends of my fingers, I decided to give some paint stripper a go.
I had some left from when I had used it previously, it hadn't worked very well and had left a lot of paint behind!
This was "Diall" brand "Paint and Varnish Remover".
I'm not going to say where I got this stuff, because, AFAIC, they're a bunch of robbing bastards!
Anyway I put each casing in a washing up bowl and covered both of them in a, thick, layer of goop. As per the instructions, I waited an hour and recoated both parts with another, thick, layer of goop.
I left the parts for another hour then took a toothbrush to them, as per the instructions, and, believe it or not it actually worked.
I followed the exact same process last May, and, as I said 50% of the paint was still there, this time 99% of the paint had gone.
The only noticeable difference betwen the two processes, AFAICS, is that today it was wet and miserable outside. The parts were outside all the time but under cover, the paint stripper didn't dry out, at all, today.
Previously, in warmer weather, leaving an hour between coats, the goop had started to dry.
If I need to do this again, in warmer weather, I will be covering the items with a carrier bag during the process and making sure they're in total shade! I assume, today, that the active chemicals did not, simply, evaporate, like they must have done previously!
HTH ____________________ "Everybody needs money, that's why they call it money!"  |
| andym |
| Vincent |
 Vincent Banned
 Posted: 12:54 - 05 Nov 2015 Post subject: |
It's what they look like after a few months that matters
I want my own blaster but every spare penny is going on the '70s bike money pit  ____________________ Space Is Deep |
| stinkwheel |
| andym |
| Snodvan |
 Snodvan Spanner Monkey
 Posted: 20:48 - 05 Nov 2015 Post subject: |
This stuff
https://www.screwfix.com/p/no-nonsense-paint-varnish-stripper-500ml/17091?cm_sp=Search-_-SearchRec-_-Area1&_requestid=241862#_=p
seems like it is the same that Sid describes (B&Q and Screwfix are of course "related"). I bought some today to remove ancient varnish off half a dozen solid brass door handles
QUITE IMPRESSED. Especially for a £5 relative to £41 for 4 litres of Nitromoors. The 1/2 litre size for the Screwfix gloop is also more practical. I spread the stuff over the handles, wrapped it all in ally foil and left it for a couple of hours. Opened up the foil and applied some more for an hour and ------ nice clean handles when I scrubbed all the gloop off. Needed a bit of Brillo pad to get a few final crusty bits off, but generally happy.
Snod ____________________ 04 (UK Reg) BMW F650cs, but really 02 first Reg in Holland |
The last post was made 10 years, 225 days ago. Instead of replying here, would creating a new thread be more useful? |
