| tatt0owarrior |
 tatt0owarrior Borekit Bruiser
| Andy_Pagin |
 Andy_Pagin World Chat Champion
| Rogerborg |
 Rogerborg nimbA
 Posted: 11:57 - 16 Sep 2015 Post subject: |
They won't be wide enough to hide the L plates.
How much are you planning to sink into your tiddler instead of spending it on getting a license to ride that bike that you actually want?
With hindsight, you'll realise that this comment is actually helpful. I wish it had been said to me more forcibly. ____________________ Biking is 1/20th as dangerous as horse riding.
| tatt0owarrior |
| orac |
 orac World Chat Champion
| el_oso |
 el_oso World Chat Champion
| tatt0owarrior |
| P.addy |
 P.addy Red Rocket
| Rogerborg |
 Rogerborg nimbA
 Posted: 14:55 - 16 Sep 2015 Post subject: |
Trying to stay constructive (Paddy, you so rageface) possibly the least meddlesome thing you could do to personalise it would be white wall tyre paint.
Or spokey-dokeys. ____________________ Biking is 1/20th as dangerous as horse riding.
| P.addy |
 P.addy Red Rocket
 Posted: 15:11 - 16 Sep 2015 Post subject: |
Yes... I am rather iffy recently. Its the sperg-cruiser sons of anal postings tbh  |
| tatt0owarrior |
 Posted: 16:20 - 16 Sep 2015 Post subject: |
| P.addy |
 P.addy Red Rocket
| tatt0owarrior |
 Posted: 16:44 - 16 Sep 2015 Post subject: |
Haters always gonna hate  |
| nowhere.elysium |
 nowhere.elysium The Pork Lord
| orac |
| P.addy |
 P.addy Red Rocket
| Ste |
 Ste Not Work Safe
| Northern Monkey |
 Northern Monkey World Chat Champion
| tatt0owarrior |
| Rogerborg |
 Rogerborg nimbA
 Posted: 18:26 - 16 Sep 2015 Post subject: |
That's a pretty thorough job so far.
Round headlight, lose the instruments in favour of a single speedo, sprung seat.
It'll still all be money down the drain, but that should at least make it easier to sell on when you come to your senses. ____________________ Biking is 1/20th as dangerous as horse riding.
| stinkwheel |
 Posted: 19:04 - 16 Sep 2015 Post subject: |
There's a limit to how wide your tyres will go.
Hardtail 125 with standard rear tyre is going to kill your back. I normally disagree with people wanting wider tyres but in this case you need a bigger rear tyre with less pressure in it. Biggest you can fit. Front looks OK to me.
As far as I can see your chain clearance is the limiting factor on width here. The mudguard strut is the limiting factor on profile. The latter can be moved. The former cannot (easily).
So. See what tyre you have on already. They look like a metzeler 3.00x18. Nominally 3" wide with a 90% cross section (height is 90% of the width so 2.7 inches high.
Check the distance between your sidewall and the chain. Double that is the MAXIMUM width you could add to the current tyre width.
Next two readily available sizes up are 3.25 x 18 and 3.5 x 18
Old-school choppers used to use a 4" tyre but there is no way you'll fit one in there.
Looking at your picture, you're going to be lucky to even go up to a 3.25. That'll put the profile height up by 0.22" (5.6mm), might just fit with no modifications . A 3.50 would increase the profile by 0.45" (11.4mm) but I suspect you don't have that much chain clearance to play with.
The other consideration is if that'll fit on the wheel rim. I suspect you have a WM2 rim on the rear (1.85" wide) which normally takes between a 2.75 and 3.10 tyre. You can squeeze on up to a 3.60. No bigger. But that's moot because you'd almost certainly need to move the whole engine to the left and fabricate an outrigger sprocket carrier to fit anything wider than a 3.50.
So. No need for a wider wheel. It's pointless because a tyre to suit it wont physically fit in your bike, it would rub on the chain. You can probably go up to a 3.25x18 and still have it fit. You MIGHT be able to go up to a 3.50x18 but it'll be tight and you'll need to move the rear mudguard mount.
My personal suggestion. Get an Avon Safety Mileage 3.25 x 18 (or 3.50 if it'll fit in the gap, it just might due to their squareness, they tend to be on the narrow side compared to more conventional tyres). Fit it with a tube, run it at low pressure (low 20's of psi). They are an old fashioned tyre with a pretty much square cross section and heavy duty tread. This means they'll cope with being run soft. They have big sidewalls which are also multi-ply and have a fair degree of flex in them.
You have very limited ground clearance anyway. When you corner, the sidewalls will flex and the tread will remain on the road giving you a large contact patch and at least some suspension.
Look at pictures of early hardtail motorcycles, (google BSA M20) this is how they did it. Round profile front, soft and squidgy square profile rear.
You urgently need a front mudguard and a sprung saddle. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| stinkwheel |
 Posted: 19:07 - 16 Sep 2015 Post subject: |
On a styling front. If you're going to rock a square headlamp and cast wheels, I'd be looking at T-bars. You hardly see T-bars about these days. They were big in the late 70's/early 80's.  ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Rogerborg |
 Rogerborg nimbA
| tatt0owarrior |
| RhynoCZ |
 RhynoCZ Super Spammer
The last post was made 10 years, 362 days ago. Instead of replying here, would creating a new thread be more useful? |
