question on chain and sprockets.
Hammerstrike
PostPosted: 17:42 - 16 Sep 2015    Post subject: question on chain and sprockets. Reply with quote
Hello everyone.
Was away on work so wasnt on much lately.
A quick question on the chain and sprockets.
Chain was getting loose, I got it tightened. However it has got loose again, and it looks like it wont tighten any more, does it mean I need to get a new set? anyone know somewhere not very expensive to get it done in London or buckinghamshire?
I have a Hyosung Aquila 125 by the way!
Cheers guys
Hammerstrike
goto10
PostPosted: 17:47 - 16 Sep 2015    Post subject: Re: question on chain and sprockets. Reply with quote
Hammerstrike wrote:
Hello everyone.
Cheers guys
Sprockets might be ok, but it sounds like a new chain is definitely needed. Do you oil it regularly?
Over-tightening the chain can cause premature wear too.
MCN
PostPosted: 19:53 - 16 Sep 2015    Post subject: Reply with quote
If you are at the end of the adjustment then you need a new chain AND sprockets.
Mis-matching will accelerate wear in the new part you fit.
Are you sure the spindle bolt is tight enough?
Hammerstrike
PostPosted: 20:43 - 16 Sep 2015    Post subject: Reply with quote
I think it is full tight, but will get a pic and post it here!
Hammerstrike
Dave70
PostPosted: 21:04 - 16 Sep 2015    Post subject: Reply with quote
In my experience, I usually only have to change the sprockets every other chain.
But yeah, need pics of sprockets to be able to advise. Thumbs Up
MCN
PostPosted: 21:44 - 16 Sep 2015    Post subject: Reply with quote
Unusual but not unheard of.
How many miles do you get out of a chain?
Dave70
PostPosted: 21:56 - 16 Sep 2015    Post subject: Reply with quote
Hmm... Never really counted tbh but, thinking about it, probably averaging somewhere between 12-15,000 miles as a ballpark figure. Always use DID chain and sprockets.
MCN
PostPosted: 22:14 - 16 Sep 2015    Post subject: Reply with quote
My mechanic frowns at chain only/sprockets only. Smile
I put a new chain on my S1000RR due to a Scotoiler issue. Sprockets were fine but chain had two tight links.
He wasn't happy but when he saw the bike he said fair enough.
The problem is they both wear equally or near enough equally.
So it is as worth changing all at the same time. you shouldf be able to get over 26k on a chain and sprockets with no problem.
If you have a scotoiler (that works) you can easy get 36k
Have you ever changed all together?
Fuck it... This thread is almost derailed so I may as well waffle on now. Very Happy
I change tyres two at a time. I have always found when the rear is gone the front is not far behind. For the sake of the hassle I do both. I don't like my bike to be off the road.
Dave70
PostPosted: 22:24 - 16 Sep 2015    Post subject: Reply with quote
Last set were changed together and funnily enough I only gave them a good check over last week, as by normal standards they should be coming towards the end of their life but, the sprockets are showing little to no signs of wear and the chain has a fair bit left in it too. I have been cleaning it more frequently, as opposed to just lobbing more oil on though and I no longer use the dry chain lube because I came to the conclusion it wasn't as good.
PostPosted: 22:30 - 16 Sep 2015    Post subject: Reply with quote
What bike?
Dave70
PostPosted: 22:34 - 16 Sep 2015    Post subject: Reply with quote
R125. Mr. Green
Val
PostPosted: 12:06 - 17 Sep 2015    Post subject: Re: question on chain and sprockets. Reply with quote
Hammerstrike wrote:
Hello everyone.
Cheers guys
Read the service manual man Laughing
https://files.hyosungmotorsusa.com/GT125_250_Service_Manual.pdf
It says:
Count out 21 pins (20 pitches) on the chain and mea-
sure the distance between the two points. If the dis-
tance exceeds the service limit, the chain must be
replaced.
The Service limit lenght for your bike stated there is 265.5mm
If the chain has stretched longer its time to change the chain and the sprockets. The manual is clear when change the chain change the sporckets too. If you do not do that its false economy you are ruin new chain with old crappy sprockets. Less BCF wisdom more reading of the said manufacturer service manual.
Frankly if you can tighten a chain you should be able to change it yourself using the above manual. Given the fact you need riveting tools which will cost you some money and probably this will be only change on this bike you will do, its fine to find some garage to do that for you. It should cost around £60. Do not spalsh some money on fancy chains and sprockets. Its overkill for 125. Get decent and cheap chain and sprockets they will do perfect job given the fact your 125 has low power.
This one wil be more than enough:
https://www.ebay.co.uk/itm/Hyosung-GV125-C-Aquila-2009-2010-DID-Chain-Kit-Complete-Long-Life-Chain-428-/150926729630?hash=item2323ef219e
Also make sure the chain is not too tight the slack stated again in the above manual Very Happy is 20-30mm
I prefer to keep the top limit in your case 30mm. When you measure the slack sometimes (its ok) the chain has tighter spots. When you turn the wheel you measure the slack in the tightest spot ok? Its fine to have more slack on other spots. The slack is for the most tight spot on the chain.
Again manual, man up Laughing
Dave70
PostPosted: 12:25 - 17 Sep 2015    Post subject: Re: question on chain and sprockets. Reply with quote
Val wrote:
Do not spalsh some money on fancy DID chains and sprockets. Its overkill for 125. Get decent and cheap chain and sprockets they will do perfect job given the fact your 125 has low power.
Cheap chain and sprockets may well do the job on a 125. However, they will need replacing more frequently and the chain will need tightening more often. This has been my experience anyway.
Currently, my DID chain and sprockets are showing very little wear. A cheap set would need replacing at this point. Also, I've had to tighten my chain far less frequently. I prefer things this way. Pay more, last longer, less work.
Val
PostPosted: 12:54 - 17 Sep 2015    Post subject: Re: question on chain and sprockets. Reply with quote
I stand corrected and in fact removed the DID reference from my post.
Apparently for small bikes good DID chain kit is actually only £5 more expensive than cheap ones Very Happy
The last post was made 10 years, 357 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 91.59 Kb
