| Hammerstrike |
 Hammerstrike Derestricted Danger
| goto10 |
 goto10 World Chat Champion
| Beehive Bedlam |
 Beehive Bedlam World Chat Champion
| MCN |
 MCN Super Spammer
| Hammerstrike |
| Dave70 |
 Dave70 World Chat Champion
 Posted: 21:04 - 16 Sep 2015 Post subject: |
In my experience, I usually only have to change the sprockets every other chain.
But yeah, need pics of sprockets to be able to advise.  ____________________ There ain't no devil, there's just god when he's drunk.
2012: R125 killed by white van. 2016 R125 killed by 30,000 miles of redline. Current: 2016 Kawasaki ER6f. |
| MCN |
 MCN Super Spammer
| Dave70 |
| MCN |
 MCN Super Spammer
| Dave70 |
| Ste |
 Ste Not Work Safe
| Dave70 |
 Posted: 22:34 - 16 Sep 2015 Post subject: |
R125.  ____________________ There ain't no devil, there's just god when he's drunk.
| Val |
 Val World Chat Champion
 Posted: 12:06 - 17 Sep 2015 Post subject: Re: question on chain and sprockets. |
| Hammerstrike wrote: | Hello everyone.
Was away on work so wasnt on much lately.
A quick question on the chain and sprockets.
Chain was getting loose, I got it tightened. However it has got loose again, and it looks like it wont tighten any more, does it mean I need to get a new set? anyone know somewhere not very expensive to get it done in London or buckinghamshire?
I have a Hyosung Aquila 125 by the way!
Cheers guys |
Read the service manual man
https://files.hyosungmotorsusa.com/GT125_250_Service_Manual.pdf
It says:
| Quote: |
Count out 21 pins (20 pitches) on the chain and mea-
sure the distance between the two points. If the dis-
tance exceeds the service limit, the chain must be
replaced. |
The Service limit lenght for your bike stated there is 265.5mm
If the chain has stretched longer its time to change the chain and the sprockets. The manual is clear when change the chain change the sporckets too. If you do not do that its false economy you are ruin new chain with old crappy sprockets. Less BCF wisdom more reading of the said manufacturer service manual.
Frankly if you can tighten a chain you should be able to change it yourself using the above manual. Given the fact you need riveting tools which will cost you some money and probably this will be only change on this bike you will do, its fine to find some garage to do that for you. It should cost around £60. Do not spalsh some money on fancy chains and sprockets. Its overkill for 125. Get decent and cheap chain and sprockets they will do perfect job given the fact your 125 has low power.
This one wil be more than enough:
https://www.ebay.co.uk/itm/Hyosung-GV125-C-Aquila-2009-2010-DID-Chain-Kit-Complete-Long-Life-Chain-428-/150926729630?hash=item2323ef219e
Also make sure the chain is not too tight the slack stated again in the above manual is 20-30mm
I prefer to keep the top limit in your case 30mm. When you measure the slack sometimes (its ok) the chain has tighter spots. When you turn the wheel you measure the slack in the tightest spot ok? Its fine to have more slack on other spots. The slack is for the most tight spot on the chain.
Again manual, man up  ____________________ Adrian Monk: Unless I'm wrong, which, you know, I'm not...
Yamaha Fazer FZS 600, MT09, XSR 900 |
| Dave70 |
| Val |
 Posted: 12:54 - 17 Sep 2015 Post subject: Re: question on chain and sprockets. |
| Dave70 wrote: | | Val wrote: |
Do not spalsh some money on fancy DID chains and sprockets. Its overkill for 125. Get decent and cheap chain and sprockets they will do perfect job given the fact your 125 has low power. |
Cheap chain and sprockets may well do the job on a 125. However, they will need replacing more frequently and the chain will need tightening more often. This has been my experience anyway.
Currently, my DID chain and sprockets are showing very little wear. A cheap set would need replacing at this point. Also, I've had to tighten my chain far less frequently. I prefer things this way. Pay more, last longer, less work. |
I stand corrected and in fact removed the DID reference from my post.
Apparently for small bikes good DID chain kit is actually only £5 more expensive than cheap ones  ____________________ Adrian Monk: Unless I'm wrong, which, you know, I'm not...
The last post was made 10 years, 358 days ago. Instead of replying here, would creating a new thread be more useful? |
