Sticky Rear Drum Brake
jonpod
PostPosted: 14:51 - 22 Sep 2015    Post subject: Sticky Rear Drum Brake Reply with quote
Amateur, so bare with me.
Rear brake has started sticking a bit on the 2010 YBR125. I have adjusted the pedal with the screw at the back, and it doesn't seem to make a difference.
Even when the pedal is being pulled upwards, the rear seems to stick a bit.
Any ideas what it could be before I go and get milked by a mechanic at a garage?
Thanks!
Take 1: CBR125R > Theory Done > Expired
Take 2: YBR125 > Theory Done > DAS Passed
London Commuter
bikenut
PostPosted: 14:56 - 22 Sep 2015    Post subject: brakes Reply with quote
safety critical........
you have good tools and an area to work in??
Find your bike on cmsnl for the exploded views.....they will help you.
you have a manual??
but first, some maintenance spray on the brake rod ( connected to the foot pedal ) , and the smaller arm that goes onto a shaft that goes into the brake back plate, it may be stiff and need a service ( which it should have been getting form you, little and often on bikes dude ).
I wonder how the chain is??!
if it moves, lubricate it, apart from brake friction material that is.
don't forget to lub the brake pedal as well.
if still no joy, come back with some pictures. :karma:
nuts about bikes
bladeblaster
PostPosted: 16:28 - 22 Sep 2015    Post subject: Reply with quote
I did the brakes on my sons YBR125, the cause of the sticking back break was the brake actuator spindle being corroded into the hub.
Easy to solve, if you are competent enough to work on your own brakes.
Disconnect the operating mechanism from the actuator use a pair of mole grips, screwdriver, spanner, anything that works to turn the actuator so that the pads are fully disengaged. Remove rear wheel, remove hub, press out the actuator, might need a few good taps with a hammer if you don't have access to a fly press or similar. Clean up the actuator and the hole if fits into, grease, pop actuator back in, and reassemble.
About an hour long job if doing it at home, a decent mechanic in a workshop should be able to do it easily for an hours labour and no parts cost.
PostPosted: 21:24 - 22 Sep 2015    Post subject: Reply with quote
Undo the adjusting cam nut and release the rod from the trunion. Now try to move the lever on the brake hub by hand. If it is stiff you need to remove the wheel and strip out the pivot because it's probably seizing from corrosion and lack of lubrication.
If the lever moves smoothly but then sticks in one spot again strip off the hub and inspect the wear plates on the end of the brake shoes. They should be smooth but sometimes you get ridges worn in them and it makes the cam catch in the ridge and locks the brake on. The cure is either to file the plates to get rid of the ridge, or simply to switch the shoes over so that the cam now acts on a fresh bit of the shoe.
PostPosted: 13:31 - 23 Sep 2015    Post subject: Reply with quote
You might find this howto I wrote a few years back handy:
https://www.bikechatforums.com/viewtopic.php?t=174773
The last post was made 10 years, 353 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 49.57 Kb
