Hyosung GV125 loses power frequently
Paraggv125
PostPosted: 08:58 - 22 Sep 2015    Post subject: Hyosung GV125 loses power frequently Reply with quote
Hi All, just bought a Hyosung GV125 aquillia started riding and see that it loses power very frequently. The bike starts good with no problem. When it starts losing power it sounds as if it's going to go off that's when I have to go a bit easy on the throttle, and shift to a lower gear, but the power loss still continues. Infrequently it wakes up but then the power goes down again. What could the problem be.
Also to mention, the fuel tap has got jammed on RES, could it be something stuck in there stopping the fuel flow?
Missed to mention It is a 2007 make.
Born to Ride
smallfrowne
PostPosted: 09:50 - 22 Sep 2015    Post subject: Reply with quote
Very likely Very Happy I'd be draining the tank and whipping the tap off for a look.
'90 VFR750; '89 NC30; '95 DR650; '89 CD250U; ~'82 CG125; ~C90
RhynoCZ
PostPosted: 10:33 - 22 Sep 2015    Post subject: Re: Hyosung GV125 loses power frequently Reply with quote
It's time for you to find out, I guess. Smile
Paraggv125
PostPosted: 06:56 - 23 Sep 2015    Post subject: Re: Hyosung GV125 loses power frequently Reply with quote
Went back home and drained a bit of the fuel in a glass and well, could clearly see 2 layers of liquid. I guess it was water. That sort of explains why the bike won't run cause unfortunately the bike does not run on water. Have emptied the tank. There is a bit of rust in the tank, will try to shake it off as much as possible over the weekend, re-fuel it and give it a go.
Any tips?
Born to Ride
mudcow007
PostPosted: 08:32 - 23 Sep 2015    Post subject: Reply with quote
drain tank, replace with good fuel - try bike
might be worth checking how rusty the tank is inside too
also, rust an crap maybe blocking the filter (if there is any fitted)
RhynoCZ
PostPosted: 10:27 - 23 Sep 2015    Post subject: Reply with quote
I'd be taking off the carb bowl/s to clean them. The rust and slime balls of the water/petrol mixture might still be there. Randomly getting sucked into the jet and blocking it. Thumbs Up
The last post was made 10 years, 354 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.07 - MySQL Queries: 13 - Page Size: 48.29 Kb
