Did something stupid...
PostPosted: 13:30 - 25 Sep 2015    Post subject: Did something stupid... Reply with quote
My Trophy had a flat battery so charged it for half and hour and then tried starting it with the charger still connected and power on without thinking. It started OK but I now have an engine management warning light on. Evil or Very Mad
Everything seems to be working, bike is running fine. I presume I have fried some electrical gubbins somewhere.
I think this will have to be a trip to Triumph as I can't find any info on getting and reading codes.
Would trying to start with the charger connected do this or is it pure coincidence?
Triumph Trophy Launch Edition
sickpup
Old Timer
PostPosted: 13:42 - 25 Sep 2015    Post subject: Re: Did something stupid... Reply with quote
I reckon coincidence, a bike charger assuming it is one doesn't give out much power.
I suspect it has been caused by the flat battery so try turning the bike on and off half a dozen times quickly and see if it clears the fault, used to work on older Triumphs.
James83
PostPosted: 13:50 - 25 Sep 2015    Post subject: Reply with quote
Might want to check the fuses on your charger though. I blew one trying to start a bike with it still connected once.
Jonathan A wrote: tart.
Matt B
PostPosted: 14:38 - 25 Sep 2015    Post subject: Re: Did something stupid... Reply with quote
Seems that this is something Triumphs (Sprint, STripple etc.) do with flat batteries. Advice is turn it on/off 4 or 5 times, or it may clear after a ride.
davebike
PostPosted: 15:25 - 25 Sep 2015    Post subject: Reply with quote
Triumph system is OBD2 compliant like cars
Most cheap readers will give you the fault code and clear the light
Triumph do not like poor weak or discharged batteries
Give it a good charge Check the bike is charging And if you not certain get the battery tested
Dave
NC750Xdct + others at work !
[email protected]
Diggs
PostPosted: 16:07 - 25 Sep 2015    Post subject: Reply with quote
I wouldn't worry about starting a bike with a battery charger still connected. I have done this on numerous bikes over the years without a problem.
Being a Triumph I'd be more concerned about lack of spinny-power and the sprag clutch...
Now - Speed Triple, old ratty GS550, GSXR750M
Gone (in order of ownership) - Raleigh Runabout, AP50, KH125, GP125, KH250, CBX550, Z400, CB750FII, 250LC, GS550, ZXR750H1, Guzzi Targa, GSX750F, KH250 x2, Bimota SB6R and counting...
talkToTheHat
PostPosted: 14:23 - 26 Sep 2015    Post subject: Reply with quote
did that with a Hein Gericke charger, next time i used it, it was stuck in fast charge mode, telling me the charge voltage was about 8, multimeter said 22v. Oops.
Bandit. does. everything.
RhynoCZ
PostPosted: 14:52 - 26 Sep 2015    Post subject: Reply with quote
I thought the chargers had not enough Amps to power the starter motor. Thinking
andys675
PostPosted: 17:51 - 26 Sep 2015    Post subject: Reply with quote
bluetooth obd tool and a phone app, cost about £23 and you can clear fault codes and reset the service spanner, even on the later "locked" ecu models
ADSrox0r
PostPosted: 18:43 - 26 Sep 2015    Post subject: Reply with quote
Disconnect the battery and leave it a good ten minutes, should clear it. Failing that there's usually a way to kill the warnings, mine is just a matter of shorting out the diagnostic connector.
PostPosted: 19:23 - 26 Sep 2015    Post subject: Reply with quote
On my Triumph whenever the batter power is cut it would throw the EM light. I'd bet good money after 3 heat cycles it'll clear.
Heat cycle = Start engine and get it up to temp (for my Speed four it would mean waiting for the temp to change from 'Lo' to a number. Once this happens turn it off let it cool down again and do it again (and again).
Edit:- Do this before spending any money, I'm certain I'm right.
PostPosted: 15:39 - 27 Sep 2015    Post subject: Reply with quote
Andy,can you point me in the way of what I would require for this. Google throws up 10's of different ones of varying prices on Amazon alone so I'm not sure what I actually need. My cheap car reader won't 'talk' to the bike.
PostPosted: 15:58 - 27 Sep 2015    Post subject: Reply with quote
Thanks Chris, 3 cycles and the light went out. Thumbs Up
That's saved me a few quid Very Happy
andys675
PostPosted: 11:58 - 28 Sep 2015    Post subject: Reply with quote
app is called TuneECU on android
and one of these
https://www.ebay.co.uk/itm/NEW-OBD2-ELM327-V1-5-Bluetooth-Car-Scanner-Android-Torque-Auto-Scan-Tool-OBD-II-/331206015268?hash=item4d1d6ab924
sorry couldn't reply sooner, went for a big ride yesterday, was out for 12 hours Very Happy
The last post was made 10 years, 341 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 82.66 Kb
