NSR 125 JC22 Electrical Problem.[SOLVED]
Alaahel
PostPosted: 12:39 - 26 Sep 2015    Post subject: NSR 125 JC22 Electrical Problem.[SOLVED] Reply with quote
Hi everyone !
So I have a NSR, which worked well for a while, but now I have a weak spark and it won't charge either.
I had a few spares, so I replace the stator, regulator rectifier and put in a new battery. No changes.
If this helps, when the bike is idling, I get about 10-12 volts from the 4 pin connector off the stator, between the yellow wires and ground. This drops to almost nothing when reving the bike up.
I've check all the resistance and everything is within normal ranges.
Anyone has any idea ?
Thanks
Val
PostPosted: 21:29 - 27 Sep 2015    Post subject: Reply with quote
Thanks
You have confused me with that voltage. I do not know your particular model, but the normal AC voltage coming from the stator must be well over 12V must be 50V at 5000 rpms.
If yours produces miserly 12v AC you need to replace the rotor.
It will help if you explain what exactly you are measuring? And do you have your bike electrical diagram and details about expected AC voltage from your stator from the service manual?
Just use this to find the issue ok Very Happy
https://www.electrosport.com/media/pdf/fault-finding-diagram.pdf
alains
PostPosted: 16:16 - 28 Sep 2015    Post subject: Reply with quote
the stator has 9 coils as : 3 in serial and connected like triphased in Y it provides after rectifier 14.2VDC at 5500 rpm
it has also 2 coils (bigger than the 9 others) in serial to provide the charge of the CDI's capacity Under 200VAC at 5500 rpm
the thing to keep in mind : ignition is separated from the provided energy
if the battery is not charging this is from the 3 yellow wires . but you should read about 19VAC between yelows before rectifier
take mesurement between a yellow and the 2 others
the stator is the weakest part on the NSR , but if necessary you should find spares on eBay . just pay attention at coils number , must be 11
Alaahel
PostPosted: 12:44 - 10 Oct 2015    Post subject: Reply with quote
Hi guys,
Thanks for taking the time and your responses.
Ok, so back with a bit more testing, following your advice.
I get 8-9 volts AC from yellow to yellow (all pairs) when the regulator rectifier is connected and it drop when reving. With the rectifier unplugged, I get about 11-13 volts on each pair at idle and then it goes up to about 35-40 volts at 5000 rpm.
I do have a spare stator, which gives the same range of results.
It could be unrelated, but I also noticed that when I put the indicators on, the servo motor twitches a little bit.
Which to be honest I have no clue on how this can happen.
alains
PostPosted: 13:12 - 10 Oct 2015    Post subject: Reply with quote
when a battery is worn this kind of bug appears . when the battery is connected the voltage is 14.2 VDC
charge your battery with a charger then check voltage when you unplug (if less than 12.6V battery worn) , wait 2 hours then check again (if you've lost more than 0.2V battery is worn)
BATTERY IS PART OF THE CHARGING SYSTEM
if bug remain try an other reg/rec but you should think about loom exchange if you find the right one for your model
Alaahel
PostPosted: 14:43 - 10 Oct 2015    Post subject: Reply with quote
Well the battery is new and hold its charge so I guess it's time for a new loom !
Thanks Alains for your time and help, on this occasion but also countless other time I was looking for info on my beloved NSR Smile
Alaahel
PostPosted: 20:23 - 16 Oct 2015    Post subject: Reply with quote
If anyone has similar symptoms, I found what was my problem.
In hindsight it's probably something I should have checked first, but I checked the positive wire (red) that goes into the RR for continuity with the positive battery terminal and found a resistance of 600 ohms or so.
Although the first thing we check is the stator, battery and RR. There is a connector where the start switch, fuse and RR wires meet, it's a simple crimp, which looks a bit like the picture shown. I'm guessing with the vibration, moisture etc, it can weaken and break off.
Anyhow, glad to finally have found the answer Smile
https://www.madelectrical.com/electricaltech/images/remote3.jpg
stirlinggaz
PostPosted: 00:43 - 17 Oct 2015    Post subject: Reply with quote
hi,
glad to hear you got it sorted Smile
There seems to be a few nsr owners having problems with batteries not charging, so this info will be useful.
where exactly is this connection/crimp located? (for future reference)
cheers,
GAZ
Alaahel
PostPosted: 10:53 - 17 Oct 2015    Post subject: Reply with quote
It's located between the two diodes on my loom, although I guess it may vary slightly.
stirlinggaz
PostPosted: 13:00 - 17 Oct 2015    Post subject: Reply with quote
erm, where that then?
cheers,
GAZ
Alaahel
PostPosted: 13:09 - 17 Oct 2015    Post subject: Reply with quote
lol, hum... Between the connector coming from the stator and the one going to the RR.
The last post was made 10 years, 341 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 69.44 Kb
