Sym jet 4 50cc de restricting
that ped guy
PostPosted: 13:31 - 27 Sep 2015    Post subject: Sym jet 4 50cc de restricting Reply with quote
Hi I am looking at getting a small moped for commuting to work I have been searching around and I really like the look of the sym jet 4 50cc I was just wonder if it can be de restricted and what sort of speed I would get once I have done that.
Andy_Pagin
PostPosted: 16:15 - 27 Sep 2015    Post subject: Reply with quote
Bare in mind that if you 'de-restrict' it you will need to re-register it with the DVLA as a motorcycle, inform your insurers, and will need a minimum of a provisional motorcycle licence to ride it.
wr6133
PostPosted: 16:45 - 27 Sep 2015    Post subject: Reply with quote
If it's a Chinese GY6 clone (which it appears to be) then it'll be a combination of the following.
Washer in variator.
Carbs (usually a thing in the needle).
CDI (can normally snip a wire).
Remove any of them present and that whopping 2.4BHP will let you get to about 35mph on the flat with a long enough run up.
If you want a better increase then you need an 80cc big bore kit. With one of them and the right carb/roller/clutch setup you can manage 45mph on the flat with a long run up.
Or just buy the 125 version and you can do 55mph.
Ayrton
PostPosted: 18:06 - 27 Sep 2015    Post subject: Reply with quote
Your not going to get much more by de-restricting it and any copper that catches you doing over 30mph will know it's de-restricted. If your old enough then just get a 125 instead.
My friend had a sym jet though and it was pretty good.
The last post was made 10 years, 342 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 38.85 Kb
