Suzuki Dr125cc SM Exhaust Header Problem
 Topic moved: from General Bike Chat to The Workshop by stinkwheel (28 Sep 2015 - 19:27)
smithyy
PostPosted: 17:00 - 28 Sep 2015    Post subject: Suzuki Dr125cc SM Exhaust Header Problem Reply with quote
i have a 2010 Suzuki dr125cc sm
would like to know if any other bikes header is interchangeable with any other bike as i am having a problem locating this part as mine has snapped of Sad
PostPosted: 18:03 - 28 Sep 2015    Post subject: Reply with quote
Technical discussions and mechanical advice. Need help with your bike?
The Workshop
smithyy
PostPosted: 18:07 - 28 Sep 2015    Post subject: Reply with quote
Sorry have i posted in wrong section
PostPosted: 20:29 - 28 Sep 2015    Post subject: Reply with quote
Sorry, moving and new thread happening at the same time. Have deleted the spare as no replies.
Where has it snapped? It's unusual for a header pipe to snap. Or has it rusted through?
PostPosted: 21:11 - 28 Sep 2015    Post subject: Reply with quote
Huh, you're right, they're not exactly growing on trees. Thinking
One possibility is that a Chinese copybike pipe will fit. I believe that engine is the one that's used in a lot of copybikes (the other being the CG copyengine).
I've found CMPO to be pretty helpful in the past and they certainly know their copybikes. Worth a try?
https://www.chinesemotorcyclepartsonline.co.uk/contact.php
smithyy
PostPosted: 13:01 - 29 Sep 2015    Post subject: Reply with quote
think its rusted through and got 2 hot tbh and burnt from inside out just so difficult to find and if i want one making im looking at over £100
smithyy
PostPosted: 13:31 - 29 Sep 2015    Post subject: Reply with quote
i will give these contact see what happens there like rocking horse shit atm mind my french
smithyy
PostPosted: 18:38 - 02 Oct 2015    Post subject: Still no use Reply with quote
Still no use cant find one anywhere at all , it hard to find the pipe with the correct hole for the 02 sensor
PostPosted: 18:57 - 02 Oct 2015    Post subject: Reply with quote
Thanks, ecomentals.
Short of binning your FI and fitting a carb, you could drill and tap a hole for the sensor. It might require welding an appropriate sized nut on to give enough to thread into.
Sorry, sucks to be you.
In extremis, if you're absolutely stuck, I guess you could ask a Suzuki dealer. Pale
The last post was made 10 years, 351 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.03 - MySQL Queries: 16 - Page Size: 59.61 Kb
