custom made expansion chamber makers
stirlinggaz
PostPosted: 15:38 - 29 Sep 2015    Post subject: custom made expansion chamber makers Reply with quote
hi,
im looking for recommendations for someone to build me a custom made expansion chamber for a project im working on.
its nothing too complicated, just a little single cylinder 180cc 2 stroke engine combined with a dellorto vhsb 34mm carb or maybe something bigger...
theres nothing available ready made, that would be suitable, apart from the usual 125cc exhausts which would just restrict it.
its not for racing so it would need a useable power-band & be capable of making peak power at around 12500rpm but still be useable below 7000rpm.
would this be prohibitively expensive? even in mild steel, without an end can? (I have a few that could just be welded/bolted on.
I know there are programmes/guides out there that can assist in designing them yourself but I think that might be outwith my skill-set. (im willing to look into this though)
anyone actually done anything like this & can point me in the right direction?
cheers,
GAZ
PostPosted: 15:48 - 29 Sep 2015    Post subject: Reply with quote
These guys near me still do.
https://gibsonexhausts.co.uk/page_8.php?pgenme=2stroke
I've never used them mind.
PostPosted: 17:15 - 29 Sep 2015    Post subject: Reply with quote
Wouldn't a 200cc enduro exhaust suit the "needs" to a degree. As in it won't restrict it but still gives you something to work with.
stirlinggaz
PostPosted: 20:35 - 29 Sep 2015    Post subject: Reply with quote
maybe..
I hadnt thought that, but the engine is out of a Honda who don't make a 200cc version of this engine or bike that it came out of.
its gonna be fitted to a road going bike, probably a mito or something equally sporty/small/light.
I have contacted a guy in euroland who makes nice expansion chambers in small numbers, who seems to have a good reputation & the quality of his work is impressive, for what he charges.
I really like the idea of designing 1 myself, using available formulae/programs, right up to a cardboard mock up & then get someone to weld together the steel version of it, but I fear the mathematics is beyond me & it would probably work out more expensive.
anyone any ideas?
cheers,
GAZ
stevo as b4
PostPosted: 19:24 - 30 Sep 2015    Post subject: Reply with quote
Hi Gaz.
Paddy is thinking the right way IMO, but if it's not just to get a motor running in a bike cheaply, then while cutting and shutting a 200cc bike's exhaust to fit the new engine/bike/vehicle should get you closer to what you need than a 125cc pipe will, it's worth spending more on a custom pipe to get the most out of a non std motor/bike build if it's feasible?
I'm having a 125cc pipe made up in a months time for a KMX 125. I'm led to believe it will cost in the £300-350 region, for my application, but with any decent custom job your paying for the time and expertise in measuring, calculating and educated guess work from experience, much more so than the price of the materials and labour to fabricate it IMO.
Oh and what engine is it, curiousness needs satisfying! Laughing
Suntan Sid
PostPosted: 20:15 - 30 Sep 2015    Post subject: Reply with quote
Honda MTX200R
https://www.motorcyclespecs.co.za/Gallery%20B/Honda%20MTX%20200R%2083.jpg
Iain.
PostPosted: 21:21 - 30 Sep 2015    Post subject: Reply with quote
Why not use the factory expansion chamber and re-package it as per the motocross engine RS50 conversions?
https://www.apriliaforum.com/micahupload/Apriliasaki%20Upload/BuildingPicsTop.jpg
https://www.apriliaforum.com/forums/attachment.php?attachmentid=81192&stc=1&d=1207240431
bladerunner
PostPosted: 22:45 - 30 Sep 2015    Post subject: Reply with quote
Mick abbey is worth talking to. He tunes and makes pipes to suit the bike. 12.5k peak power is pretty high up the range to be pulling well from 7k if your after sporty levels of hp
stirlinggaz
PostPosted: 15:05 - 02 Oct 2015    Post subject: Reply with quote
Suntan Sid wrote:
nope, been a while since I had the mtx.
BUT just had a thought...I still have an expansion chamber off a mtx 200 in ma shed!
its leftover from when I had the mtx, & its not likely to get used as I dont plan on getting another mtx..
so, its a NSR 125 engine, with malossi 180cc bbk.
I will be fitting a dellorto vhsb 34mm carb, simply because I have a spare.
BUT the bbk comes with jets for the standard 28mm carb, so might start off with the 28mm & see how it goes.
heres what im thinking : the honda mtx is a trail type bike, so the exhaust (well the expansion chamber) is the wrong "shape" for a road/sports bike, could I just cut it & weld it?
am I right in thinking its the "fat" bit of the spanny thats important for bhp, right?
well, ok, I know the length of the stinger (the thin bit) has more to do with where the powerband will be/how wide it is.
will cutting it, still get me the full power out off it?
or am I wasting my time with the mtx expansion chamber? (it also seems a bit of a waste, destroying a perfectly good exhaust, which is actually quite rare)
the mtx 200 puts out 20 something bhp.
the nsr 125 with standard cylinder & decent 125 exhaust already puts out around 28bhp, & the 180cc cylinder is good for 38bhp but thats with a custom pipe (around 35bhp with the jolly-moto off the 125)
so suggestions?
bare in mind, I cant weld so would have to cut it, at the right bit & take it to somebody to weld it back up.
cheers,
GAZ
ps : meant to say, I can get a hand made,custom exhaust made up for sround 250 quid (in mild steel & without end can) from somebody who makes good pipes & has already made 1 before for the 180cc kit & it will make 39bhp @ 10000rpm (peak power)
thst sounds good, right?
UnknownStuntm...
PostPosted: 16:15 - 02 Oct 2015    Post subject: Reply with quote
Bite his arm off! That's almost incredibly exactly what you're after.
The little I do know about two stroke pipes, is that it's the diameter of the chamber, the taper, the angles of both sides of the belly and the length of the tail before the stinger that affects power. So pretty much everything, yes....
Suntan Sid
PostPosted: 16:32 - 02 Oct 2015    Post subject: Reply with quote
Before you attack the MTX spanny, is there an easy, non destructive, method of fitting it on the engine and seeing what's what?
stirlinggaz
PostPosted: 16:37 - 02 Oct 2015    Post subject: Reply with quote
thats what im thinking about....I might be able to bolt it onto the cylinder, but nowhere else & its way too high BUT I might give it a try & see how it performs...but the more I think about a custom pipe, the more im convinced its the way forward...
cheers,
GAZ
PostPosted: 22:43 - 02 Oct 2015    Post subject: Reply with quote
Expansion chamber design is a real black art, and far more to it that just down to matching engine capacity. Needs to be designed for port timing, etc.
How well designed is the porting on the BBK? Which BBK was it that Performance Bike used in the article (about 20 years ago) on playing with the NS125?
K
stevo as b4
PostPosted: 16:14 - 03 Oct 2015    Post subject: Reply with quote
I wouldn't cut up an MTX 200 pipe. Shocked
So rare, and sellable on Ebay too. Even then id want to measure all the dimensions so I'd have something to base another MTX200 pipe on or pass on the details to other MTX owners trying in desperation to get exhausts for their MTX's.
If the guy doing the custom pipe makes it for your engine (with big bore kit) and for your chassis or something very similar, then buy it at that price, it's a steal especially if it's been dyno tested/developed.
My pipe will be more than that, but I'm going stainless (thanks to Knacker and his DT125RE with the sexy shiny pipe).
Matching pipes from cc to other engines is of course very simplistic, but it does seem to always be the case that bigger engines/cylinders need more volume in the pipe than they did as a 125cc engine.
Look at all the Aprilia RS125 owners that complain of poor top end performance when fitting the 150/160? big bore kits. If Polini or whoever makes the kit supplied a pipe with it specifically for the conversion, I bet the results and power gains achieved would be far more pleasing. As it stands the forums are nearly all against bigger cylinder conversions and regard them as backwards step.
stirlinggaz
PostPosted: 18:59 - 03 Oct 2015    Post subject: Reply with quote
Look at all the Aprilia RS125 owners that complain of poor top end performance when fitting the 150/160? big bore kits. If Polini or whoever makes the kit supplied a pipe with it specifically for the wconversion, I bet the results and power gains achieved would be far more pleasing. As it stands the forums are nearly all against bigger cylinder conversions and regard them as backwards step.
hi,
I have thought about it a bit more & the mtx exhaust can stay in the garage, along side the angle grinder Smile
it would need to be cut in at least 2 or 3 places & even then I would need to get someone to weld it back together & the mtx 200 only puts out about 22bhp so I would probably LOSE power!
it might come in handy for someone.
i have spoke to the exhaust builder & hes suggesting mild steel,something to do with heat apparently.
it will give peak power at about 10500rpm, so I wont need to rev it any higher than I do now. (& will probably not need to take it that high normally)
price is good, & I have seen a couple of his previous efforts & they are close to being works of art.
your right in saying the bbk's have a bad reputation, especially in the UK, & that's cos nobody builds suitable exhausts to exploit the extra power & torque!
well at least there's 2t owners abroad willing to take up the challenge Smile
I'll be going with whatever the exhaust builder suggests for the expansion chamber but with the end being able to accept any bolt on end can.
looking forward to around 38bhp on a bike that weighs around 130kg (less when my blacksmith mate gets round to building me a rear subframe out of alu Smile )
cheers,
GAZ
stevo as b4
PostPosted: 16:10 - 04 Oct 2015    Post subject: Reply with quote
Don't forget Moar pics either! Laughing
The last post was made 10 years, 342 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 97.84 Kb
