| stirlinggaz |
| chris-red |
 Posted: 15:48 - 29 Sep 2015 Post subject: |
These guys near me still do.
https://gibsonexhausts.co.uk/page_8.php?pgenme=2stroke
I've never used them mind. ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
| P.addy |
 P.addy Red Rocket
| stirlinggaz |
| stevo as b4 |
 Posted: 19:24 - 30 Sep 2015 Post subject: |
Hi Gaz.
Paddy is thinking the right way IMO, but if it's not just to get a motor running in a bike cheaply, then while cutting and shutting a 200cc bike's exhaust to fit the new engine/bike/vehicle should get you closer to what you need than a 125cc pipe will, it's worth spending more on a custom pipe to get the most out of a non std motor/bike build if it's feasible?
I'm having a 125cc pipe made up in a months time for a KMX 125. I'm led to believe it will cost in the £300-350 region, for my application, but with any decent custom job your paying for the time and expertise in measuring, calculating and educated guess work from experience, much more so than the price of the materials and labour to fabricate it IMO.
Oh and what engine is it, curiousness needs satisfying!  |
| Suntan Sid |
| Iain. |
 Iain. Could Be A Chat Bot
 Posted: 21:21 - 30 Sep 2015 Post subject: |
| bladerunner |
| stirlinggaz |
 Posted: 15:05 - 02 Oct 2015 Post subject: |
nope, been a while since I had the mtx.
BUT just had a thought...I still have an expansion chamber off a mtx 200 in ma shed!
its leftover from when I had the mtx, & its not likely to get used as I dont plan on getting another mtx..
so, its a NSR 125 engine, with malossi 180cc bbk.
I will be fitting a dellorto vhsb 34mm carb, simply because I have a spare.
BUT the bbk comes with jets for the standard 28mm carb, so might start off with the 28mm & see how it goes.
heres what im thinking : the honda mtx is a trail type bike, so the exhaust (well the expansion chamber) is the wrong "shape" for a road/sports bike, could I just cut it & weld it?
am I right in thinking its the "fat" bit of the spanny thats important for bhp, right?
well, ok, I know the length of the stinger (the thin bit) has more to do with where the powerband will be/how wide it is.
will cutting it, still get me the full power out off it?
or am I wasting my time with the mtx expansion chamber? (it also seems a bit of a waste, destroying a perfectly good exhaust, which is actually quite rare)
the mtx 200 puts out 20 something bhp.
the nsr 125 with standard cylinder & decent 125 exhaust already puts out around 28bhp, & the 180cc cylinder is good for 38bhp but thats with a custom pipe (around 35bhp with the jolly-moto off the 125)
so suggestions?
bare in mind, I cant weld so would have to cut it, at the right bit & take it to somebody to weld it back up.
cheers,
GAZ
ps : meant to say, I can get a hand made,custom exhaust made up for sround 250 quid (in mild steel & without end can) from somebody who makes good pipes & has already made 1 before for the 180cc kit & it will make 39bhp @ 10000rpm (peak power)
thst sounds good, right? |
| UnknownStuntm... |
 UnknownStuntm... World Chat Champion
| Suntan Sid |
 Posted: 16:32 - 02 Oct 2015 Post subject: |
Before you attack the MTX spanny, is there an easy, non destructive, method of fitting it on the engine and seeing what's what? ____________________ "Everybody needs money, that's why they call it money!"  |
| stirlinggaz |
| stevo as b4 |
 Posted: 16:14 - 03 Oct 2015 Post subject: |
I wouldn't cut up an MTX 200 pipe.
So rare, and sellable on Ebay too. Even then id want to measure all the dimensions so I'd have something to base another MTX200 pipe on or pass on the details to other MTX owners trying in desperation to get exhausts for their MTX's.
If the guy doing the custom pipe makes it for your engine (with big bore kit) and for your chassis or something very similar, then buy it at that price, it's a steal especially if it's been dyno tested/developed.
My pipe will be more than that, but I'm going stainless (thanks to Knacker and his DT125RE with the sexy shiny pipe).
Matching pipes from cc to other engines is of course very simplistic, but it does seem to always be the case that bigger engines/cylinders need more volume in the pipe than they did as a 125cc engine.
Look at all the Aprilia RS125 owners that complain of poor top end performance when fitting the 150/160? big bore kits. If Polini or whoever makes the kit supplied a pipe with it specifically for the conversion, I bet the results and power gains achieved would be far more pleasing. As it stands the forums are nearly all against bigger cylinder conversions and regard them as backwards step. |
| stirlinggaz |
 Posted: 18:59 - 03 Oct 2015 Post subject: |
| stevo as b4 wrote: | I wouldn't cut up an MTX 200 pipe.
Look at all the Aprilia RS125 owners that complain of poor top end performance when fitting the 150/160? big bore kits. If Polini or whoever makes the kit supplied a pipe with it specifically for the wconversion, I bet the results and power gains achieved would be far more pleasing. As it stands the forums are nearly all against bigger cylinder conversions and regard them as backwards step. |
hi,
I have thought about it a bit more & the mtx exhaust can stay in the garage, along side the angle grinder
it would need to be cut in at least 2 or 3 places & even then I would need to get someone to weld it back together & the mtx 200 only puts out about 22bhp so I would probably LOSE power!
it might come in handy for someone.
i have spoke to the exhaust builder & hes suggesting mild steel,something to do with heat apparently.
it will give peak power at about 10500rpm, so I wont need to rev it any higher than I do now. (& will probably not need to take it that high normally)
price is good, & I have seen a couple of his previous efforts & they are close to being works of art.
your right in saying the bbk's have a bad reputation, especially in the UK, & that's cos nobody builds suitable exhausts to exploit the extra power & torque!
well at least there's 2t owners abroad willing to take up the challenge
I'll be going with whatever the exhaust builder suggests for the expansion chamber but with the end being able to accept any bolt on end can.
looking forward to around 38bhp on a bike that weighs around 130kg (less when my blacksmith mate gets round to building me a rear subframe out of alu )
cheers,
GAZ |
| stevo as b4 |
 Posted: 16:10 - 04 Oct 2015 Post subject: |
Don't forget Moar pics either!  |
The last post was made 10 years, 343 days ago. Instead of replying here, would creating a new thread be more useful? |
