new alarmed disc lock
bigdom86
PostPosted: 20:31 - 29 Sep 2015    Post subject: new alarmed disc lock Reply with quote
so i dropped my disc lock from height and the alarm module doesnt sit right anymore but can still use it as a normal disc lock fine.
any recommendations for a new alarmed disc lock? looking to spend around £50 maximum. had a xena for past year and no issues besides dropping it Mr. Green
Snop Doog
PostPosted: 22:58 - 29 Sep 2015    Post subject: Reply with quote
Get another Xena and don't drop it?
Ariel Badger
PostPosted: 23:11 - 29 Sep 2015    Post subject: Reply with quote
Buy one that is strong enough to not break with a little knock.
NJD
PostPosted: 23:30 - 29 Sep 2015    Post subject: Reply with quote
If you've done enough damage to render the alarm broken then what's the overall condition of the lock itself, internally that is. Thinking
I wouldn't count on that alarm to do anything other than possibly wake you up in your half asleep state in the middle of the night when you think "ah fek it, winds set it off or something" because we all ignore car alarms, house alarms and well no one has ever stopped me fiddling about the locks on my bike regardless of i'm actually locking up with my gear on or not.
"Broken alarm m8, stopping it from going off all the time on me lunch brake like" seems one of many possible responses if anyone did ask why someone not wearing gear was fiddling with the locks on a bike parked up, and what proof could the nosy person provide otherwise?
Anyway..
As above if you where happy before "doh" moment then as you where, or do you want something different?
bigdom86
PostPosted: 11:37 - 07 Oct 2015    Post subject: re Reply with quote
hi all
got the xena to work again but still would like to get a new one, the xena one goes off if a mouse farts next to it. ideally would like something which will only go off if the lock is physically touched or wheel moved
cheers Very Happy
someotherguy
PostPosted: 12:44 - 07 Oct 2015    Post subject: Reply with quote
I use an Abus disc lock alarm. £65 from GetGeared, so maybe a touch over your budget, but I'm sure you can find it cheaper elsewhere.
It does the job, and it's not overly sensitive. It's just sensitive enough so that it will only go off if you move it (e.g. you try to take the lock off or move the bike). It has never gone off any other time.
Hope this helps.
someotherguy
PostPosted: 09:02 - 08 Oct 2015    Post subject: Re: re Reply with quote
MrGs1 wrote:
Alarmed disc locks are annoying and not weather proof unless your bike lives in a garage.
Mine's not annoying, and it's been outside for over a year with no issues whatsoever.
brains_t
PostPosted: 08:48 - 09 Oct 2015    Post subject: Reply with quote
JDC search Amazon about £30. Had mine for two and half years, wind and lazy cats set off warning but not alarm. Sensitive enough to go off if you are slow unlocking. Changed batteries after 18 months and sprayed with GT85 over last winter. No complaints.
Mudshark
PostPosted: 09:04 - 09 Oct 2015    Post subject: Re: re Reply with quote
mine too AND it's an Oxford!
R1250RS
XT660X
grr666
PostPosted: 10:57 - 09 Oct 2015    Post subject: Reply with quote
Was the broken disc lock a xena?
I thought the internals in those were replaceable?
bigdom86
PostPosted: 11:12 - 13 Oct 2015    Post subject: re Reply with quote
hi all
will look into those, don't really have a budget don't mind spending more for something decent.
yes the xena was the one where the internals broke when i dropped it but i manage to position it to work, if i turn it with the lock facing up the unit inside drops down and arms the lock but if i turn it upside down then fit it sideways to the disc it works ok. will see if i can replace the inside bit, i think its just the catch which holds the alarm module in place which is broken
The last post was made 11 years, 34 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.24 - MySQL Queries: 13 - Page Size: 72.78 Kb
