Honda CB200 1977 camshaft urgently needed
HondaCB200Lad...
PostPosted: 17:05 - 30 Sep 2015    Post subject: Honda CB200 1977 camshaft urgently needed Reply with quote
Hi everyone,
I am new to the forum and urgently need a camshaft for my Honda CB200 1977 model - obviously needs to be in good condition.
I recently bought the bike and unfortunately despite the low mileage the lack of maintenance means that the cam chain had not been adjusted so has knackered the camshaft along with other parts which I have managed to locate. The camshaft however is beyond repair and the only replacements used parts I can find are in the USA. I know it is a long shot but if you don't ask and all that.
Keeping my fingers crossed.
Thanks for reading Smile
RhynoCZ
PostPosted: 18:40 - 30 Sep 2015    Post subject: Reply with quote
Are you sure the camshaft can't be resurfaced? Thinking
I'd ask here (for instance): https://www.hondatwins.net/index.php Thumbs Up
There is a very high possibility the '77 CB200 camshaft is the same as in other models from that era.
HondaCB200Lad...
PostPosted: 18:46 - 30 Sep 2015    Post subject: Reply with quote
We have been told it is too far gone. It is the ends where the main damage is so would need machining and then the left and right casings would need sleeves to match. Currently going to take it to another machine shop who might tackle it. Just thought it might be easier in the long run (want to keep the bike when finished) to replace bad parts with good.
Any advice is much appreciated.
piazza
PostPosted: 19:08 - 30 Sep 2015    Post subject: Reply with quote
https://www.ebay.com/itm/75-Honda-CB-200T-200-T-used-Cam-Camshaft-Shaft-Timing-Gear-/361394363878?_trksid=p2054897.l4275
HondaCB200Lad...
PostPosted: 19:11 - 30 Sep 2015    Post subject: Reply with quote
Thanks piazza, I have that one on my watch list and there is also another a lot more expensive in the USA. Hoping to locate one in the UK to save on shipping times.
Ariel Badger
PostPosted: 22:21 - 30 Sep 2015    Post subject: Reply with quote
£100 pounds inc P&P is dirt cheap for a camshaft, to restore yours could cost double that.
HondaCB200Lad...
PostPosted: 22:32 - 30 Sep 2015    Post subject: Reply with quote
True but if you check closely on the pictures it is not in the best condition (part of the points housing casing is still on the shaft!) and having to wait possibly 3 weeks for it to arrive is not ideal.
Might have located a complete engine but don't know the condition yet - or price.
piazza
PostPosted: 22:46 - 30 Sep 2015    Post subject: Reply with quote
Go on treat yourself! Laughing
https://www.ebay-kleinanzeigen.de/s-anzeige/honda-cb200-motor/347331549-305-1935
HondaCB200Lad...
PostPosted: 22:56 - 30 Sep 2015    Post subject: Reply with quote
piazza wrote:
That is cheap. Mine actually looked better than that but when trying to rectify running problems we discovered broken piston rings, scored barrels, cam chain tensioner and the camshaft wrecked!!
Will post some photos when I have time to resize them.
Fizzer Thou
PostPosted: 10:55 - 01 Oct 2015    Post subject: Reply with quote
434 Euros Shocked Shocked Shocked
https://www.cmsnl.com/honda-cb200-england_model16413/partslist/E02.html#results
Always have a 'Plan B'
HondaCB200Lad...
PostPosted: 13:07 - 01 Oct 2015    Post subject: Reply with quote
Fizzer Thou wrote:
Laughing I did see that, luckily the part is unavailable so I was not tempted to order it. Wink
moonzoomer
PostPosted: 22:39 - 01 Oct 2015    Post subject: Reply with quote
If your cam is knackered you can rest assured the rest of the engine is knackered as well, probably due to dirty oil or total lack of the slippery stuff, if you are stuck the cb175 motor will fit if you can one.
Major Doss
PostPosted: 22:59 - 01 Oct 2015    Post subject: Reply with quote
moonzoomer wrote:
If your cam is knackered you can rest assured the rest of the engine is knackered as well, probably due to dirty oil or total lack of the slippery stuff, and weird whatever
Not necessarily. CB's always had a bit of a naff top end oil feed.
HondaCB200Lad...
PostPosted: 16:45 - 02 Oct 2015    Post subject: Reply with quote
I think that it is just the cam shaft, chain tensioner and housing that has been damaged. I will post some photos and more on what we have done and found along the way. It is always hard to comment on something without seeing it.
HondaCB200Lad...
PostPosted: 16:55 - 02 Oct 2015    Post subject: Reply with quote
Damaged cam shaft
HondaCB200Lad...
PostPosted: 17:04 - 02 Oct 2015    Post subject: Reply with quote
close ups
HondaCB200Lad...
PostPosted: 17:06 - 02 Oct 2015    Post subject: Reply with quote
THE STORY SO FAR - hopefully in order and no omissions.
The engine has little mileage and bike has been dry stored for around 15 years with the last two owners with little or no use. The guy we bought it off had little mechanical knowledge. The bike started with the kick start but running was erratic and it was suggested the carbs needed setting up.
The fuel tank was our first concern with the amount of rust in it so hubby made a temporary tank out of a petrol can. The starter motor did not work and on checking was full of oil - cleaned it out, seals replaced and looked for the cause which seemed to be the breather pipe was wrongly routed and crushed. Starter motor now works fine. The engine did run when we got it but not well so we started by checking all the obvious - carbs, points, plugs, timing, tappets, oil drained and replaced etc. replacing with new parts as necessary including carb floats and full repair kits. I noticed a rattle so the cam chain was adjusted. The running did improve but we still had some smoke from the exhaust and from the breather pipe. There was an obvious difference in the temperature of the exhaust gasses from one side to the other. Compression checks showed it was low on the cool exhaust side (near/left side) but improved with a little oil in the barrel so "Off with it's Head". By this time we had decided that running it for a couple of months before the winter was not going to happen so the engine removed we found the off/right side piston was a replacement and the rings incorrectly placed with the gap lined up instead of staggered. The near/left side piston had two broken rings. The cam chain tensioner was damaged - photo above, the cam shaft ends and off/right side housing (speedo drive I believe) also damaged. Centrifugal oil filter fully sludged up with plenty of filings in the filter.
The head has been skimmed, valves re seated, barrels bored, new pistons and rings. Currently waiting on a decision on the cam shaft and a shed load of new and lightly used parts (where discontinued) are on order.
I will add some photos and any further information as it comes back to me. Three weeks of late night and weekends do have an effect so please forgive any omissions. We are thoroughly enjoying renovating the bike but it is frustrating at times. Hubby even bought another project (before things went bad with this one) Suzuki GT200 X5 1980.
I am sure the men in white coats will be paying us a visit soon
HondaCB200Lad...
PostPosted: 17:18 - 02 Oct 2015    Post subject: Reply with quote
Engine strip
HondaCB200Lad...
PostPosted: 17:44 - 02 Oct 2015    Post subject: Reply with quote
Now and Then Pictures
HondaCB200Lad...
PostPosted: 14:44 - 22 Oct 2015    Post subject: Reply with quote
Great news, we now have the choice of three or possibly four camshafts. You know what they say, you wait an hour for a bus and then three come along at once!!
We ended up buying a spares or repair CB200 (not looked at the camshaft yet). A frame with engine CB200 which on inspection has an as new camshaft. Two good fuel tanks, a used but in great condition cam shaft with matching end casings and a brand new cam shaft. We can now crack on with the rebuild and possibly look at a Cafe Racer/Bobber/Street Scrambler project with the others - time permitting.
Thanks for the response and advice, I will try and post updates so you can see the progress.
Nexus Icon
PostPosted: 18:24 - 22 Oct 2015    Post subject: Reply with quote
Please do. Interesting pics up there. Thumbs Up
Greetings from Shitsville!
PostPosted: 21:10 - 22 Oct 2015    Post subject: Reply with quote
I reckon I could fix that camshaft. I'd need better pics of the cam and the head to make a proper judgement.
The image with the hand in it - 1305 - what is that thing? If it's a centrifugal strainer then that engine is in pretty poor condition I'd say. Lot of metal in there.
HondaCB200Lad...
PostPosted: 10:09 - 23 Oct 2015    Post subject: Reply with quote
Hi Pete,
The cam shaft is probably fixable but as I want to keep the bike I decided to get a good one. I will hang on to the damaged one, you never know someone might be in desperate need as they are getting rarer.
Yes the image with the hand in is the centrifugal oil filter and there was filings in the strainer. Someone had replaced one piston and not done any remedial work - clean out the oil filter etc. It looks a lot worse than it is, the engine has been stripped and thoroughly inspected so I am sure there was no other damage done.
It will be put back together as soon as the polishing is finished. It is a really low mileage bike but previous owners have not given it the care and attention it needed. I think the damage to the cam has been through them starting it up occasionally for a short time when there is little or no oil in the head. Then leaving it for a few years and doing the same.
It has a good home now but will not be put in to retirement!!
The last post was made 11 years, 27 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.10 Sec - Server Load: 1.07 - MySQL Queries: 13 - Page Size: 121.13 Kb
