Socket set recommendations.
NJD
PostPosted: 22:57 - 03 Oct 2015    Post subject: Socket set recommendations. Reply with quote
In need of a socket set that will enable me to do some light maintenance on my bike. I've window shopped but keep going round in circles so would like some suggestions, all I do know is that they have to be 6 sided and metric.
Sizes of sockets that I may need vary from 8mm-25mm a set that contains all of this range would be great but equally a cheaper set where sockets of the required size can be purchased to use on the ratchet work also, i'm getting a bit confused what sockets would work with what ratchet so a set would probably work better.
Argos, Halfords or Homebase as I'm able to visit in person and have stores fairly local would be ideal.
edit: and a 18mm plug socket.
Thanks. Thumbs Up
FlightRisk
PostPosted: 23:00 - 03 Oct 2015    Post subject: Reply with quote
One of the Halfords Advanced Professional sets, lifetime warranty, get 'em when they're on sale. They're on sale every other week.
Honda CB500S
NJD
PostPosted: 23:05 - 03 Oct 2015    Post subject: Reply with quote
They all appear 12 sided sockets, do they have a 6 sided version in store?
NJD
PostPosted: 23:40 - 03 Oct 2015    Post subject: Reply with quote
All this 1/2, 3/8, 1/4 is not exactly newbie friendly, what one would I go for?
Raffles
PostPosted: 23:56 - 03 Oct 2015    Post subject: Reply with quote
All three!
NJD
PostPosted: 00:06 - 04 Oct 2015    Post subject: Reply with quote
How about this?
No 22mm socket though hmm of which I may need. I'd assume that this would just fit straight on the ratchet if I did need it?
Major Doss
PostPosted: 00:07 - 04 Oct 2015    Post subject: Reply with quote
Half inch is overkill for most mc apps, 3/8 good for most stuff if you have a feel for torque, 1/4 good up to 14 lbf or so, IME. Spunk cash (well, 30 sovs) on a decent torque wrench if you are unsure/newb.
Genuine question; Why specifically 6 sided?
bamt
PostPosted: 00:11 - 04 Oct 2015    Post subject: Reply with quote
3/8 is probably the most useful for general stuff. You can get small to reasonably big sockets in it, and torque wrenches. Almost everything on a bike can be done with a 3/8 set.
1/2 is good for heavier duty work, but you may find that the smaller sockets (e.g. 10mm) are too chunky to fit into small gaps (it still needs to be pretty thick at the top to fit the 1/2 inch drive). So, for example, doing the head gasket on one of our bikes the other day, I couldn't use the 1/2 inch set as the socket fouled on the casting next to the nut. The 3/8 slipped straight on. Tools like impact drivers tend to be at least 1/2 inch.
1/4 is best for tiny sockets - again useful to have for clearance purposes as they are physically smaller, or for more precise handling (you're less likely to destroy a small bolt using a 1/4 inch socket in a spinner than a socket in a 10 inch long 1/2 inch drive ratchet). It won't be strong enough for bigger fastners so not ideal as the only set. I'd buy this one last.
Short version - go for 3/8 as a first set.
Major Doss
PostPosted: 00:12 - 04 Oct 2015    Post subject: Reply with quote
NJD wrote:
How about this?
No. Get something better for not much more. You can always buy particular sockets as you need them. When you start buying tools.... Rolling Eyes great fun!
FlightRisk
PostPosted: 00:48 - 04 Oct 2015    Post subject: Reply with quote
You know a 12 sided socket is designed to go on a 6 sided bolt, right...?!
12-sided is absolutely fine. It has been for me anyway and I know some people who spanner for a living use the Halfords AP stuff because it's very decent quality and the warranty is convenient.
What kind of maintenance are you going to do?
Edit: I originally bought a set from Argos - I used it once and a ratchet started slipping. It also started rusting after about three weeks indoors! Returned and bought the Halfords 120 piece set which cost a bit more but has paid for itself several times over with the jobs I've been able to do. Bahco stuff should also be good.
Honda CB500S
PostPosted: 08:17 - 04 Oct 2015    Post subject: Reply with quote
Vincent wrote:
I just got this set as it goes*. I've had them before and really like the 6 point wall drive - it'll get off already-rounded fasteners in a lot of situations where the 12 point halfords one will just make it worse.
*Though paid £33 or so - around £40, but then quidco cash back through the current bespoke deals offer.
I'd also consider (and do regularly) one of the 94pc socket sets on ebay - I went for a REALLY cheap one (like £23) and while the tolerances aren't great (more so for some of the connectors rather than the work-end), for most things it does just fine and is great value for money offering 6-32mm, a good selection of deep sockets and a wide range of bits (including comprehensive allen, good range of trx etc.)
Moo.
PostPosted: 08:40 - 04 Oct 2015    Post subject: Reply with quote
Surprised noones mentined the lidl special when I eventually comes round again. I've been using mine for about 4 years now for general home mechanic stuff and its been perfect.
Lidl also have their torque wrenches in at the moment for about £17...
A2 Passed 18/6/10
c_dug
PostPosted: 09:32 - 04 Oct 2015    Post subject: Reply with quote
From experience I'd imagine you'll end up buying more than just one set anyway, I have three plus a few odds and ends that I bought for special jobs.
I prefer six sided/wall drive as a rule too, that said I have three socket sets including a dirt cheap six side set and an expensive 12 point, guess which is the better of the pair!
The third is a midrange six sided set, the sockets themselves are decent quality, really nice fit, they've dug me out of a couple of holes with all but rounded bolts in the past, but the ratchet and breaker bar are cack compared to the decent 12 point set. If I'm doing a big job I tend to bring out both the midrange 6 side and the expensive 12 side, then use the six sided bits on the expensive ratchet.
Probably all sounds a bit mad but it works! What I'm trying to say is go for a decent quality set primarily, then add to it what you need to.
I'd suggest second hand by the way. You'll get way more for your money.
Old Git Racing
PostPosted: 09:58 - 04 Oct 2015    Post subject: Reply with quote
Another vote here for Halfords Advanced Pros, I use them in my job and never had an issue. For a small Quarter drive set I use the Aldi 'Worx' sets. Cheap as chips, decent quality.
OGR
wots
PostPosted: 10:06 - 04 Oct 2015    Post subject: Reply with quote
My only issue with the Halfords sets, having owned one. It needn't be quite so big if they made one with just Metric sockets. It's a hefty set to lump around (good though it is), I just wish you had the choice of metric only.
PostPosted: 13:20 - 04 Oct 2015    Post subject: Reply with quote
The Lidl sets are equivalent to the (better) 94pc sets from ebay I believe. The bigger sets are available unbranded too, but much less so than the 94pc.
MCN
PostPosted: 13:51 - 04 Oct 2015    Post subject: Reply with quote
3/8" drive is very good for car/bike work. You only need 1/22 for wheel axle nuts swingarm pivot nuts and etc.
So you could save ££ by only buying a 1/2" drive swivel/power bar and the specific socket/tool to fit your axles
Halfords sets have some single hex/6 point for some of the 3/8" drive and some are 12 bi-hex/12 point.
Single Hex are better for loosening chewed/rusted fasteners. But shite on 12-point nuts and bolt heads. Smile
stevo as b4
PostPosted: 16:04 - 04 Oct 2015    Post subject: Reply with quote
I went the other way and started out with 1/2" sets and extra sockets, wheel/hub sockets, impact sockets etc.
As I spannered on car's for a while before bikes, with my own tools that is.
Then I built up a big set of 1/4" drive stuff, including extension bars, flexi drives, screwdriver drives and deep wall sockets. I've always found 1/4" drive to be the most used and useful size stuff on bikes, not 3/8".
As such I have a 3/8" low range torque wrench now, a stubby ratchet and about 7-8 3/8" sockets max, as I nearly always go for 1/4 or 1/2" drive items when doing job's and only use the 3/8" gear when I need to or can't get bigger 1/2" sockets or ratchets in tight areas to work on the bike.
My advice for OP is build up a good range of 1/4" drive tools, and bits, and then get a quality 1/2" set with the larger sizes in. That way you can tackle every job, and won't sometimes need anything bigger. And if you work on car's too 1/22 tools are essential.
Undinist
PostPosted: 16:23 - 04 Oct 2015    Post subject: Reply with quote
I got this 61 piece 3/8 inch RAC set for £40 from Argos recently - very pleased with it. The hex bit sockets and the extender bars are so useful. And the sockets go from 6mm to 24mm. It feels like good quality but I have no idea who made it. https://bit.ly/1M9kgUR
I combine it with a tiny 1/4 inch ratchet and an adapter so I can use all the 3/8 inch bits in small spaces.
Current bike: K1100RS. Previous: CD200, GSX250, GT550, VFR750, K100LT, K1100LT, R1100GS, R1150GS, ZZR1100, Hayabusa, RSV Mille, MV F4 750S, R1, ZX-10, KTM Adventure 950S
NJD
PostPosted: 16:53 - 04 Oct 2015    Post subject: Reply with quote
Halfords 200 piece set.
1/4 - 4-14mm
3/8 - 6-22 + 24mm
1/2 - 15-24 + 27, 30 and 32mm.
Also covers 8 - 19mm in spanners a bonus since I need a decent set.
Can I just confirm that 12 sided sockets and 12 sided ring spanners would not damage the 6 sided nuts and bolts on my bike?
Please let this be the set I can't take any more going round in circles. Praying
Andy_Pagin
PostPosted: 16:55 - 04 Oct 2015    Post subject: Reply with quote
If I was starting from scratch I'd just buy the individual sockets, bars and ratchets I actually need. If you buy a 40pc set you'll only ever use about four of the sockets. Better to just buy the ones you need and some matching spanners to go on the other end.
Skudd
PostPosted: 17:06 - 04 Oct 2015    Post subject: Reply with quote
I've had a Draper set for over 30 years and it has been great, got myself another bigger set about 3 years ago and that has been good too.
The last post was made 10 years, 339 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.17 - MySQL Queries: 13 - Page Size: 133.17 Kb
