Scooter in distress.
WKDSEED
PostPosted: 13:24 - 08 Oct 2015    Post subject: Scooter in distress. Reply with quote
Peugeot v-clic scooter.
Hi all, I'm a newby so please be kind hahahahahaha.
Okay better mention I'm the one in distress because I can't get my wheels running.
Okay this scooter was running mint and put away as usual then next day just won't start. Could anyone point me in the right direction for possible fault finding please. I do tinker a little but now it's time to ask the experts on here. I am trying to avoid a garage bill as I'm at sixth form so don't have much in the way of funds. Any help and advice will be greatly appreciated. Thank you . Loucas.
Bosh
PostPosted: 13:39 - 08 Oct 2015    Post subject: Reply with quote
What exactly is it doing, when you try to start it.
wr6133
PostPosted: 13:42 - 08 Oct 2015    Post subject: Reply with quote
The V-clic is a rebadged Chinese made Qinqqi scoot, so most information about Chinese GY6 clone scooters applies (this opens up a whole new world of parts and tech advice).
Your plea for help is too vague. What is happening when you try to start it?
Buzzing noise?
Nothing at all?
What did you last tinker with?
Does it turn over on the kick start?
Does it still have the side stand switch?
Did you forget kill switch?
WKDSEED
PostPosted: 14:31 - 08 Oct 2015    Post subject: Facts. Reply with quote
Hi,
I've checked the kill switch and auto choke. The side stand switch is disconnected and there appears to be fuel where it should be. There is a spark at the plug.
Could the rectifier, CDi or coil be faulty?
Thank you.
Loucas.
Bosh
wr6133
PostPosted: 14:42 - 08 Oct 2015    Post subject: Re: Facts. Reply with quote
You have a spark so issue is probably related to fuel/air.
Pull seat bucket out.
Check airbox connection to carb hasn't fallen off, it's a bad fit and used to disconnect itself on mine, when it did it would be a cock to start.
Inlet manifold will be in front of your face when you pull the bucket, look for tears.
Pull carb out and clean it.
MCN
PostPosted: 14:43 - 08 Oct 2015    Post subject: Re: Facts. Reply with quote
loucas bosh hilton wrote:
Hi,
Thank you.
Loucas.
Not likely on a new bike (but not entirely imposibru).
What year, how many miles, What sort of service history?
Battery
Capacity, Voltage sufficient (Maplins AVO meter £9 odds).
Terminals are clean and tight.
Cables connecting battery to bike and bike electrical system clean and tight.
Ignition system.
Small Low Tension
Wires clean and tight (connected).
High Tension
Big thick cable from coil to plug clean, secure, intact (no cuts, crush, wear)
For starters (no pun).
WKDSEED
PostPosted: 14:48 - 08 Oct 2015    Post subject: WR6133 Reply with quote
Hi,
Cheers for that. The spark is blue but faint if that makes any difference.
Other parts you mentioned seem fine but will double check. I think I'll go for your suggestion of a blockage in the carb. I'm just puzzled as to why it went from running mint to this without any warning. Gutted too as need to get to sixth form. Okay fingers crossed and thanks again.
Cheers.
Loucas.
Bosh
WKDSEED
PostPosted: 14:54 - 08 Oct 2015    Post subject: Checks. Reply with quote
Hi MCN,
Done those checks and all good.
wr6133 has indicated could be fuel blockage in carb.
All ideas and suggestions gladly accepted.
Thanks.
Loucas.
Bosh
PostPosted: 15:33 - 08 Oct 2015    Post subject: Reply with quote
Is the sparkplug wet with fuel after a few attempts at starting?
If it isn't, this may indicate fuel is not getting through.
WKDSEED
PostPosted: 15:36 - 08 Oct 2015    Post subject: fuel Reply with quote
Yeah spark plug defo wet with fuel.
That is why I'm so confused?
Cheers.
loucas
Bosh
Robby
Dirty Old Man
PostPosted: 15:40 - 08 Oct 2015    Post subject: Reply with quote
Is the electric start still spinning the engine over at a good rate, or is it being slow?
It just got cold. We are now entering spontaneous battery death season.
WKDSEED
PostPosted: 15:50 - 08 Oct 2015    Post subject: spinning. Reply with quote
Hi,
Yeah spinning over at really good rate; faster than my head which is spinning because it's not starting up.
Cheers.
Loucas.
Bosh
PostPosted: 15:58 - 08 Oct 2015    Post subject: Reply with quote
I'm a big fan of simply trying a new plug in. Especially with smaller engines. They get a hard time and aren't expensive.
WKDSEED
PostPosted: 16:06 - 08 Oct 2015    Post subject: Basic stuff. Reply with quote
Hi,
Too true and your'e right. I don't mind trying that if you think it may help. I'll kick myself if that's all it is. Sometimes it is the easiest things.
cheers.
Loucas.
Bosh
mentalboy
PostPosted: 16:22 - 08 Oct 2015    Post subject: Re: Basic stuff. Reply with quote
Hi,
cheers.
Loucas.
At least you've had the gumption to ask before changing the coil, HT leads, reg/rec and wiring loom and hopefully it'll cost you little!!!
WKDSEED
PostPosted: 16:35 - 08 Oct 2015    Post subject: Cheap as chips. Reply with quote
Hi,
Just picking spark plug up, £3.49 can't be bad. Will be fitted in next half hour or so. Fingers crossed. Will be chuffed to bits if it's cured.
Cheers.
Loucas.
Bosh
MCN
PostPosted: 16:47 - 08 Oct 2015    Post subject: Re: Cheap as chips. Reply with quote
Hi,
Cheers.
Loucas.
Don't just ride off and forget to update your thread if the new plug fixes it. Rolling Eyes
Smile
WKDSEED
PostPosted: 18:25 - 08 Oct 2015    Post subject: Update. Reply with quote
Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up
I'm grinning like a Cheshire cat and a big thumbs up to you all who chipped in with advice, thank you.
It was the spark plug, howd i not get that.
back to running like a dream so 'big up' to you all.
Special mention to 'stinkwheel', cheers.
Thanks again all.
Cheers.
Loucas.
Bosh
PostPosted: 12:29 - 09 Oct 2015    Post subject: Reply with quote
Fistpump!
https://s-media-cache-ak0.pinimg.com/236x/1a/4b/63/1a4b639e61e312ad0df19e45488deae0.jpg
The last post was made 10 years, 330 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 102.59 Kb
