Think my Volvo t5 is terminals deaded
sidewinder
PostPosted: 21:48 - 10 Oct 2015    Post subject: Think my Volvo t5 is terminals deaded Reply with quote
So coming home tonight my Volvo t5 started to make some strange noises from the motor and was gradually loosing power.just about limped it home when it completely died.left it a few hrs and went out to see if it would fire up.its turning over just.on inspection I have noticed a lot of oil around one of the spark plugs where they screw in ..i know it was not there last week due to changing the plugs..any ideas or is it fucked it's the 2006 2.5 turbo with a polestar tune..
CBRMAN94
PostPosted: 22:47 - 10 Oct 2015    Post subject: Reply with quote
Find out where the leak is coming from. It might just be the rocker cover gasket leaking. Oil around the plugs can cause misfiring causing lack of power.
Honda CBR-RW6 (Sold) - Kawasaki GPZ500s (Sold) - Honda CG125 (Project) - Honda CB750 Cafe racer (Project) - Yamaha FZR400RR
sidewinder
PostPosted: 23:13 - 10 Oct 2015    Post subject: Reply with quote
It's a lot of oil looks like it's coming through the plug threads themselves..rocker gasket is bone dry
iooi
PostPosted: 08:25 - 11 Oct 2015    Post subject: Reply with quote
Then you have either stripped the threads or not tightened then up enough.
sidewinder
PostPosted: 10:05 - 11 Oct 2015    Post subject: Reply with quote
Threads are fine..that doesn't explain. Why there's oil coming out the cylinder through the plug hole though...
sickpup
Old Timer
PostPosted: 10:51 - 11 Oct 2015    Post subject: Reply with quote
Spark plugs have a sealing washer so there shouldn't be anything coming out of there. It may be that the head has cracked between a plug and valve, this is repairable but not cheap.
bugeye_bob
PostPosted: 12:39 - 11 Oct 2015    Post subject: Reply with quote
any signs of damage to the ceramic part, if the threads are all ok its the only place it can really get out.
sidewinder
PostPosted: 14:11 - 11 Oct 2015    Post subject: Reply with quote
I think sic pup is onto something seems to be a common issue with the heads cracking Sad .also the cylinder liners are known to crack.looks like it's head off for closer inspection.
sickpup
Old Timer
PostPosted: 14:54 - 11 Oct 2015    Post subject: Reply with quote
Conveniently I also know an extremely good volvo head man.
sidewinder
PostPosted: 20:55 - 11 Oct 2015    Post subject: Reply with quote
We have some really good enginge builders and engineering company that can do the work. If it's not repairable I'll get a new one. Might be worth getting it gas flowed and ported.might even upgrade the cams and valve springs as well..
The last post was made 11 years, 39 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 63.7 Kb
