Where to begin with ground up restoration
Poseidon
PostPosted: 20:46 - 12 Oct 2015    Post subject: Where to begin with ground up restoration Reply with quote
Evening all,
The triumph in my sig is now the top of my list with regards to vehicle priorities (the car now being fully functional and MOT'd for the next year). However there is a couple of issues. Firstly is monies. I haven't the funds to be buying all the shiny new parts I want just yet (new zorsts, hagon rear shock and touring seat). Secondly, it lived outdoors under a HG cover, motionless for 18months after it developed starting issues (in that it doesn't anymore).
When I bought the bike, it was for peanuts, sold as seen, needing repairs. I spent around £100 getting it through an MOT and it ran sweet as for 3 years. There was always lots of little bodges the many previous owners had done to her that steadily unravelled themselves (my favourite being the silicone sealant on the fork dust seals in what I can only presume was an attempt to stop the oil seals leaking), so when the starter motor finally gave up, it was shelved until I had a garage to work on her. I now have a garage and (some) time on my hands.
Where do I begin? She rolls fine, the motor turns if given a push in gear, although I've not bothered going for the full bump start. The brakes are probably knackered, but I have calliper rebuild kits for front and back, so I can sort that easy enough. The throttle cable is jammed almost solid, so will need replacing and everything else hasn't really been checked.
Bearing in mind I won't have the fundage for any major new parts until the new year, should I leave her in her current condition until I can source all the relevant parts I need (I'll be checking the engine out, clearances, new sprag clutch and all that jazz on top of the rattly alternator and kaput starter) and do the whole thing in as short a space of time as possible, or should I start a piece by piece approach?
I want to strip the whole thing down to the frame and get her back to decent condition, checking all the bearings/bushes/seals as I go and I'm worried a little by little approach over 6 months or more will result in a great many parts that I lose track of, or forget where they go. Whereas if I go the whole hog, when funds allow, I can strip down, do an inventory and rebuild in a short enough space of time that I should know where everything came from. The flip side would be that I can strip it down now, do it a little at a time with the limited free time I have and build up a list of parts ready for when money is available.
And as I've never stripped a bike down completely, where do I begin? Once I have a decent set of photos detailing where each part goes, do I just strip it down in a logical order, or is it better to work from front to back etc?
The bike has huge sentimental value for me, so once money is available, I'm not at all worried about it costing me more than it's worth in the long run.
Cheers all
Poseidon
1977 Honda CG125
pompousporcup...
PostPosted: 21:19 - 12 Oct 2015    Post subject: Reply with quote
Fwiw, strip it down slowly. Picture everything and bag it all up and label stuff meticulously. It's very easy to strip a bike down but a lot harder to put it back together not knowing where things go
If you're going to keep it for the foreseeable future, replace the bearings and sort the frame out and get it rolling as a nice clean frame..everything else will come together as and when you can
Just 2p from experience striping and rebuilding cars. Currently have a bike in that situation
Suntan Sid
PostPosted: 23:22 - 12 Oct 2015    Post subject: Reply with quote
As above, I'd say strip down to component parts.
Presumably there's a manual for it, the much maligned Haynes, would do the job.
No doubt there will be parts that need replacing that will be, infinitely easier, to replace with the bike in bits. Even if you're not going for a repaint, it makes it much easier to clean.
If you're prepared to put the time in, not rushing to get it finished, it will be a very rewarding experience.
Take loads of photos, as you're going along, they will be invaluable, filling in the gaps the manual will leave.
If the wiring's been botched label everything, before you pull it apart, could save hours of head scratching, make a very close inspection of the loom, it's really easy to miss a bit of worn away insulation.
Go for it, you'll enjoy it more than you think!
Ariel Badger
PostPosted: 23:29 - 12 Oct 2015    Post subject: Reply with quote
Do not start to strip it until you have the cash to put it back together. £4K at least. If you strip it now what will you gain? Parts will get lost, your new tyres will develop flats and crack etc.
temeluchus
PostPosted: 00:22 - 13 Oct 2015    Post subject: Reply with quote
Replace all o-rings and gaskets in the carburettors, check the condition of the slides, replace all of the emulsion tubes and the needles.
Teflon-Mike
tl;dr
PostPosted: 01:52 - 13 Oct 2015    Post subject: Reply with quote
I start knocking one back to the frame.
Parts that come off, get inspected / evaluated and stacked for later attention, or listed for replacement.
Forks and brakes come in for particular scrutiny; if the chromes has gone on the stanchions, whole job could be in question; if the sliders are in a rough shape, and there's any evidence of botchery where seized callipers have been removed or the callipers themselves are a lost cause, then new parts, if obtainable could be prohibitive to the project...
That's my first 'break-point', and 'drilling-down' to establish whether I can make a serviceable business end, may mean that the forks and callipers get stripped and overhauled before I turn attension back to the frame to bolt them to.
Back to the frame, after revealed i all its glory; That gets checked over; sheared screws drilled out; lock-stops hammered straight, built up with weld, that sort of thing; if needed, then painted.
That gives you something to bolt all the other bits to as you tackle them; and sort of suggests an order to it.
So having sorted the front end; I strip and paint the fork-yokes; fit nice new taper-roller bearings to the head-stock, ready t attach the front forks, which I have already 'done' or have framed as a 'job' to be done.
'Cos forks 'on', can slap the front wheel in, even if it's got no tyre or brakes, and prop the whole plot up on the centre stand, as I turn attension to overhauling and attaching the back end, so that it can also be wheeled around, as well as propped up!
Wheels probably get attention at this point; but tyres can wait 'till last. New bearings might get fitted, with new seals, but sorting nigglies like speedo'drives and sorting cush rubbers can be tackled., along with them brakes.
Engine? I tend to leave until almost last. I might do a quick run-up to get some confidence it shouldn't need much attension, but you'll ever know till the jobs jobbed anyway, and pulling a lump out is only eight bolts or so in most cases... no point get all exited about it, and rushing the rest of the job to hear it runing....
Body-Work? way down the list of priorities, as far as I'm concerned; you can live without such nicties as side panels or mudguards entirely, so no point making them all pretty n paint, util you have something that deserves them bolting to it!
One bit that gets attention, early on is the tank. Dealing with post-resussitation niggles; cleaning carbs from the silt dislodged nside a rusty tank, after its pressed back into service, is a ball-ache I can live without; findg the bike in a pool of petrol from a pin-hole, that's erupted after resuscitation, and either handling or preppig for paint, or or or just shaking, sat over an engine thats now runing and making the metal vbrate the rust loose, is a fucktard bastard! Especially f the petrol runs nice new paint applied during resto!
SO.. once I have the rest 'in-hand' and I am past the point of no return, committed to the build; I tackle the tank; back to bare metal on the outside with rotary wires, then lots of water flushes to wash out as much silt and shit as I can to start with; then a vingar soak, followed by a caustic soak; loosen up any more flakey rust and crap; then plain water flush... then an electrolysis 'de-rust', over night on the battery charger.... that, hopefully will burn out any rust pin-hole's that the tank is likely to aquire.. so I flush the electrolyte, and then let the tank 'oak' for a day or so, with water in it, checking the level and looking for drips!
THEN it gets a POR15 treatment, which involves another caustic wash, and an etch pickle, before the lining treatment is applied; that takes a week to cure to 'petrol hard'.. and with the washing and flushing up front, its a job that stretches out over a week or so, 'waiting' for soaks to be ready to change ad stuff.. so needs to be tackled earlier on so it doesn't hold up the end build.
But, with bare tank, treated, logical, to have panels, and mudgards and stuff, to paint when you paint the tank, so, prepping side-panels and the like, is a good gob to do i those waiting periods
Its that sort of 'organisation'.
As to having the cash up-front before tackling the job? Well, the bills get very big, very quick, and there is ALWAYS something needed you don't know about until you start putting it all back together...
And there's LOADS of work to be done, where parts aren't required; usually horrible nadgery ones, and lots and lots of cleaning and sanding and wire brushing....
Even if you start with a big box of bits; you will be dealig with plenty of sub-assemblies like forks or brake calipers, or suspension links, that are either holding up 'the build' while you tackle the sub-assembly, or if you tackle the sub-assembly, that's sat in the shelf waiting for 'the build' to catch up.. and likely a mixture of both...
Bottom line, It ENT going to all happen in a week-end!
But, I like to get 'ahead' on as many sub-assemblies, like brake callipers, or recovered seat, as I can, so that they are sat on the shelf ready when the 'July Offensive' is ready to press ahead and see the build leap forward towards that final 'de-niggling' when you start threading control cables and trying to mate electrical connectors, or are try to get lights to work when they should, and swapping coil connectors over trying to get the motor to fire...
If you are confident the build is viable, or committed to it, before tearing down to the spine; then no reason, particularly this time of year, you cant be getting on with smaller assemblies like that, ready to stack.
But that be your call... ultimately, there's no real right or wrong way about it, just more or less 'efficient' ways about it, and lack of organisation and forethought will lead to as much chaos and confusion in a short build, as a long one...
Best of luck....
Diggs
PostPosted: 07:56 - 13 Oct 2015    Post subject: Reply with quote
Speak to this man:
https://m.facebook.com/profile.php?id=824782640921802
He runs 885 rebuild courses for £70, and your engine is a sleeved down version. Although I haven't been on one yet I am reliably informed that they are excellent and cover a full strip-down and rebuild including the sprag clutch.
It will be the best £70 you can spend and will save you thousands in the long run...
Now - Speed Triple, old ratty GS550, GSXR750M
Gone (in order of ownership) - Raleigh Runabout, AP50, KH125, GP125, KH250, CBX550, Z400, CB750FII, 250LC, GS550, ZXR750H1, Guzzi Targa, GSX750F, KH250 x2, Bimota SB6R and counting...
davebike
PostPosted: 08:16 - 13 Oct 2015    Post subject: Reply with quote
Beeing an old sinical professional mechanic
I want to see it run before I spent time and money on it the early Triumphs are Known for starter clutch failures and a dead one is a total engine strip
Get a charged battery a car one or even the car is good and some jump leads
Start the bike up and see it runs revs and idles
Dave
NC750Xdct + others at work !
[email protected]
Diggs
PostPosted: 08:27 - 13 Oct 2015    Post subject: Reply with quote
Clive Wood's next course is on 21st November in Lincolnshire and costs £75....
bladeblaster
PostPosted: 08:43 - 13 Oct 2015    Post subject: Reply with quote
Being in the process of several rebuilds, this is how I plan to go about the next one.
First decide what you are trying to achieve, full money no object restoration back to original, basic functional rebuild back to standard, money no object trick it up rebuild, etc etc. Decide if you are going to rebuild the engine, or just tart up the outside.
Then start stripping and cataloging.
Separate parts into categories such as, bin for new, sand blasting, re-plating, powder coating etc.
Start listing the new parts you need at the same time, seals, bushes, bearings, cables, etc etc.
This is a looooong job if done meticulously.
Once you are down to component parts, they you can start getting things back together, my preference is to get a rolling chassis together first. Get everything you need to get the frame, swing arm, forks & wheels assembled. Once you have that, then tackle the engine and get that back in the frame. Once you have that get the bare essentials together to be able to fire the engine up and make sure everything is running as it should. Once you are happy with that you can start on the frilly bits such as body work, pegs, etc etc.
That's how I would do it anyway.
mudcow007
PostPosted: 14:43 - 13 Oct 2015    Post subject: Reply with quote
Im in the same boat at the moment check out my DT thread
Mine is missing loads of bits, so my plan is to strip the engine down to component to see how much damaged has been done, if i find (much) damage then i will just prob write the whole thing off.
Keep an eye on eBay, you can still get the occasional bargain, also check foreign ebay's too like Germany etc...
Poseidon
PostPosted: 17:18 - 13 Oct 2015    Post subject: Reply with quote
Diggs, cheers for that info, sounds like it will be worth my while getting onto one of those.
Dave bike... Mine is one of the early silver engined ones, with the access panels for the sprag clutch, so that will ease the burden a little. Bearing in mind I ran this bike as my everyday commuter for nigh on 3 years, I know, love and trust this bike. It will be rebuilt come what may.
Sid, I know there is a workshop manual available for the T300 triumphs. Just need to get my mits on one. Already have the haynes jobby (came with the bike).
Blade, I know what I'm after in terms of rebuilding. I want to rebuild this bike into the machine I want. Not talking concours here, more personalised to my tastes and needs.
Thanks for all the info folks. Great food for thought. Ariel, you raise a good point about the amount of money needed for this sort of thing. I did price up all the replacement/upgrade parts a little while ago (including replacing almost every bearing/seal/bush) and it came to just shy of 1500. Reckon I'll budget for at least double that for the parts I don't even know need replacing yet. It seems the consensus is to take a softly softly approach to the strip down at least. I need some racking at the very least to keep things in some semblance of order.
1977 Honda CG125
stevo as b4
PostPosted: 20:16 - 13 Oct 2015    Post subject: Reply with quote
It has to be if the bike means enough to you and is sentimental to warrant a large spend on it?
No resto is cheap, My KMX125 would have had around £3K spent on it to do a full restoration, and I've since spent around £1k on new parts, finishing stuff off and aftermarket bits etc.
I did not read you thread properly at first and assumed your Trident was an old T160 model instead oops! One of those would definitely be worth restoring, and to a total British bike novice like me, I would in some ways quite like the idea and the challenge of working on something I have no experience or idea about.
A 94 trident to me is less of a worthy resto project, supposing you are wanting to make it cosmetically really nice and not just a good rider?
There's probably a fair few T300 bikes out there still, and some will be A1 Minter's. Buying such a bike or an already restored one will always be cheaper than doing your own bike.
My KMX125 cost well under £2K, but as I said it must have easily had over £3k spent on it to get it looking good, so unless your particular bike is very important to you, then it's something to think about before you start the resto?
Poseidon
PostPosted: 20:26 - 13 Oct 2015    Post subject: Reply with quote
You can pick up the 750s for £1500 in working order, but by the time I've put the exhausts I want on it, upgraded the suspension to the ones I want, got myself a comfy seat, you're talking about a grand, and that's assuming there's no other nasties lurking in there. This bike was my first motorbike. Ever. I love the beast. Cosmetically, I want it clean, but I'm not after perfection. It will be a working bike and used as such. Hence why I'm willing to embark on this project.
1977 Honda CG125
Ed Case
PostPosted: 09:21 - 14 Oct 2015    Post subject: Reply with quote
Unless the bike is something ridiculous like a Vincent or an equivalent 'classic' the cost of a thorough restoration is frequently more than the thing's worth. The bloke who buys it off you when you sell is the man who gets real value for money.
Robby
Dirty Old Man
PostPosted: 18:36 - 14 Oct 2015    Post subject: Reply with quote
Work on one sub-assembly at a time. Start with the ones you're most comfortable with, then tackle the more difficult ones as you build up experience.
I assume your pricing for bearings/bushes/seals was based on Triumph prices. You're not pressed for time and you'll be taking the bits off. That means that for common sized parts, like bearings, you can measure what comes out and buy the bearing from a bearing shop. Same part, fraction of the price. There may also be some cases where the OE fit is a shitty plastic or nylon bush, and you can instead fit a brass one, or even a needle roller bearing with a grease nipple.
Also I think your seized throttle cable is in fact a seizure at the throttle shaft - either on the shaft itself, or the butterflys corroding against the carb body. A good twist should free it off.
Don't go too crazy on it, or you'll never finish. The first thing you'll learn is just quickly you can remove any major component. This means you don't need to restore every bit just because you have it apart. If the frame just needs a new set of head bearings, don't go replacing every bearing and bush in the entire frame and swingarm.
Poseidon
PostPosted: 21:31 - 14 Oct 2015    Post subject: Reply with quote
Perhaps restoration is too strong a word. Rebuild with customisation is a more accurate description.
Ed, I get what you're saying. I heard once that if you buy a minter bonnie from the 60s, strip it down and sell the component parts, you'll make money. But this bike isn't going to be a show piece. If I bought a pristine trident for £1500-£2000, I'd still want to spend about another grand on top of that doing the bits and bobs I want to do to it, so would be shelling out 3grand-ish. Instead, I'd rather spend that money getting mine into tip-top order, with all the upgrades I want. The bonus being that this particular triumph is the one that has a special place in my heart. She deserves this level of treatment! (and I won't ever sell it! Ever!)
1977 Honda CG125
Teflon-Mike
tl;dr
PostPosted: 23:03 - 14 Oct 2015    Post subject: Reply with quote
This is where we start deliberating over powder coating....
You get it down to the frame, and you start looking at it... and well, 'Powder coating'.. its what you do, isn't it? And you look at all the awkward brackets and cranies where getting 'in' with a rotary wire is going to be a bit awkward, and you price up powder coating, and having the frame 'done' is 'only' £50 or so, including shot-blasting... pot of smooth-rite is £20.. this has to be the way to go... hasn't it?
Only.. you DO have to pull all the bearings and bushes from it, before it goes for coating... and you start swearing, as you crack nylon bushes and snap plastic inserts and look at bearings and think, "Is it worth putting that back in"... but you carry on....
And one or two things happen; first, you fill a few stack-a-boxes with other bits you 'might as well' get coated whilst you are at it; swing-arm, pillion rest hangers, battery clamp, brake arm, centre stand, side-stand, etc etc etc.... and the 'bill' when you get it back, is more like £500 than £50... 'cos they charge £5 per part, cos its the handling of them as much as the size, and you have given them a LOT of little bits of metal... that in some cases might not eve cost a fiver to replace!
Second thing; you get back your frame, and start to bolt stuff to it, and looking so fresh and new and shiny... "I cant bolt this manky old bit on here!" The finish on the frame showing up the lack of on everything else.... and if you avoided filling the stak-a-boxes for the coaters to start with... you do now! And that 'old' bearing you pulled out... if you can find it... you dont want to fit, and you definitely want to replace... "Why spoil the boat for a hapeth o'tar?"
And, the list of 'new' parts grows, and the job grows as more and more bits fail to pass muster, too scruffy to bolt to this 'work of art' frame, and come in for closer attention, and more detail renovation... and work and costs and time start to spiral..
USE SMOOTHRITE!!! Laughing It' ent as good as it used to be, since they changed all the paint regs; but! That £20 pot, goes a LONG way! You can do the frame, and the swing-arm, AND all those brackets and bits you'd fill the stak-a-boxes with! You can paint round bearings and bushes and inserts, and you can 'touch up' if it gets scratched, when you inevitably 'slip' with the screwdriver and put a gauge that lovely nice 'finish' that's been applied! And most of it wont be seen when the build's done; most will be covered by body-work, and few folk will pay much attention to a brake-arm!
For a 'practical' classic that's going to get used; rather than a show-piece for meets and shows, (Where applying 'better than factory' finish, like powder coat, can start loosing you credits, in some cases) Stuff has a lot of merit... and one of the hidden ones is in keeping the job in check, and not pushing perfectionism and over-ambition.
This is a crucial point in the planning phase; setting a project 'philosophy', not just what you want to achieve, but how you want to achieve it, to help steer decisions, like, whether to go powered coating or stick with pots brushes and rattle cans... it's also a point of discipline, sticking to it, and not letting things spiral and the project take a completely new direction......
Or mine.... mine was in a slightly more 'viable' state when I got it.. , for a start, it actually ran, roughly, but it ran... and it only cost me the price of a pair of tyres for the 750, so my Project Philosophy had been it would be a bit of 'pocket money fun' to scrub it up, chuck some hammerite at it, and spend a few quid on connectors and bulbs to give it some electrics, touse as a trail toy..... until I decided to get the frame powder-coated! At which point, it 'morphed', from a 'cheap' scrub-up and turned into a much more detailed, much more expensive full-on resto...
Do as I say, not as I do? Nah! There's no 'Rules'.. end of the day, its your project, it can be whatever you want it to be, and the 'build' will lead you, as much as you ever try and lead 'the build', regardless...
The KEY if there is one, is to know when its leading you, and when you are leading it, and where it can start taking you places you never origially thought to go or wanted to go.... whether, you decide to go there, once the build has lead, tempting you towards them, and whether you are glad you went there or not, at the end? Well, all part of the 'fun'; Its all about weighig up those decissions, and making them, that 'make' a project.. other wise you might as well just get an Airfix model and just follow the instructions.
"Failure to pan, is a plan for failure" has truth; but 'good' plans aren't the most detailed, and rigerouse; they are the most robsust, and that HELP... there has to be room in the plan for change, its going to happen! Plan to plan, and plan to change that plan, as circumstances direct. This is not making it up as you go along, its planning to change the plan, when needed... trick is to know when changing the plan IS needed, or is more 'helpful'...
And, bottom line... a pile of scrap cant be 'planned' into a working motorbike.... at some point you have to bite the bullet, and get busy with the spanners... and and start adaptg that plan, as needed as you discover what the spaners reveal...
So ^^^^ is possibly ENOUGH of a plan to be getting started.. as Robby says... bite the bullet and dig in.. pick a place and get the spaners out.. do the seat, or do a brake caliper, or tackle that starter clutch... and GET ON WITH IT
I dont have the luxuary of a kitted out work-shop; I dont even have a garage! Racking?!? Yeah, be nice, but its NOT exactly critical to the project! Plastic-Bags, stak-a-boxes, and a bit of space at the back of the shed or under the stairs! IMPROVISATION! COMPROMISE! It works... might not be ideal, but, little is; we have to work wth what we got, and make the best of it. And from what you have said so far, that is where your first hurdle lies.. even the question at the top, "Where do I start?".. you just dont know; and you are looking for any diversion to NOT get started, rather than picking up a spaner and cracking the fuck on with it... somewhere... ANYWHERE..
Its ALL got to be done in the end... doesn't really matter exactly where you start.. (Or indeed 'finish'!?! As long as you do!)
Pick a bit.. look at it, what can you do with it? What do you NEED to do with it? HOW can you do it?.. treat that BIT as a 'project'... and plan what to do with it... THEN go back and pick another bit... pretty soon there will be a pile of 'bits' all 'done', and the project is making progress.. not stalled whilst you try and plan for ALL the possible unknowns and possibilities and permutations, until doomsday!!!
Eat the cow one steak at a time..
Kawasaki Jimbo
PostPosted: 20:46 - 15 Oct 2015    Post subject: Reply with quote
[quote="Poseidon]this particular triumph is the one that has a special place in my heart. She deserves this level of treatment! (and I won't ever sell it! Ever!)[/quote]
I get this! I now have a garage so my 60,000 mile, '99 ZX6R is having a long-anticipated and mainly cosmetic refurb. I'm trying to avoid the urge to go concours on it, I just want to take a few years off. I could buy a very low mileage, immaculate, road-ready one for less than £1500 but it wouldn't be quite the same.
Poseidon
PostPosted: 21:04 - 15 Oct 2015    Post subject: Reply with quote
I'm not what you'd call a neat freak, but I do like having a place for most things and most things being in their place. Not a fan of stack-a-boxes and the like and garage shelving that'll hold over a metric tonne is quite cheap nowadays. Improv will most likely be avoided if at all possible.
As for the diversionary tactics, I wouldn't go that far. My car received an MOT last week, having spent a couple of months in the garage awaiting some free time to do the necessary. This is the first time I've had the time available for a project. The thread title was more a "I don't want to be left standing in my garage with a load of parts in one hand and scratching my head with the other, wondering what the merry hell the next move is". I'm tapping the collective years of experience in stripping bikes down and rebuilding them that this forum offers. I want to do this right.
1977 Honda CG125
Ed Case
PostPosted: 22:18 - 15 Oct 2015    Post subject: Reply with quote
If it's a bike that you have no intention of selling for the foreseeable future then it's worth really 'going to town' on the job 'coz you'll be getting pleasure for some years and you'll be chuffed you did it. Best of luck, let us know how you get on.
Teflon-Mike
tl;dr
PostPosted: 01:17 - 16 Oct 2015    Post subject: Reply with quote
Lol! Sorry, but that IS 90% of a 'project', I think!
I have at least one project 'on the go' constantly, and have done as long as I can remember! Last few years I've averaged about one full ground up project-bike a year.. NOW picture this...
I have had my Montesa Cota, since I was 15.. thirty frigging years, come February! It's first and only (Daylight) MOT had just expired when I bought it... [sigh].... Anyway; back in 1986, I did a couple of trials schools on it, and a few practice sessions, one comp event, then another practice session, WHERE I fell out of a skip!?!?!? a-n-d snapped the frame! THAT prompted the first 'rebuild'...
Now, there's not much to a twin-shock trials bike, really. No street-gear, so no lights; the entire wiring loom is a single strand from the magneto to the coil! And the rest of the thing, is pretty much as 'minimalist'. Air-Cooled piston-ported two-stroke, doesn't even have a reed-block!
SO, that rebuild wasn't too challenging for me as a teenager, after I got the frame back... and twenty years of regular 'service', it got a detail build before every new season, and a pretty thorough strip and 'inspect & prep' before each trials meet...
SO! You would expect, I know that bike pretty intimately, and OUGHT to be able to almost strip and rebuild it blind-fold like a squaddie with a Bren-Gun!
And it's a NICE bike to work on. As said, there's bugger all to it, and rebuilt approx once a year for competition, I get a little 'fuzzy-warm' every time I go to undo, say the exhaust, and I'm NOT cursing or swearing at seized, mismatched bolts, and they just undo, and instead of rust, have a little pink trace of coppa-slip on them, and I think "THIS is why I paid that attention when I put it together... last time"
YET... even with all THAT experience of THAT particular bike, I have probably spent more time, wandering up and down the garden, waving something as 'simple' as a plastic mudguard, or vexed by something as 'silly' as a split-pin, bum my hands, wondering what to do!
Doing the DT, few years back; I was quite pleased I got the thing down to the frame, in about a day, and quite surprised that I had very few nagger-busterd-bits, and arguments with rounded and chewed screws and bolts.. but then just ONE redressed that balance!
The rear shock pin, was bent. Nut came off the end easy as pie, but would that fucking pin shift?! I had moles grips of it tryng to make it twist, I hit it with heat, I hit t with a hammer; I left it to soak in plus-gas! I tried attacking it with a drill, a hammer drill, the angle grinder EVERY bludy tool in the box, got looked at to see if it could help!
Being a suspension pin, it was hardened steel, so it had resisted the hack-saw, which was about the only tool that would get 'in' at t between the shock-absorber and the swing-arm.. if I hammered the shock over far enough to one or other side.. THAT one prolem was probably the most time consuming niggle of the whole build, an entire week, MOST of it, doing no more than look at the bludy thing, swear and ask "HOW the HELL do I sort THIS?!?!"
In the end, came down to a shit load of elbow grease and a LOT of hack-saw blades.. and I won... in the end... eventually.. but a WHOLE WEEK, to get one pin out of the thing! and most of that time, bum in hands, wondering how the heck I could do it.
I'm Doing another 125 Super-Dream at the moment; this is, the, err, fifth one of them, I think; again, I should know them pretty well, and where to expect the hassles, how to avoid them, and how to tackle them, B-U-T? The 'niggle' of the wobbly center stand, had e bum in hands, wandering around the garden, faffing for a week or more! Stupid little niggle; the centre stand pin rusts into the stand, then instead of the stand twisting on the pin, it twists the pin i the frame, and the lug wears oval, and the stand goes wobbly.. BUT, seized in the stand, you have to cut the pin to get the stand off the frame, and then you have a stub of stand-pin left in the pressed steel stand to try getting out, before you can try and make a new pivot..
These are the sort of hassles you have to contend with; you wont know which you'll have to cope with before you begin, or how big a hassle they are going to be.. you just have to know that they WILL happen, and plan to plan for them when you find them...
And THAT is when you'll be stood, holding some awkward bit in one hand, stopping the bike toppling on you with the other, wondering "What the fuck do I do now!"
If you tackle the project, it WILL happen. IF you don't want it to happen? Don't do a project!
I am trying to think of a single project, in the last twenty years, that has surprised me by just 'going to plan' and not offering something to vex me along the way... and I'm really struggling!
Closest, I think was doing an engine swap on my Rangie; my Rangie was a 'rare' 3-speed auto, donor engine came from a more common manual, and I expected a bit of hassle, swapping the flywheel for a torque converter and changing adaptor plates for the gearbox/transmission... BUT, went like a dream, and I had the engine all dressed and swapped in a week-end... but the bugger wouldn't start! Defied EVERY bludy attempt to get it running.... turned out that donor motor had a slot drive for the dizzy, my motor had a pin.. so the cam was turning the dizzy gear, and the slot was just turning quite happily without turning my dizzy.... and I couldn't use the door motors dizzy 'cos it was points, where my engine was ECU! Again, more time, sorting that niggle, and engineering a drive adaptor, than actually swapping the bludy engine!
So, benefit of my experience? There will ALWAYS be "something" to leave you scratching your head, wondering what to do, and why you started all this in the first place.. embrace it, expect it, that IS what makes the project; hitting those hurdles, and working out what to do next. There's no achievement in the routine, the mundane or the 'easy'. Its those hassles that challenge us, and its rising to those challenges that reward us, in the achievement, when it's all over.
We cant give you a set of instructions to do a resto, all we can give you is clues, and WHEN you get stuck and are scratching your head, THEN, maybe offer some suggestions...
BUT, here and now; where to start; pick up a spanner; pick a bit to tackle and JUST 'make a 'start', some-where.. if or when you are left scratching your head.. well, deal with that as it comes..
But to get you as far ahead and prepared for that as we can... the first suggestion when that happens is...
Put it down, put the kettle on!
First rule of mechanics that! A Hot Cuppa is as yet the closest yet to the universal-solvent! Take a break, have a cuppa, come back to it with fresh-eyes. amazing how many solutions a cuppa provides!
Poseidon
PostPosted: 16:43 - 16 Oct 2015    Post subject: Reply with quote
Cheers. Not sure I'll do a project thread, but I'm sure I'll be posting up with updates once things start moving.
Tef. Thanks for the words of encouragement. First job tomorrow is getting the garage into a fit state for working on a bike (floor needs sweeping and kids bikes/toys need stowing away), leaving me with plenty of space for the various bits and bobs that need to come off. Second job is stripping of the knackered bits that I know I'm going to replace, starting with the downpipes, the horns, the pillion footrest hangers and the seat. From there, I'm not sure where I'll go, but I'm sure I'll figure something out. Reluctant to strip the front end as I want to be able to move it as and when, so that may wait until I have the replacement stanchions (current ones had the stinkwheel patented araldite treatment). I might attack the swingarm to see what I can do about the cross threaded bolt on the eccentric adjuster (previous owner), although this too will render the bike motionless. Hmmm, decisions, decisions... I'll go pop the kettle on and maybe let the bike decide.
1977 Honda CG125
The last post was made 10 years, 336 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.26 Sec - Server Load: 0.97 - MySQL Queries: 13 - Page Size: 158.85 Kb
