New battery
Bomberman
PostPosted: 11:52 - 09 Feb 2005    Post subject: New battery Reply with quote
Ok, I got a new battery for my bike in an attempt to fix the electrical problem I've been having.
Two things though;
It's a dry charged battery, and as such can be used straight away according to the slip of paper that came with it. However, it warns against this, suggesting it be charged first. How much is this going to affect the batteries life? (Considering I have no charger, and can't afford to get one Rolling Eyes)
Secondly, it came with some acid. The acid is in a sort of quickloader (like a revolver sort of) which would fill all 6 cells at once. But it doesn't fit Sad So. Any suggestions? I'm not sure where I'd find a glass funnel, would I get away with a plastic one (unsure as to the strength of battery acid, but I assume its not safe to drink Wink). Or does anyone have any ideas/ suggestions of how to safely get the acid in?
Cheers Very Happy
PostPosted: 11:59 - 09 Feb 2005    Post subject: Reply with quote
You can use then immediatly and they will still last a fair while. Probably knocks a year or 2 off the life. Also leave the battery to stand for a while after filling it up.
Normally with these batteries the acid comes in a strip of bottles that you push hard into place, which punctures the seals on the bottles. Then just leave it draining in for half an hour or so.
Suspect a plastic funnel would be OK (after all the acid comes in a plastic bottle), just don't use it for cooking afterwards.
Bomberman
PostPosted: 12:08 - 09 Feb 2005    Post subject: Reply with quote
Cheers Kickstart, I figured it would be OK to use immediately, I guess they're just covering themselves.
It is indeed a strip of little bottles, but the battery for my TZR is about the size of a square 9v Very Happy The strip of bottles is way to long. Typical.
As to the funnel. I used the same logic as you, but then I got worried about special plastics for acids etc. but think I may be overcomplicating.
Cheers mate Thumbs Up
PostPosted: 12:56 - 09 Feb 2005    Post subject: Reply with quote
WEAR GOGGLES!
Battery acid is nasty stuff. I have seen loads of people filling batteries without goggles on and it is just bloody stupid.
Seems funny to give you the acid packaged in those little bottles when they don't fit. If you get the bottles there is usually a spike on the opening of each battery cell to pierce the seals. Could it be that the battery only needs a couple of the bottles and you just need to snap them off the strip like a bar of chocolate?
I have visions of strong sulphuric acid splashing everywhere as you try to get it out of the bottles, they are really designed to drain directly into the cells, if you can find a way of doing this, use it.
ts50x0
PostPosted: 13:36 - 09 Feb 2005    Post subject: Reply with quote
if your not going to charge it make you let it stand for at least an hour should be more after youve put the acid in as kickstart said, just to make sure you do it as this is important, hasnt one of your mates or anyone got a charger as it is definatly better.
Bomberman
PostPosted: 14:53 - 09 Feb 2005    Post subject: Reply with quote
Stinkwheel, understood Thumbs Up I've taken the acid out of its package now, and ot only do they not fit, but they require penetrating by the battery, and there's nothing on the battery holes that would do this as far as I can see (further investigation reveals that thy won't fit in the battery holes anyway). Also, it'll use most of the acid but not all by the looks, so if I were to (assuming I could, which I can't) use it as per instruction, the battery would be overfilled.
The containers themselves are quite rubbery and would not snap apart, but there's ample room to cut them from each other I think (although again, I don't like the idea of running a knife between two bottles of acid Thumbs Down).
Best plan so far seems to be - Goggles, Heavy Gloves, cut apart bottles, pierce bottle tops with blade, use small funnel. I don't see that I have huge alternative to be honest.
ts50x0 I have no access to a charger full stop mate. None of my mates are mechanically inclined at all, let alone bikers Rolling Eyes I would if I could, trust me Smile
It does detail to leave the battery for an hour, so I'll follow that Thumbs Up
Scotsman37
PostPosted: 14:58 - 09 Feb 2005    Post subject: Reply with quote
stinkwheel wrote:
WEAR GOGGLES!
I remember working for an electronics company many years ago when health&safety wasn't really their strong point. Even if there's a very tiny drop hot/cold sulphuric acid on a surface some where and you touch it accidentally say while wearing nylon clean room gloves and watch those gloves disappear right in front of you ! Then you need to wash you hands quickly! Confused
PostPosted: 15:22 - 09 Feb 2005    Post subject: Reply with quote
Rather than faffing round with the acid bottles, take the battery into a local bike shop or maybe even decent old car garage and just get them to fill it with acid for you. They will probably have a drum of battery acid and will send the YTS trainee off to put on the goggles and heavy duty gloves to do it for you.
They will probably charge you, but probably less than the cost of the trousers you wreck when you spill acid on them.
Sounds to me like someone has messed up and given you the wrong acid bottles for the battery you have.
Scotsman37
PostPosted: 15:34 - 09 Feb 2005    Post subject: Reply with quote
If he had bought the battery say at a Hein Gericke shop they would fill it for you at no extra charge !
Bomberman
PostPosted: 15:47 - 09 Feb 2005    Post subject: Reply with quote
Well thanks for the concern, however that was pretty smooth. Hair raising, but smooth, and my trousers remain intact Thumbs Up
But I now have a new problem. As I surmised, there's simply too much acid. So I have one and a half bottles left (one of which is obviously open and unresealable. What do I do with the stuff? Is chucking it down the grate in the road unnacceptable like with oil?
Almost certainly true, but it would have cost me more than £20 from them Very Happy
Edit; Oh, I realise I need to leave it for a while to see if the level drops, but I'm still going to have left over acid here...
PostPosted: 17:13 - 09 Feb 2005    Post subject: Reply with quote
"The solution to Pollution is dilution."
Wash it down the drain with LOTS of running water, this will dilute the acid to a degree where it is not of any concern. Always add strong acid to water and not water to strong acid.
Switch on the tap to a high flow rate and trickle the waste acid down there with the water, rinse out the containers with similarly large amounts of water and throw them in the domestic rubbish. Again, wear goggles in case any of it splashes
If any of the containers are still sealed, keep hold of them. Battery acid is increasingly hard to come by in the retail sector and if you accidentally spill some out of your battery, you have something to replace it with.
Bomberman
PostPosted: 17:17 - 09 Feb 2005    Post subject: Reply with quote
Cool, gotcha Thumbs Up Cheers mate.
Anyhoo, its all done and reading a robust 12.43V which hope fully means an end to the problem in this thread Thumbs Up
PostPosted: 17:58 - 09 Feb 2005    Post subject: Reply with quote
Buy batteries at the classis bike shows and it normally comes with a couple of squeezy bottles of acid. With the 12V 9ah ones used on the 125 there is normally half a bottle left over.
The last post was made 21 years, 3 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 2.27 - MySQL Queries: 13 - Page Size: 86.3 Kb
