Filtering at Pedestrian Crossings?
zico
PostPosted: 14:54 - 14 Oct 2015    Post subject: Filtering at Pedestrian Crossings? Reply with quote
Guys and girls, what's the deal with this? I filtered past a van today at a crossing when the light was red. I went slowly up the outside of him and stopped. As I moved away he did as well and tried to stay level with me to intimidate me into backing off. I didn't. I suspect that he saw the 125 and an L plate and thought he was dealing with a kid that wouldn't bite back rather than a middle aged man that does. He was a skinhead guy with tattoos but didn't argue much when I stepped off the bike and went to his window. His argument was that he can't go past cars like that in his van.
What are the legalities of filtering in these situations? Sorry for the noob question, I've looked but advice is contradictory.
Andy_Pagin
PostPosted: 15:01 - 14 Oct 2015    Post subject: Reply with quote
For zig-zag marked junctions the legality is that you cannot overtake the lead vehicle if it is moving, or if the crossing is in use.
As for dealing with 'blockers', don't get off and start a row, filter away, leave them fuming and get on with your life.
hellkat
PostPosted: 15:08 - 14 Oct 2015    Post subject: Reply with quote
Andy_Pagin wrote:
Some helpful stuff
But if you can take the piss, then do so, without being caught by the rozzers.
zico
PostPosted: 15:16 - 14 Oct 2015    Post subject: Reply with quote
Right. There were indeed zigzag markings. He was the lead vehicle but was stationary and the crossing was in use. I should technically have sat behind him then.
Not that he knew that though, he just objected to being passed. I need to master the art of giving no fcks.
zico
PostPosted: 15:18 - 14 Oct 2015    Post subject: Reply with quote
As always. Razz
zico
PostPosted: 15:20 - 14 Oct 2015    Post subject: Reply with quote
I actually have it on video from my camera, if it's not to incriminating I'll throw it up although as above I was obviously in the wrong.
ScaredyCat
PostPosted: 15:32 - 14 Oct 2015    Post subject: Reply with quote
If you tried to overtake him there, it's incriminating.
28.—(1) Without prejudice to regulation 27, a zig-zag line shall convey the requirement that, whilst any motor vehicle (in this regulation called “the approaching vehicle”) or any part of it is within the limits of a controlled area and is proceeding towards the signal-controlled crossing facility to which the controlled area relates, the driver of the vehicle shall not cause it or any part of it—
(a)to pass ahead of the foremost part of any other motor vehicle proceeding in the same direction; or
(b)to pass ahead of the foremost part of a vehicle which is stationary for the purpose of complying with the indication given by a traffic light signal for controlling vehicular traffic.
https://www.legislation.gov.uk/uksi/2002/3113/regulation/28/made
HWC 191 :
You MUST NOT park on a crossing or in the area covered by the zig-zag lines. You MUST NOT overtake the moving vehicle nearest the crossing or the vehicle nearest the crossing which has stopped to give way to pedestrians.
Laws ZPPPCRGD regs 18, 20 & 24, RTRA sect 25(5) & TSRGD regs 10, 27 & 28
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
PostPosted: 15:39 - 14 Oct 2015    Post subject: Reply with quote
No "passing ahead of" any moving motor vehicle.
No "passing ahead of" the nearest stationary vehicle to the crossing (including a pushbike, "motor" not being specified) if the lights are red / a zebra crossing is in use.
There's a hair to be split over exactly what "pass ahead of" means, and whether there's a magic moment when you can blow past a stationary vehicle before it starts moving the instant that the light changes to green or Doris gets off the crossing.
Andy_Pagin
PostPosted: 15:45 - 14 Oct 2015    Post subject: Reply with quote
From a practical point of view, having witnessed the suicidal inability many pedestrians have to master a crossing I'd say stay put and let the other vehicle risk getting fined and/or killing someone.
zico
PostPosted: 15:50 - 14 Oct 2015    Post subject: Reply with quote
On the upside, I've learnt something else today and nobody died, that's what it's all about.
pompousporcup...
PostPosted: 15:56 - 14 Oct 2015    Post subject: Reply with quote
what if the crossing is a red light, with ziggy zagz, but you filter and stop at the leading drivers door (so not actually in front) but then as the lights change (and noone is crossing) you finish the over take? is that illegal?
zico
PostPosted: 16:11 - 14 Oct 2015    Post subject: Reply with quote
That's exactly what I did.
PostPosted: 16:27 - 14 Oct 2015    Post subject: Reply with quote
That's the magic moment I mentioned.
If the lights have actually gone green, and the other vehicle is still stationary, and you can get past before they start moving, then it's OK.
For that to happen they're either facebooking or have died at the wheel.
someotherguy
PostPosted: 16:54 - 14 Oct 2015    Post subject: Re: Filtering at Pedestrian Crossings? Reply with quote
y u no self-preservate?
Should have punched the van.
zico
PostPosted: 16:59 - 14 Oct 2015    Post subject: Re: Filtering at Pedestrian Crossings? Reply with quote
I stopped in front of him, got off the bike and told him exactly what I thought. There was traffic coming the other way so I didn't fancy unbalancing myself.
someotherguy
PostPosted: 17:02 - 14 Oct 2015    Post subject: Re: Filtering at Pedestrian Crossings? Reply with quote
I was joking... probably not a good idea to pick fights with vans Laughing
Feel free not to be intimidated when you're surrounded by a protective cage of metal. Otherwise, backing off seems the most sensible thing to do.
HTH Thumbs Up
Matt B
PostPosted: 18:02 - 14 Oct 2015    Post subject: Re: Filtering at Pedestrian Crossings? Reply with quote
I will wait for the "Got kicked around by 3 angry builders" thread then.
Make sure you get it all on cam Thumbs Up
zico
PostPosted: 18:07 - 14 Oct 2015    Post subject: Re: Filtering at Pedestrian Crossings? Reply with quote
I need to work on my temper but if I do get beat up at least it will be entertaining for you lot.
PostPosted: 21:40 - 14 Oct 2015    Post subject: Re: Filtering at Pedestrian Crossings? Reply with quote
Also an offence.
Highways Act 1980
1980 c. 66Part IX Obstruction of highways and streets
137 Penalty for wilful obstruction.
(1)If a person, without lawful authority or excuse, in any way wilfully obstructs the free passage along a highway he is guilty of an offence and liable to a fine not exceeding [F1level 3 on the standard scale].
zico
PostPosted: 21:43 - 14 Oct 2015    Post subject: Reply with quote
Lock me up and throw away the key...
PostPosted: 21:49 - 14 Oct 2015    Post subject: Re: Filtering at Pedestrian Crossings? Reply with quote
C'mon then, fight me.
What's the point in filtering past traffic if you then stop and get on your soap box?
zico
PostPosted: 21:52 - 14 Oct 2015    Post subject: Re: Filtering at Pedestrian Crossings? Reply with quote
Yes, fair point. Have you never stopped to voice your disapproval at the actions of other road users though?
Undinist
PostPosted: 22:18 - 14 Oct 2015    Post subject: Reply with quote
Eh? Not where I live guv'nor. I draw level with the lead vehicle when the light is red, and having cunningly anticipated the amber light I zip off the instant it shows, ideally without putting a foot down. It's stretching the rules a bit, but that's what bikes are for. And the driver has no opportunity to make his displeasure known to me. If he does get the chance I ignore him and carry on doing all the bikey things he objects to as if he doesn't exist. That's what really pisses them off - being ignored and insignificant.
Current bike: K1100RS. Previous: CD200, GSX250, GT550, VFR750, K100LT, K1100LT, R1100GS, R1150GS, ZZR1100, Hayabusa, RSV Mille, MV F4 750S, R1, ZX-10, KTM Adventure 950S
PostPosted: 22:54 - 14 Oct 2015    Post subject: Reply with quote
Tut Tut Tut Tut Tut Tut
If you're gonna go on red/amber you might as well just go on red. They mean the same thing.
recman
PostPosted: 22:58 - 14 Oct 2015    Post subject: Re: Filtering at Pedestrian Crossings? Reply with quote
Not worth it. I just shake my head and ride away on my high horse. Wink
The last post was made 10 years, 330 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 136.31 Kb
