Gearbox Problem
Suntan Sid
PostPosted: 17:54 - 19 Oct 2015    Post subject: Gearbox Problem Reply with quote
I was out for a ride on my XL125 earlier, after a 25 mile ride I was 20m from home when I lost all gears apart from first.  I had just been slowing down for a junction and had gone down through all the gears.  There were no grinding/knocking/crunching noises and I could find neutral.
Got it home, dropped the oil and got the clutch cover off to have a look at the shift mechanism.  There were no nasty surprises in the oil so I assume nothing has disintegrated.
With the clutch cover off, when you move the gear change the cam gearshift, (No.6 in the diagram), moves round in both direction but it doesn't stop after 5 changes, it just carries on, same with downshifts, however it doesn't select a gear.
Any thoughts?
My initial thought is that the pin, (No20. on the diagram), has failed.
https://images.cmsnl.com/img/partslists/honda-xl125s-1982-englandmph-shift-drumshift-fork_big00029547e__1400_a9b1.gif
PostPosted: 18:51 - 19 Oct 2015    Post subject: Reply with quote
My guess is the index pin - No20 in the diagram - has sheared.
Suntan Sid
PostPosted: 20:24 - 19 Oct 2015    Post subject: Reply with quote
With the engine still in the frame, and not wishing to take the head off, what's the best method of locking the crank so I can get the clutch basket off?
The manual says put it in fourth gear and use the back brake, seeing as I've got no gears at the moment, that's not viable!
PostPosted: 20:38 - 19 Oct 2015    Post subject: Reply with quote
Nut gun is the quickest way. If you haven't got access to one of those I look at wedging a small piece of wood in the primary teeth. Go easy though if you snap a tooth you'll need a new basket.
Islander
PostPosted: 20:51 - 19 Oct 2015    Post subject: Reply with quote
Beg steal or borrow an impact wrench - it'll make short work of it. Thumbs Up
PostPosted: 21:18 - 19 Oct 2015    Post subject: Reply with quote
I used the back brake and rags to do the 250. Shifty
Ariel Badger
PostPosted: 21:22 - 19 Oct 2015    Post subject: Reply with quote
Jamming a lump of wood between chain and sprocket does it for me.
Suntan Sid
PostPosted: 21:44 - 19 Oct 2015    Post subject: Reply with quote
Thanks for the suggestions, unfortunately a couple of them require the bike being in gear, which I can't do at the moment, so I guess I'll have to jam something in the primary drive.
Do you reckon I could do it with an impact driver and a hammer?
I can't get hold of a rattle gun.
Ariel Badger
PostPosted: 22:02 - 19 Oct 2015    Post subject: Reply with quote
Jam up the primary drive and try, Other way is to take a plug out and feed rope into the barrel at BDC and use that to lock it all up.
Chuffin Nora
PostPosted: 22:07 - 19 Oct 2015    Post subject: Reply with quote
HTTH...and I could be wrong, but perhaps holding No.12 with a socket, provided that the tension is in the 'doing up' direction. Thinking
https://www.bike-parts-honda.com/pieces-honda-detail-37288-1343701A-XL125SC-1982-E__0900-XLS+125.html
(No microfiche for RC)
There's a fine line between integrity
skatefreak
PostPosted: 22:43 - 19 Oct 2015    Post subject: Reply with quote
A bit of cardboard, folded up and feed into the primary gears.
Has worked for me every time and seems kind to the gears.
Best of luck.
mentalboy
PostPosted: 22:45 - 19 Oct 2015    Post subject: Reply with quote
When no rattle gun available I've found the best way is to buy a steel clutch plate for the model in question and weld a piece of bent bar to it then pop it on the end of the basket and Bob's your uncle!
EDIT: For clarity... you hang onto the bar whilst swinging a socket wrench on the nut!!!
Suntan Sid
PostPosted: 23:39 - 19 Oct 2015    Post subject: Reply with quote
I thought about that, but it's a toss up as to which would loosen first!
Teflon-Mike
tl;dr
PostPosted: 09:29 - 20 Oct 2015    Post subject: Reply with quote
If its the generic 'small-honda' clutch:-https://i178.photobucket.com/albums/w269/teflons-torque/Little%20Dreams/LD07%20Eng%20Build/100_0503.jpg
then you'll want the special castle-nut socket, (Honda Service tool, 07716-0020100) to get the pack out before you take the basket off. They are about a tenner on e-bay.
As to locking the shafts, after you've done the tab-washer, shouldn't need to much torque to hold it.. there's another Honda special tool for holding the basket.... a big C-Spanner, if I remember the picture in the manual correctly... if you could find one of them cheap on the bay... else, the strap-type spin on filter wrench for cars, around the outside of the basket MIGHT be just enough purchase; My favourite primary drive 'locking' tool was a thick bit of dural strip.. teeth bit into it and didn't leave saw-dust or threads like wood or rags.
If you have oil-pump, as the Benley engine in pic; then be careful, using the jamming method, there isn't a lot of wiggle room to get owt in between the cogs, behind that brittle ally casing.. and screws holding the pump on are close cousins of the ones on master-cylinder reservoir caps.
groovylee
PostPosted: 10:11 - 20 Oct 2015    Post subject: Reply with quote
Sid, i cant remember where you are, but i have a battery rattle gun (and an air one for that matter) that you are more than welcome to borrow for as long as you need Thumbs Up
i could post the battery one if required, although it might be a little pricey.
Past - 1988 honda revere 600, 1996 kawasaki gpz500s, 1999 Yamaha R6
Current - 2002 Aprilia RSV1000R & 1999 Kawasaki ZX6R
Suntan Sid
PostPosted: 10:23 - 20 Oct 2015    Post subject: Reply with quote
mpd72 wrote:
Is the return spring on the selector shaft OK? Does the shaft return to centre when turned by the gear lever?
It appears to be, got a choice of two spares on my other engines.
Teflon-Mike wrote:
If its the generic 'small-honda' clutch then you'll want the special castle-nut socket, (Honda Service tool, 07716-0020100) to get the pack out before you take the basket off. They are about a tenner on e-bay.
I don't need to get the oil pump off, I couldn't get it off when I rebuilt the engine and managed to get everything else off and on with it in place.
I've got the castellated socket needed to remove the clutch.
Thanks for all the help!
Fizzer Thou
PostPosted: 12:50 - 20 Oct 2015    Post subject: Reply with quote
I used a 2p piece when doing the KTM
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Workshop/Picture006.jpg
Always have a 'Plan B'
Suntan Sid
PostPosted: 16:35 - 20 Oct 2015    Post subject: Re: Gearbox Problem Reply with quote
Well, to conclude this sorry episode, it turns out that bolt No.16 had come loose, cheeky little monkey, probably forgot to tighten it during the rebuild. Embarassed
In my defence there's no torque setting for it in the manual.
Unfortunately I couldn't tighten it with everything else in place, the clutch was just slightly in the way, so had to remove the oil filter and the clutch. I used a piece of 2mm thick aluminium bar to lock everything up to remove and replace the oil filter.
For the clutch I put in it gear, jammed a rag in the sprocket, locked the back break up with a cable tie, (drums), and got Mrs Suntan to sit on the bike, with the front brake on.
A PITA really because the gearbox is as sweet as, hardly makes a sound when changing up and down.
Going to get the casing back on in a moment, I'll put everything else, brake lever, kick start, clucth cable etc, back on tomorrow and hopefully remember to refil it with oil!!!!
Thanks for all the help! Thumbs Up
PostPosted: 16:54 - 20 Oct 2015    Post subject: Reply with quote
If you don't have torque figures just use the standard one for that size of bolt. For M6 that would be 7 foot pounds or 10Nm.
Some threadlock would be a good idea to hold permanently in place.
The last post was made 11 years, 31 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 115.86 Kb
