| Suntan Sid |
 Posted: 17:54 - 19 Oct 2015 Post subject: Gearbox Problem |
I was out for a ride on my XL125 earlier, after a 25 mile ride I was 20m from home when I lost all gears apart from first. I had just been slowing down for a junction and had gone down through all the gears. There were no grinding/knocking/crunching noises and I could find neutral.
Got it home, dropped the oil and got the clutch cover off to have a look at the shift mechanism. There were no nasty surprises in the oil so I assume nothing has disintegrated.
With the clutch cover off, when you move the gear change the cam gearshift, (No.6 in the diagram), moves round in both direction but it doesn't stop after 5 changes, it just carries on, same with downshifts, however it doesn't select a gear.
Any thoughts?
My initial thought is that the pin, (No20. on the diagram), has failed.
https://images.cmsnl.com/img/partslists/honda-xl125s-1982-englandmph-shift-drumshift-fork_big00029547e__1400_a9b1.gif ____________________ "Everybody needs money, that's why they call it money!"  |
 Posted: 18:51 - 19 Oct 2015 Post subject: |
My guess is the index pin - No20 in the diagram - has sheared. ____________________ a.k.a 'Geri'
| Suntan Sid |
 Posted: 20:24 - 19 Oct 2015 Post subject: |
With the engine still in the frame, and not wishing to take the head off, what's the best method of locking the crank so I can get the clutch basket off?
The manual says put it in fourth gear and use the back brake, seeing as I've got no gears at the moment, that's not viable! ____________________ "Everybody needs money, that's why they call it money!"  |
 Posted: 20:38 - 19 Oct 2015 Post subject: |
Nut gun is the quickest way. If you haven't got access to one of those I look at wedging a small piece of wood in the primary teeth. Go easy though if you snap a tooth you'll need a new basket. ____________________ a.k.a 'Geri'
| Islander |
 Islander World Chat Champion
 Posted: 20:51 - 19 Oct 2015 Post subject: |
Beg steal or borrow an impact wrench - it'll make short work of it.  |
| Howling TerrorOutOfOffice |
| Ariel Badger |
 Ariel Badger Super Spammer
| Suntan Sid |
 Posted: 21:44 - 19 Oct 2015 Post subject: |
Thanks for the suggestions, unfortunately a couple of them require the bike being in gear, which I can't do at the moment, so I guess I'll have to jam something in the primary drive.
Do you reckon I could do it with an impact driver and a hammer?
I can't get hold of a rattle gun. ____________________ "Everybody needs money, that's why they call it money!"  |
| Ariel Badger |
| Chuffin Nora |
 Chuffin Nora World Chat Champion
| skatefreak |
| mentalboy |
 mentalboy World Chat Champion
| Suntan Sid |
 Posted: 23:39 - 19 Oct 2015 Post subject: |
I thought about that, but it's a toss up as to which would loosen first! ____________________ "Everybody needs money, that's why they call it money!"  |
 - Super Spammer
| Teflon-Mike |
 Posted: 09:29 - 20 Oct 2015 Post subject: |
If its the generic 'small-honda' clutch:-https://i178.photobucket.com/albums/w269/teflons-torque/Little%20Dreams/LD07%20Eng%20Build/100_0503.jpg
then you'll want the special castle-nut socket, (Honda Service tool, 07716-0020100) to get the pack out before you take the basket off. They are about a tenner on e-bay.
As to locking the shafts, after you've done the tab-washer, shouldn't need to much torque to hold it.. there's another Honda special tool for holding the basket.... a big C-Spanner, if I remember the picture in the manual correctly... if you could find one of them cheap on the bay... else, the strap-type spin on filter wrench for cars, around the outside of the basket MIGHT be just enough purchase; My favourite primary drive 'locking' tool was a thick bit of dural strip.. teeth bit into it and didn't leave saw-dust or threads like wood or rags.
If you have oil-pump, as the Benley engine in pic; then be careful, using the jamming method, there isn't a lot of wiggle room to get owt in between the cogs, behind that brittle ally casing.. and screws holding the pump on are close cousins of the ones on master-cylinder reservoir caps. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| groovylee |
 groovylee World Chat Champion
| Suntan Sid |
 Posted: 10:23 - 20 Oct 2015 Post subject: |
| mpd72 wrote: | Is the return spring on the selector shaft OK? Does the shaft return to centre when turned by the gear lever? |
It appears to be, got a choice of two spares on my other engines.
| Teflon-Mike wrote: | If its the generic 'small-honda' clutch then you'll want the special castle-nut socket, (Honda Service tool, 07716-0020100) to get the pack out before you take the basket off. They are about a tenner on e-bay.
If you have oil-pump, as the Benley engine in pic; then be careful, using the jamming method, there isn't a lot of wiggle room to get owt in between the cogs, behind that brittle ally casing.. and screws holding the pump on are close cousins of the ones on master-cylinder reservoir caps. |
I don't need to get the oil pump off, I couldn't get it off when I rebuilt the engine and managed to get everything else off and on with it in place.
I've got the castellated socket needed to remove the clutch.
Thanks for all the help! ____________________ "Everybody needs money, that's why they call it money!"  |
| Fizzer Thou |
| Suntan Sid |
 Posted: 16:35 - 20 Oct 2015 Post subject: Re: Gearbox Problem |
Well, to conclude this sorry episode, it turns out that bolt No.16 had come loose, cheeky little monkey, probably forgot to tighten it during the rebuild.
In my defence there's no torque setting for it in the manual.
Unfortunately I couldn't tighten it with everything else in place, the clutch was just slightly in the way, so had to remove the oil filter and the clutch. I used a piece of 2mm thick aluminium bar to lock everything up to remove and replace the oil filter.
For the clutch I put in it gear, jammed a rag in the sprocket, locked the back break up with a cable tie, (drums), and got Mrs Suntan to sit on the bike, with the front brake on.
A PITA really because the gearbox is as sweet as, hardly makes a sound when changing up and down.
Going to get the casing back on in a moment, I'll put everything else, brake lever, kick start, clucth cable etc, back on tomorrow and hopefully remember to refil it with oil!!!!
 Posted: 16:54 - 20 Oct 2015 Post subject: |
If you don't have torque figures just use the standard one for that size of bolt. For M6 that would be 7 foot pounds or 10Nm.
Some threadlock would be a good idea to hold permanently in place. ____________________ a.k.a 'Geri'
The last post was made 10 years, 145 days ago. Instead of replying here, would creating a new thread be more useful? |
