Front brake seals. Easy to replace?
Simba76
PostPosted: 18:14 - 21 Oct 2015    Post subject: Front brake seals. Easy to replace? Reply with quote
Just had my bike serviced and they told me the seals on the front brakes were going. The dust seal was damaged and if it broke off all the crap from the road would go into the calipers.
How easy are these to replace?
They are quoting me 140 for replacement. 63 for the seals and labour on top.
Should I get it done professionally?
If you can keep your head while all around are loosing theirs....you're probably in some sort of Zombie movie!
-Current bike ......
Bloggsy
PostPosted: 18:26 - 21 Oct 2015    Post subject: Reply with quote
No do it yourself it's a piece of piss, but if you don't feel confident have you got a knowledgable mate who could help you.
mudcow007
PostPosted: 18:59 - 21 Oct 2015    Post subject: Reply with quote
if you know what a socket set is, you are capable of doing them your self.
you do know what a socket set is.....dont you?
Jewlio Rides Again LLB
PostPosted: 19:18 - 21 Oct 2015    Post subject: Reply with quote
Buy a Haynes manual. Read the appropriate sections. Then decide if you're happy enough to have a crack at it yourself. Thumbs Up
Mpd72: I can categorically say i’m Brighter than that, no matter how I come across on here.
HAHAHA HAHAHA Blew Chilly MyCrowSystems
RhynoCZ
PostPosted: 19:25 - 21 Oct 2015    Post subject: Reply with quote
Read: https://www.bikechatforums.com/viewtopic.php?t=306985&start=0 Thumbs Up
Start at: Mount the calipers back on your motorcycle with no pads in them. Tighten the calipers there....
1, calipers back on bike (with no pads)
2, loosen up all the bolts + the bolt that holds the hose (not too much)
3, calipers off
4, push the pots out with the MC
5, split the caliper
PostPosted: 14:03 - 22 Oct 2015    Post subject: Reply with quote
A Proper Piston removal tool will help hugely.
Not the shitty plier things but one of these.
https://www.ebay.co.uk/itm/Motorcross-Motorcycle-Motorbike-Scooter-Brake-Piston-Wind-Back-Removal-Tool-/391176238884?hash=item5b13ebb724:g:-1gAAOSwHnFVgnO~
kramdra
PostPosted: 00:00 - 23 Oct 2015    Post subject: Reply with quote
Simba76 I would be extremely sceptical of that garage, it sounds like they are trying to scare money out of you. The situation is unlikely and if brakes are that bad they should not have let you ride away. How did they see/notice damage which will be hidden inside the calliper under dirt?
They are easy enough to strip and reassemble, but to clean everything properly is time consuming, and if you dont know how to bleed brakes the quick** way that can take just as long. Most of the time seals are in perfect condition and so far I have always reused them... but each pair cost 5-10 quid.. cbr6 with 8 pots can get expensive Shocked
** reverse fill with syringe, bleed at master banjo, then bleed normally.
Piston removal tool = foot pump - just be aware not to let brake fluid go down it, which will rot the pump seal and get into anything else. 150psi will pop most pistons out, wedge some cloth to catch it.
The last post was made 11 years, 28 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.24 - MySQL Queries: 13 - Page Size: 58.14 Kb
