Vfr 400 NC ??
Stalk
PostPosted: 09:36 - 24 Oct 2015    Post subject: Vfr 400 NC ?? Reply with quote
Hello!
Smallest Stalk has got her mind set on a Vfr 400 NC 30, as she is 19 in December. I thought it would be a good idea to ask the mighty Bcf what I should look out for and if the nc24 is worth a look?
Over to you!
Cheers!
Stalk
Rob Fzs
PostPosted: 09:54 - 24 Oct 2015    Post subject: Reply with quote
nc24 is hideous
nc30's are good, just make sure you get a test ride to check the gears out and if it pulls properly , they are getting rather old bikes now so had alot of abuse by learners
wr6133
PostPosted: 09:57 - 24 Oct 2015    Post subject: Reply with quote
Is she of the shorter persuasion? It's pretty cramped for taller people. I've not owned one but ridden one, other than being extremely cramped (I'm 6'1" and fairly long legged) the only other "eccentricity" was first gear was very tall.
redeem ouzzer
PostPosted: 10:26 - 24 Oct 2015    Post subject: Reply with quote
Standard ignition and jetting is useless. Use an Ignitech box and NC35 exhaust back section with a decent can / dyno set up for decent power. Follow HRC book to convert fuel tap to gravity feed. For 17" rear wheel there are various options out there, the Duke 916 one is cheapest but all will need a ride height correction.
joe.staffs
PostPosted: 11:15 - 24 Oct 2015    Post subject: Reply with quote
Things to consider are they're grey imports so parts arent always available or cheap.
A recent/current classic motorcycles magazine tells you what to look for when buying NC30's and mentions crap radiators on them
PostPosted: 11:30 - 24 Oct 2015    Post subject: Reply with quote
I had an NC21 but they are really old now. My NC21 did everything, touring, commuting, scratching, you name it. It was reliable, comfortable and practical, and being short it fitted me perfectly. It did have a 16in front wheel with a 18in rear.
They are good bikes, as are the NC24's but they are so ravaged with age and incompetent kiddie owners that it'll be hard to get a nice one.
I also owned an NC30, and despite not being in tip top condition it handled well, and was reasonably quick. It was easy to ride, although the riding position was crippling. The exhaust had rotted through, but there was a good bike under there somewhere.
One of the main downsides is that the V4's are extremely difficult to work on. Combine that with a microscopic size, and you've got a good reason why people don't get them serviced or fix the broken ones.
If you find a good one for a decent price then it'll be reliable and it'll work as a daily rider as long as your daughter is flexible enough to fit on it. I think we'll need pics to determine that.
Itchy
PostPosted: 11:34 - 24 Oct 2015    Post subject: Reply with quote
30s were nice but most today are old and battered often abused as a first bike by somebody recently passing their test.
In the northern group 3 such individuals bought VFR400s as their first bike post test. All of them crashed them and maintained them poorly.
One silly sod dropped a shim into the engine (or thought he did) and ended up dropping the entire engine and pulling the engine apart before finding the shim in his pocket. It never ran again.
A restricted steelie CBR would probably be a better choice for cheapness (no uber premium). It's big enough to work on and can be unchained when you get older.
wr6133
PostPosted: 11:51 - 24 Oct 2015    Post subject: Reply with quote
It would have to be a jellymould (or whatever the 1987-1990 one is called) to be A2 restrictable.
redeem ouzzer
PostPosted: 12:05 - 24 Oct 2015    Post subject: Reply with quote
Parts are piss easy. Plus anything exotic can be sourced via yahoo japan if you can internet well enough.
As standard the Jap spec bikes do need the mods i mentioned to get competitive top end power, as standard they give up 8-10 hp against a GK73A or ZXR.
Robby
Dirty Old Man
PostPosted: 20:04 - 24 Oct 2015    Post subject: Reply with quote
NC24s are awful.
NC30s seem to have quite a following. They are 25-30 years old. I would expect something like an ER6 to be similar on paper, close enough in price, and 20 years younger.
Islander
PostPosted: 23:56 - 25 Oct 2015    Post subject: Reply with quote
I wouldn't touch Ignitech with a bargepole. I bought their TCIP4 unit for my M900 last year and it failed a few months ago. They've ignored at least 6 emails I've sent, they don't publish a phone number and emails sent directly to the partners are bounced. Piss poor after sales service.
smallfrowne
PostPosted: 10:17 - 26 Oct 2015    Post subject: Reply with quote
I didn't think the standard ignition could be improved upon by much, hardly say it was useless anyway.
Standard Japanese jetting isn't good however. Change the jets out for UK Spec, piece of piss and no need for a dyno run. Really peps up the midrange.
18" rear is fine, ok there's only 2 tyres to choose from, you certainly won't need to start a "what tyre 4 me thread" then (not that there's anything wrong with that sort of thing). BT090 is a decent sport tyre that does well on the track, BT092 has a bit more life and is dual compound. Mind, I've never tried a PR4 so probably just don't know what I'm missing
'90 VFR750; '89 NC30; '95 DR650; '89 CD250U; ~'82 CG125; ~C90
redeem ouzzer
PostPosted: 10:25 - 26 Oct 2015    Post subject: Reply with quote
BT92 hasn't been available for years. Basically it's BT090 if you want something sticky. The standard ignition map is restrictive.
smallfrowne
PostPosted: 11:21 - 26 Oct 2015    Post subject: Reply with quote
Haha so you're right, BT090 all the way then, doh. What's so restrictive about the ignition map then?
redeem ouzzer
PostPosted: 12:28 - 26 Oct 2015    Post subject: Reply with quote
The stock curve gives midrange but flattens off too much at the top. A custom curve that fills it out basically gives the same top end as an inline 4 while losing none of the midrange grunt.
pits
PostPosted: 23:46 - 26 Oct 2015    Post subject: Reply with quote
Check the downpipes, IIRC you can't get them and are quite expensive to buy second hand, but this was a few years back.
Also carb seals are a pain to change, so check them if you can, as getting the carbs back on is a nightmare.
Jenks
PostPosted: 17:40 - 27 Oct 2015    Post subject: Reply with quote
i had an nc24, only problem i ever had was the cable to the CDI came loose... had me stumped and had to push it 2 miles home..
1978 MZ TS 250 1 Supa 5
1992 yamaha fzr1000 exup
1998 aprilia af1 sintesi
struan80
PostPosted: 03:22 - 28 Oct 2015    Post subject: Reply with quote
My poor little NC24 is heartbroken at some of the comments, you cruel cruel people Smile
https://i794.photobucket.com/albums/yy224/struan80/12002237_10205343130402099_4472889020353097830_n_zpsutbyah2t.jpg
binge
Emo Kiddy
PostPosted: 22:38 - 30 Oct 2015    Post subject: Reply with quote
I had an NC30, and an NC29 (VFR and CBR).
Pros and cons to both.
I preferred the CBR overall.
The VFR had the 18" rear wheel. Wasn't much of an issue. I ran Dunlop Alpha 10s, epically sticky tyres, loved them!
kramdra
PostPosted: 01:47 - 31 Oct 2015    Post subject: Reply with quote
Did she get it? pics are required Laughing
For parts.. stuff is made.. but CBR bits seem more common.
https://www.ebay.co.uk/itm/400606729190
https://www.ebay.co.uk/itm/400931198648
Did I read that the VFR's require engine out to swap pipes?
Rob Fzs
PostPosted: 09:41 - 31 Oct 2015    Post subject: Reply with quote
no
'00 Aprilia RS50 > '92 Honda CG > '99 Yamaha Fazer > '91 Yamaha RXS > '79 Suzuki X5 > 01' Honda Cg > 07' Honda Cg > 82' Kawasaki Z200 > suzuki gsxr 400 gk73a > honda vfr 400 NC30> Yamaha RD350 YPVS F2 > Kawasaki ZZR 600 D1 > Yamaha TZR 250 2MA >Suzuki TL1000R > Yamaha TDR250 > Honda 929 blade > Suzuki SV1000 > Honda H100
Mod 2 Passed 09/06/2011
The last post was made 10 years, 313 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 113.81 Kb
