Oxford disk lock - faulty or wrong use?
foggy rider
PostPosted: 18:39 - 26 Oct 2015    Post subject: Oxford disk lock - faulty or wrong use? Reply with quote
Got an Oxford monster disk lock and followed instructions but it keeps going off even when nothing moves the lock or even the bike..... Does the lock need to be fully upright or something? I've read the instructions several times and can't work out why it's going off intermittently. It was ok last night (thank god!) but going on/off all day. I'm worried about using it at work tomorrow for the first time, as I park at the hospital so it will really get on people's nerves if it's going off all day.......
Help!! Any advice?
Cautious newbie...... (CBT Oct-15) riding a Honda CB125F to get some experience. Theory test done in March). Now looking to do DAS, just gotta find the right training centre.....
wednesday
PostPosted: 18:52 - 26 Oct 2015    Post subject: Reply with quote
have you got a cover on the bike? Could it be knocking the lock as the wind blows on it?
PostPosted: 19:43 - 26 Oct 2015    Post subject: Reply with quote
Can you take the batteries out?
foggy rider
PostPosted: 20:02 - 26 Oct 2015    Post subject: Reply with quote
No, no cover, it's in a car port so no rain on it either.......
As for taking batteries out, that would presumably make it ineffective as an alarm.......
Don't particularly want to ditch £60 worth of alarm Sad any other ideas?
bugeye_bob
PostPosted: 20:33 - 26 Oct 2015    Post subject: Reply with quote
you could just have a faulty unit, can you test it off the bike inside to see if it is faulty.
monkeybiker
PostPosted: 22:44 - 26 Oct 2015    Post subject: Reply with quote
Did you just buy it? If so send it back and get a replacement.
I used to have one but kept dropping it cos I'm clumsy and eventually broke it but it lasted a few years without trouble. Sounds like you have a faulty one.
chickenstrip
PostPosted: 22:59 - 26 Oct 2015    Post subject: Reply with quote
Sometimes the batteries have sat in the pack on the shelf for quite a while before they get put to use, and can go flat, which can cause intermittent faults like this. So could be it just needs new batteries. But as has been noted, it is an Oxford Product after all...bit hit and miss as to whether you get one that's any good in the first place.
foggy rider
PostPosted: 00:36 - 27 Oct 2015    Post subject: Reply with quote
Thanks for all the replies. I will try it out tomorrow and see how it goes as it's been ok this evening...... If problems again, will change batteries, and if still no good will return it. Bloody annoying but would rather have an alarm as nothing to chain it to at work in the bike park Neutral
recman
PostPosted: 07:33 - 27 Oct 2015    Post subject: Reply with quote
Is the front disc on your bike large enough in diameter for you to be able to fit the lock on the bottom of the disc with its body resting on the rim of your wheel so the lock isn't hanging from the disc?
Sounds weird but there may be a problem with the locking mechanism itself and the pressure of the lock being 'pulled' by hanging as it were, may be setting the alarm off.
I'm not entirely sure if the actual alarm triggering unit is indeed linked to this mechanism so it's a bit of a long shot but it might work.
I'd also just make sure the shackle part of the lock is fully pushed into the case of the lock to eliminate any pressure on the internal mechanism.
This all may be complete bollocks but you've nothing to lose. Wink
PostPosted: 07:46 - 27 Oct 2015    Post subject: Reply with quote
Could just buy a 30 quid ncs alarm and buy a length of lifting chain. Oxford products suck dick.
pompousporcup...
PostPosted: 08:23 - 27 Oct 2015    Post subject: Reply with quote
MrGs1 wrote:
Anything made by Oxford bar a few items is shit. Throw it in the bin and fit one of these and use it in conjunction with a big fuck off almax chain.
at that price i may just give that a go. have you used it before?
*threadjack. sorry.
Mudshark
PostPosted: 08:50 - 27 Oct 2015    Post subject: Reply with quote
I have an Oxford Boss, Alarm disk lock.
when I got it it made no sound, had batteries out a few times, just couldn't get it to alarm. Was packing it back up a day or two later to take back to J&S when I dropped it. beeeeep!!
yup, been working fine ever since.
I do realise it's for visual deterrent only.
R1250RS
XT660X
PostPosted: 09:52 - 27 Oct 2015    Post subject: Reply with quote
Pikeys can see sound? Shocked
It's an Oxfraud, and nobody pays attention to alarms anyway, at least not to your benefit.
Amazon review wrote:
I've bought three of these over the past two and a half years, one got lost in an accident, and am still using the other two.
The first two came with two modules, one less, and one more sensitive, the idea being in the city, you'd want a less sensitive module as it could be knocked about and lead to false alarms.
The last, and I suspect this model, only came with one module, this I'm guessing is the more sensitive.
They are all alright at the beginning, but very quickly the false alarms start.
I've had the rep send me three modules to replace the ones that came with the locks, but they are all far too sensitive.
These alarms have been going off in locked garages with little or no air movement, I've looked for a common denominator, but there appears to be none, I've accidentally knocked the bike and the alarm has not gone off, yet half an hour after locking the garage the bike is in, the alarm sounds.
As I've had three of these, I speak with authority as all have displayed the same symptoms after a while.
With regard to rain setting them off, it's possible, but the one that's on the garaged bike has never been subjected to rain, and regularly goes off for no apparent reason, annoying the neighbours, and rendering it useless.
Why do I still use them? For the insurance discount, which incidentally, I'm not sure is that great.
Sorry, at that price it should come with selectable sensitivity, but... Oxfraud.
Mudshark
PostPosted: 11:41 - 27 Oct 2015    Post subject: Reply with quote
Very Happy
but, but, it's florescent doesn't say "POLITE" though Sad
and the "armed" beep is so much louder than the actual alarm noise which is pretty pathetic to be honest
R1250RS
XT660X
talkToTheHat
PostPosted: 14:09 - 28 Oct 2015    Post subject: Reply with quote
Alarms scare children, cats and delivery persons when activated. They also tell you when your bike has blown over in the wind, and when the postman has ripped your indicator off an hour before your mot.
Beeeeep bip bip
Me "please don't touch my bike"
Supermarket delivery goon "I'm not"
Beeeep
Me "the evidence suggests otherwise, don't touch the bike"
Beeep
Supermarket goon "what the fuck is that noise"
Me "that's the nugde alarm on the bike, it goes off when you touch it"
Supermarket goon "but.."
beeep
me "three strikes, you're out"
this was the point where the offending hand was removed from my mirror. This took a lot of explaining.
Alarms are only useful when you can hear them and they cannot be defeated with a rudimentary knowledge of electronics. They are also only useful if people understand that the sound is an alarm. Knowing what is reasonable force and what isn't also helps.
Bandit. does. everything.
The last post was made 11 years, 23 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 93.02 Kb
