Which shoulder check when exiting roundabout?
chupacabra
PostPosted: 20:27 - 28 Oct 2015    Post subject: Which shoulder check when exiting roundabout? Reply with quote
Just a quick question; which shoulder check you should do when exiting roundabout?
I always thought it should be left, to check for bicycles, but as far as I remember my instructor said it should be only the right shoulder check, to check for cars that want to exit from the inside lane.
What is the right answer?
arry
PostPosted: 20:46 - 28 Oct 2015    Post subject: Reply with quote
The right. Point being if you've got your lane position correct when exiting then nothing could be up the inside - whereas from the right you could have a car trying to jump in front and cut across you
Stalk
PostPosted: 20:58 - 28 Oct 2015    Post subject: Reply with quote
I've always checked the biggest bit of road, then the other side to be sure. 99 times in 100 unnecessary. 1 in 100 lifesaver as there is always another twat out there trying something, could even be another biker
MCN
PostPosted: 21:29 - 28 Oct 2015    Post subject: Reply with quote
You check the left before you exit. Same as any left turn.
Ask your instructor again.
chupacabra
PostPosted: 21:51 - 28 Oct 2015    Post subject: Reply with quote
Like arry said, that was an explanation of my instructor.
But when I'm taking an exit from the roundabout, do I also need to keep close to the left side? I know that what you should do on the exam but in real life, I'm sure a lot of morons will want to overtake centimetres away from you on your lane, or even try to take the same exit.
Similar to when you turn left at the traffic light and you supposed to turn left. A lot of time some idiot will line up right next to you and sometimes even turning left driving along side you.
What is the point of keeping close to the left when turning left?
MCN
PostPosted: 22:11 - 28 Oct 2015    Post subject: Reply with quote
Real life: I don't sit in the middle of the road if stopped at lights, give-ways, stop lines and stuff.
People might not see the bike and clatter into the back of you. (and punt you into traffic Shocked )
Take extra care at roundabouts until you are more confident and able to control the bike better. Roundabouts are a cnut for bikes and some people in cars, vans etc. don't give a shit.
PostPosted: 23:55 - 28 Oct 2015    Post subject: Reply with quote
Answer: it depends.
Sometimes you'll want to be close to the left when you exit, sometimes, you'll be towards the right. Depends on the roundabout, the traffic and where you're going next. There's no magic rule.
I've had a pedalist shoot through a roundabout at the bottom of a hill and overtake on the left. If I hadn't looked left and given him room, I've had had him embedded in me.
It depends.
Val
PostPosted: 00:43 - 29 Oct 2015    Post subject: Reply with quote
Rogerborg wrote:
Answer: it depends.
^^^ This.
It depends which exit you use to exit. 1st exit you look left, 2nd exit you look right, 3rd exit you look left. These are standard safety checks. Having said there is nothing standard on the road and the answer is it depends. Where do you expect the danger to come from.
You have marked all the usual nut jobs (White Vans, cycles, buses, trucks, Volvos, Minis, BMWs, Audis, Subarus, 4x4s, Minivans, 208s, VW Golfs basically all car models) on the approach, and you may want to look again and check are they are gonna do something stupid, most likely yes Laughing
rubyhorse2
PostPosted: 14:08 - 29 Oct 2015    Post subject: Reply with quote
As a few above have already mentioned, roundabouts can be a real danger for bikers.
My 2 rules are, dominate the lane you are in, ie dont hug any edges and be a timid little mouse (if cars see more space they tend to think they can use this space). Your a vehicle just like any other. and the second rule is be overly observant, do shoulder checks to both sides and be aware of where all vehicles are and what they might be about to do.
MCN
PostPosted: 19:04 - 29 Oct 2015    Post subject: Reply with quote
There is no real need to look right if you are turning left off a roundabout. If you are in the correct lane for the exit it is a simple left turn off the roundabout and the left shoulder check is all you need.
You will look right when entering the roundabout.
Rich Bryce
PostPosted: 22:31 - 29 Oct 2015    Post subject: Reply with quote
Left at whatever exit in case another motorcycle, scooter or fast cyclist has crept inside you without you having noticed.
'Love all, trust a few, do wrong to none, oh, and ride a Bonnie' William Shakespeare
andyscooter
PostPosted: 09:57 - 30 Oct 2015    Post subject: Reply with quote
I was always taught
left hand as you go past a junction to make sure nothing is coming out of it and right as you pull off to check nothing has come straight over in the wrong lane and is turning into the same turning as you
JonWal
PostPosted: 11:39 - 02 Nov 2015    Post subject: Reply with quote
Just to throw a spanner in the works, I was also told to check my right shoulder when taking a left exit off a roundabout.
I queried this with the instructor afterwards and had the explaination that a car could be trying to get past you on the exit.
If you're coming off a dual (or if another motorist is for that matter) and exiting onto a single, then you could effectively have two lanes squeezing into one. In this situation a right lifesaver could be the difference.
- Yamaha YBR 125 - Swansea, UK
- Triumph Street Triple
A Licence Passed 25.09.2015
talkToTheHat
PostPosted: 04:59 - 03 Nov 2015    Post subject: Reply with quote
Didnt we go over this last week?
Look to the side the vehicle that is about to kill you is coming from. Or look towards the tarmac not the kerb. Possibly do a cyclist check to your left as well.
Enter roundabout from the left and turing left, look right.
Going straight on, if you stay to the left, look right. If you took the right hand lane through the roundabout, look left as you exit.
Turning right, staying right through roundabout, look left as you exit.
If spiral or many-lane roundabout, all hell can be unleashed.
Bandit. does. everything.
Val
PostPosted: 01:24 - 05 Nov 2015    Post subject: Reply with quote
Agree to disagree here.
If you exit the second exit you always look right, because from there all the guys who are NOT in the correct lane will try to overtake and cut you down, and they are coming from behind you means you may have missed some Subaru in the mirrors. Hence required right lifesaver.
And you do not need to do a left shoulder check, you know what is on the left side of you, because you just have passed the 1st exit from which any danger can come to you - so no need for left shoulder check on 2nd exit.
That is exactly what all instructors that I know are teaching and what is required on DAS mod 2.
Which exit? Because all roundabout exits are left, but matters which number is you are exiting. 1st, 2nd or 3rd?
For example checking right shoulder when you exit 1st or 3rd exits is something completely wrong. You already have seen the traffic comming to your right on the approach. What you need is left lifesaver there, because the only danger can come to you from behind on the left side, because you may have missed something in the mirrors and you are going left.
Barnoe
PostPosted: 21:31 - 09 Nov 2015    Post subject: Reply with quote
As already said, do as your instructor says and get your licence.
Then as you ride more you will gain experience and more awareness... this means you learn that riding by the book isnt always safest.
95% of the time the books you read are right... but certain conditions mean you have to adapt
https://www.mc-ams.co.uk/wp-content/uploads/2014/06/RA_rAbout-Car-Straight-Ahead-Left-Lane-copy.jpg
The above example for instance.... which shoulder is best to check Wink
You know you are old when you're told to slow down by your doctor and not the police.
Lord Percy
PostPosted: 23:29 - 09 Nov 2015    Post subject: Reply with quote
Don't base it on which lane you're in or which lane you're supposed to look at. It's not really about any sort of prescribed rule for where you're expected to mechanically crane your neck to pass the test. It's supposed to be about saving your skin. Just check anywhere a life-threatening hazard might be coming from. The idea is to get a feel for where these dangers might be.
( Personally I even do sly shoulders checks when I'm out walking on the footpath now, I can't help it any more Laughing )
PostPosted: 23:48 - 09 Nov 2015    Post subject: Reply with quote
For a standard roundabout with 3 exit points as you approach it goes a little like this:
1. First exit left. Left shoulder check before exiting the roundabout. You should be in the left lane.
2. Second exit straight ahead, Right shoulder check, there is no harm in looking left also but the important one is the right check. You should be in the left lane unless the road markings/signs say otherwise. If the signs say right hand lane I would check both shoulders.
3: Third exit right. Left shoulder check. You should be in the right hand lane for this.
The Disapproving Brit
PostPosted: 15:25 - 10 Nov 2015    Post subject: Reply with quote
tl;dr: Look whereever things might come from. If you're in the outside lane on a roundabout and you're passing or using an exit, check right to make sure nobody is taking that exit from the inside lane. If you're in the inside lane and moving into the outside lane, check left to make sure you're not moving into anyone's path.
It's just about understanding where other traffic is likely to come from, and making sure there isn't anyone there.
Current Bikes: 1983 Honda VF400FD / 2003 Honda VT750 Shadow
Bike Test Passed 18/03/09, Car Test Passed 14/05/13
MCN
PostPosted: 16:17 - 10 Nov 2015    Post subject: Reply with quote
Awe how much simpler/safer would shopping be if they did this in bloody supermarkets too? Rolling Eyes
Very Happy
The last post was made 10 years, 319 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 110.59 Kb
