Rear wheel alignment
Ottocle
PostPosted: 18:13 - 31 Oct 2015    Post subject: Rear wheel alignment Reply with quote
As the VFR has a single swing arm, is wheel misalignment a problem? I recently changed the rear brake pad and have noticed my chain having irregular tension when the wheel is turned. Could this be due to the way I have fitted the back wheel again or do I just need to replace the drive chain (it has been 36,000 miles)?
RhynoCZ
PostPosted: 19:04 - 31 Oct 2015    Post subject: Reply with quote
Check for dead links in the chain. Thumbs Up
IF the wheel alignment was wrong, you'd see uneven wear on the chain and sprockets. I mean the inside and outside of the sprocket's teeth and chain. Thumbs Up
EDIT: 36,000 miles pretty much sounds like a new chain time. 36k is more than I've got on my clock at the moment and I don't have the original factory fitted chain there. Smile
FlightRisk
PostPosted: 19:15 - 31 Oct 2015    Post subject: Reply with quote
Chains wear with tight and loose spots. Measure and set your chain tension at the tightest spot.
As above, if it has stiff links it may need replacing.
Honda CB500S
The last post was made 11 years, 19 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 35.79 Kb
