| kawashima |
 kawashima World Chat Champion
 Posted: 14:50 - 01 Nov 2015 Post subject: throttle rocker (for safety) |
This is my personal opinion, and lots of veteran riders may disagree, I think throttle rocker is good for safety rather than comfort.
Because you can keep the throttle open with your palm easily, so you can always cover the brake lever more easily with your first and middle fingers.
Beginner riders are not good at (always) covering brake levers, so in my opinion, beginner riders should use throttle rocker for daily safety.
A few points to be careful
-When braking, you must reverse the throttle more intentionally than without throttle rocker. But small bikes don't have much power so it won't be a big trouble than big powerful bikes.
-When cruising at different speed range, you must rotate throttle rocker with your hand, and you should be careful not to do this in busy traffic.
I might had better to post this in the thread "Do you cover your levers?", but I wanted to know your comments on throttle rocker. ____________________ own:2020 Serow 250
owned: 2012 YB125SP, 2008 TDM900, 2005 W650, 2002 LS125R, 2002 CB400SF, NS50F, C50 / Trip to UK(2009), Hokkaido touring(2013) |
| iooi |
 iooi Super Spammer
 Posted: 16:01 - 01 Nov 2015 Post subject: |
Never used one and would never think of using one.
A well maintained throttle will be easy to use that you do not have to grip it. Mine have always been so easy to move that friction of your hand on there is enough to control it.
Far too many new riders grip the throttle to tight.
A throttle should not need to be closed by hand. It should shut on its own. If it does not then you need to get it sorted.
Covering the brakes is another story. Again I find that 2 fingers over the front brake is more than enough in traffic.
The rest is all done by the eyes and knowing the dangers that may happen. ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| cb1rocket |
 cb1rocket World Chat Champion
 Posted: 17:07 - 01 Nov 2015 Post subject: |
Completely unnecessary plus it's rather dangerous and basically becomes a cruise control feature. As above throttle should shut off completely when let go ____________________ Honda H100S2 Rebuild - https://www.bikechatforums.com/viewtopic.php?t=253852 |
| kawashima |
| Wonko The Sane |
 Wonko The Sane World Chat Champion
| Triton Thrasher |
 Triton Thrasher Could Be A Chat Bot
| kawashima |
| Wonko The Sane |
| DrDonnyBrago |
| Sable |
 Sable World Chat Champion
| Ariel Badger |
 Ariel Badger Super Spammer
| Triton Thrasher |
| Ariel Badger |
| Triton Thrasher |
| temeluchus |
| Ariel Badger |
| talkToTheHat |
| DrDonnyBrago |
| Rogerborg |
 Rogerborg nimbA
 Posted: 12:37 - 02 Nov 2015 Post subject: Re: throttle rocker (for safety) |
I use a 'throttle rocker' / 'cramp buster' and would certainly not recommend attempting to use the rocker while covering the brakes.
Most of the time while commuting in traffic - which is when covering the brakes is particularly helpful - I keep the rocker rotated out of the way.
I only use it when I'm on a long stretch of open road, when I'm not covering the brakes.
The problem is that if your hand is positioned such that you're using the rocker to hold the throttle open, and you already have your fingers on the lever, and your thumb is behind the grip then it's problematical to apply the brakes while instantaneously rolling off the throttle. Contrast this with the hand motion when you reach for the lever, where you naturally tend to roll the throttle forwards.
So no, this is not something that I'd encourage, especially not for newer riders. ____________________ Biking is 1/20th as dangerous as horse riding.
| DrDonnyBrago |
 Posted: 13:14 - 02 Nov 2015 Post subject: Re: throttle rocker (for safety) |
Seems I use mine differently than Roger.
Mine is almost always in the same position and set fairly low. Mine is set so that in an upright, waiting at the lights position, it just rests against my palm, but doesn't operate the throttle.
I find it more useful around town than on motorways, I cover the brakes/roll off/blip the throttle on downshifts with it installed - the reason I like it is because I don't need to actively grip the bar when doing so. Throttle on my bike has quite a quick action, so set low it is both useful and out of the way.
If I'm riding like a douche then it doesn't see much use as it is pointing downwards and I adjust my grip high. If I am out on a very long motorway journey I may occasionally adjust it like Roger does, but I otherwise leave it be.
As for noob friendly, if set low, yes, if set high/adjusted whilst moving, probably not. |
| Triton Thrasher |
 Posted: 13:45 - 02 Nov 2015 Post subject: |
Thanks. I had no idea what a throttle rocker was. ____________________ Rrrrrrrrrrrrrrrrrr |
| Rogerborg |
 Rogerborg nimbA
 Posted: 14:26 - 02 Nov 2015 Post subject: Re: throttle rocker (for safety) |
They're great, especially if you have fat grips and short fingers.
| DrDonnyBrago wrote: | Mine is set so that in an upright, waiting at the lights position, it just rests against my palm, but doesn't operate the throttle. |
Is that with your hand rotated forwards under the lever, or could you have your fingers over the lever?
I'm trying to picture riding with fingers on the lever and pressure on the rocker. I may give it a try this afternoon. If I don't make it, avenge my death. ____________________ Biking is 1/20th as dangerous as horse riding.
| DrDonnyBrago |
| kawashima |
 Posted: 16:22 - 02 Nov 2015 Post subject: |
| rubyhorse2 |
 rubyhorse2 Traffic Copper
The last post was made 10 years, 312 days ago. Instead of replying here, would creating a new thread be more useful? |
